path: root/drivers/net/usb/usbnet.c
2014-10-28usbnet: add a callback for set_rx_modeOlivier Blin
To delegate promiscuous mode and multicast filtering to the subdriver. Signed-off-by: Olivier Blin <olivier.blin@softathome.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-23usb: hub: rename khubd to hub_wq in documentation and commentsPetr Mladek
USB hub has started to use a workqueue instead of kthread. Let's update the documentation and comments here and there. This patch mostly just replaces "khubd" with "hub_wq". There are only few exceptions where the whole sentence was updated. These more complicated changes can be found in the following files: Documentation/usb/hotplug.txt drivers/net/usb/usbnet.c drivers/usb/core/hcd.c drivers/usb/host/ohci-hcd.c drivers/usb/host/xhci.c Signed-off-by: Petr Mladek <pmladek@suse.cz> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-02cdc_subset: deal with a device that needs reset for timeoutOliver Neukum
This device needs to be reset to recover from a timeout. Unfortunately this can be handled only at the level of the subdrivers. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-30Revert "cdc_subset: deal with a device that needs reset for timeout"Linus Torvalds
This reverts commit 20fbe3ae990fd54fc7d1f889d61958bc8b38f254. As reported by Stephen Rothwell, it causes compile failures in certain configurations: drivers/net/usb/cdc_subset.c:360:15: error: 'dummy_prereset' undeclared here (not in a function) .pre_reset = dummy_prereset, ^ drivers/net/usb/cdc_subset.c:361:16: error: 'dummy_postreset' undeclared here (not in a function) .post_reset = dummy_postreset, ^ Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: David Miller <davem@davemloft.net> Cc: Oliver Neukum <oneukum@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-29cdc_subset: deal with a device that needs reset for timeoutOliver Neukum
2014-03-27usbnet: include wait queue head in device structureOliver Neukum
This fixes a race which happens by freeing an object on the stack. Quoting Julius: > The issue is > that it calls usbnet_terminate_urbs() before that, which temporarily > installs a waitqueue in dev->wait in order to be able to wait on the > tasklet to run and finish up some queues. The waiting itself looks > okay, but the access to 'dev->wait' is totally unprotected and can > race arbitrarily. I think in this case usbnet_bh() managed to succeed > it's dev->wait check just before usbnet_terminate_urbs() sets it back > to NULL. The latter then finishes and the waitqueue_t structure on its > stack gets overwritten by other functions halfway through the > wake_up() call in usbnet_bh(). The fix is to just not allocate the data structure on the stack. As dev->wait is abused as a flag it also takes a runtime PM change to fix this bug. Signed-off-by: Oliver Neukum <oneukum@suse.de> Reported-by: Grant Grundler <grundler@google.com> Tested-by: Grant Grundler <grundler@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-17usbnet: remove generic hard_header_len checkEmil Goode
This patch removes a generic hard_header_len check from the usbnet module that is causing dropped packages under certain circumstances for devices that send rx packets that cross urb boundaries. One example is the AX88772B which occasionally send rx packets that cross urb boundaries where the remaining partial packet is sent with no hardware header. When the buffer with a partial packet is of less number of octets than the value of hard_header_len the buffer is discarded by the usbnet module. With AX88772B this can be reproduced by using ping with a packet size between 1965-1976. The bug has been reported here: https://bugzilla.kernel.org/show_bug.cgi?id=29082 This patch introduces the following changes: - Removes the generic hard_header_len check in the rx_complete function in the usbnet module. - Introduces a ETH_HLEN check for skbs that are not cloned from within a rx_fixup callback. - For safety a hard_header_len check is added to each rx_fixup callback function that could be affected by this change. These extra checks could possibly be removed by someone who has the hardware to test. - Removes a call to dev_kfree_skb_any() and instead utilizes the dev->done list to queue skbs for cleanup. The changes place full responsibility on the rx_fixup callback functions that clone skbs to only pass valid skbs to the usbnet_skb_return function. Signed-off-by: Emil Goode <emilgoode@gmail.com> Reported-by: Igor Gnatenko <i.gnatenko.brain@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2014-01-13net: usbnet: fix SG initialisationBjørn Mork
Commit 60e453a940ac ("USBNET: fix handling padding packet") added an extra SG entry in case padding is necessary, but failed to update the initialisation of the list. This can cause list traversal to fall off the end of the list, resulting in an oops. Fixes: 60e453a940ac ("USBNET: fix handling padding packet") Reported-by: Thomas Kear <thomas@kear.co.nz> Cc: Ming Lei <ming.lei@canonical.com> Signed-off-by: Bjørn Mork <bjorn@mork.no> Tested-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-06usb: Fix FSF address in file headersJeff Kirsher
Several files refer to an old address for the Free Software Foundation in the file header comment. Resolve by replacing the address with the URL <http://www.gnu.org/licenses/> so that we do not have to keep updating the header comments anytime the address changes. CC: Oliver Neukum <oliver@neukum.org> CC: Steve Glendinning <steve.glendinning@shawell.net> CC: Oliver Neukum <oneukum@suse.de> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14usbnet: fix status interrupt urb handlingFelix Fietkau
Since commit 7b0c5f21f348a66de495868b8df0284e8dfd6bbf "sierra_net: keep status interrupt URB active", sierra_net triggers status interrupt polling before the net_device is opened (in order to properly receive the sync message response). To be able to receive further interrupts, the interrupt urb needs to be re-submitted, so this patch removes the bogus check for netif_running(). Signed-off-by: Felix Fietkau <nbd@openwrt.org> Tested-by: Dan Williams <dcbw@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-17usbnet: fix error return code in usbnet_probe()Wei Yongjun
Fix to return -ENOMEM in the padding pkt alloc fail error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Acked-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-28USBNET: fix handling padding packetMing Lei
Commit 638c5115a7949(USBNET: support DMA SG) introduces DMA SG if the usb host controller is capable of building packet from discontinuous buffers, but missed handling padding packet when building DMA SG. This patch attachs the pre-allocated padding packet at the end of the sg list, so padding packet can be sent to device if drivers require that. Reported-by: David Laight <David.Laight@aculab.com> Acked-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: "Noteworthy changes this time around: 1) Multicast rejoin support for team driver, from Jiri Pirko. 2) Centralize and simplify TCP RTT measurement handling in order to reduce the impact of bad RTO seeding from SYN/ACKs. Also, when both timestamps and local RTT measurements are available prefer the later because there are broken middleware devices which scramble the timestamp. From Yuchung Cheng. 3) Add TCP_NOTSENT_LOWAT socket option to limit the amount of kernel memory consumed to queue up unsend user data. From Eric Dumazet. 4) Add a "physical port ID" abstraction for network devices, from Jiri Pirko. 5) Add a "suppress" operation to influence fib_rules lookups, from Stefan Tomanek. 6) Add a networking development FAQ, from Paul Gortmaker. 7) Extend the information provided by tcp_probe and add ipv6 support, from Daniel Borkmann. 8) Use RCU locking more extensively in openvswitch data paths, from Pravin B Shelar. 9) Add SCTP support to openvswitch, from Joe Stringer. 10) Add EF10 chip support to SFC driver, from Ben Hutchings. 11) Add new SYNPROXY netfilter target, from Patrick McHardy. 12) Compute a rate approximation for sending in TCP sockets, and use this to more intelligently coalesce TSO frames. Furthermore, add a new packet scheduler which takes advantage of this estimate when available. From Eric Dumazet. 13) Allow AF_PACKET fanouts with random selection, from Daniel Borkmann. 14) Add ipv6 support to vxlan driver, from Cong Wang" Resolved conflicts as per discussion. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1218 commits) openvswitch: Fix alignment of struct sw_flow_key. netfilter: Fix build errors with xt_socket.c tcp: Add missing braces to do_tcp_setsockopt caif: Add missing braces to multiline if in cfctrl_linkup_request bnx2x: Add missing braces in bnx2x:bnx2x_link_initialize vxlan: Fix kernel panic on device delete. net: mvneta: implement ->ndo_do_ioctl() to support PHY ioctls net: mvneta: properly disable HW PHY polling and ensure adjust_link() works icplus: Use netif_running to determine device state ethernet/arc/arc_emac: Fix huge delays in large file copies tuntap: orphan frags before trying to set tx timestamp tuntap: purge socket error queue on detach qlcnic: use standard NAPI weights ipv6:introduce function to find route for redirect bnx2x: VF RSS support - VF side bnx2x: VF RSS support - PF side vxlan: Notify drivers for listening UDP port changes net: usbnet: update addr_assign_type if appropriate driver/net: enic: update enic maintainers and driver driver/net: enic: Exposing symbols for Cisco's low latency driver ...
2013-09-05net: usbnet: update addr_assign_type if appropriateBjørn Mork
This module generates a common default address on init, using eth_random_addr. Set addr_assign_type to let userspace know the address is random unless it was overridden by the minidriver. Signed-off-by: Bjørn Mork <bjorn@mork.no> Acked-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-12USBNET: support DMA SGMing Lei
This patch introduces support of DMA SG if the USB host controller which usbnet device is attached to is capable of building packet from discontinuous buffers. The patch supports passing the skb fragment buffers to usb stack directly via urb->sg. Cc: Ben Hutchings <bhutchings@solarflare.com> Cc: Grant Grundler <grundler@google.com> Cc: Freddy Xin <freddy@asix.com.tw> Cc: Alan Stern <stern@rowland.harvard.edu> Acked-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Ming Lei <ming.lei@canonical.com> Reviewed-by: Eric Dumazet <edumazet@google.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-27USBNET: increase max rx/tx qlen for improving USB3 thoughtputMing Lei
The default RX_QLEN()/TX_QLEN() didn't consider super speed USB device, so only max 4 URBs are scheduled at the same time for tx/rx, then USB3 NIC can't perform very well. With this patch, both rx and tx thoughput are increased more than 100Mbps when doing iperf test on ax88179_178a USB 3.0 NIC. Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-27USBNET: centralize computing of max rx/tx qlenMing Lei
This patch centralizes computing of max rx/tx qlen, because: - RX_QLEN()/TX_QLEN() is called in hot path - computing depends on device's usb speed, now we have ls/fs, hs, ss, so more checks need to be involved - in fact, max rx/tx qlen should not only depend on device USB speed, but also depend on ethernet link speed, so we need to consider that in future. - if SG support is done, max tx qlen may need change too Generally, hard_mtu and rx_urb_size are changed in bind(), reset() and link_reset() callback, and change mtu network operation, this patches introduces the API of usbnet_update_max_qlen(), and calls it in above path. Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-15USB: remove remaining instances of USB_SUSPENDAlan Stern
Commit 84ebc10294a3d7be4c66f51070b7aedbaa24de9b (USB: remove CONFIG_USB_SUSPEND option) failed to remove all of the usages of USB_SUSPEND throughout the kernel. This patch (as1677) removes the remaining instances of that symbol. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-08usbnet: allow status interrupt URB to always be activeDan Williams
Some drivers (sierra_net) need the status interrupt URB active even when the device is closed, because they receive custom indications from firmware. Add functions to refcount the status interrupt URB submit/kill operation so that sub-drivers and the generic driver don't fight over whether the status interrupt URB is active or not. A sub-driver can call usbnet_status_start() at any time, but the URB is only submitted the first time the function is called. Likewise, when the sub-driver is done with the URB, it calls usbnet_status_stop() but the URB is only killed when all users have stopped it. The URB is still killed and re-submitted for suspend/resume, as before, with the same refcount it had at suspend. Signed-off-by: Dan Williams <dcbw@redhat.com> Acked-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-11usbnet: handle link changeMing Lei
The link change is detected via the interrupt pipe, and bulk pipes are responsible for transfering packets, so it is reasonable to stop bulk transfer after link is reported as off. Two adavantages may be obtained with stopping bulk transfer after link becomes off: - USB bus bandwidth is saved(USB bus is shared bus except for USB3.0), for example, lots of 'IN' token packets and 'NYET' handshake packets is transfered on 2.0 bus. - probabaly power might be saved for usb host controller since cancelling bulk transfer may disable the asynchronous schedule of host controller. With this patch, when link becomes off, about ~10% performance boost can be found on bulk transfer of anther usb device which is attached to same bus with the usbnet device, see below test on next-20130410: - read from usb mass storage(Sandisk Extreme USB 3.0) on pandaboard with below command after unplugging ethernet cable: dd if=/dev/sda iflag=direct of=/dev/null bs=1M count=800 - without the patch 1, 838860800 bytes (839 MB) copied, 36.2216 s, 23.2 MB/s 2, 838860800 bytes (839 MB) copied, 35.8368 s, 23.4 MB/s 3, 838860800 bytes (839 MB) copied, 35.823 s, 23.4 MB/s 4, 838860800 bytes (839 MB) copied, 35.937 s, 23.3 MB/s 5, 838860800 bytes (839 MB) copied, 35.7365 s, 23.5 MB/s average: 23.6MB/s - with the patch 1, 838860800 bytes (839 MB) copied, 32.3817 s, 25.9 MB/s 2, 838860800 bytes (839 MB) copied, 31.7389 s, 26.4 MB/s 3, 838860800 bytes (839 MB) copied, 32.438 s, 25.9 MB/s 4, 838860800 bytes (839 MB) copied, 32.5492 s, 25.8 MB/s 5, 838860800 bytes (839 MB) copied, 31.6178 s, 26.5 MB/s average: 26.1MB/s Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-11usbnet: apply usbnet_link_changeMing Lei
Use usbnet_link_change to handle link change centrally. Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-11usbnet: introduce usbnet_link_change APIMing Lei
This patch introduces the API of usbnet_link_change, so that usbnet can handle link change centrally, which may help to implement killing traffic URBs for saving USB bus bandwidth and host controller power. Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/intel/e1000e/ethtool.c drivers/net/vmxnet3/vmxnet3_drv.c drivers/net/wireless/iwlwifi/dvm/tx.c net/ipv6/route.c The ipv6 route.c conflict is simple, just ignore the 'net' side change as we fixed the same problem in 'net-next' by eliminating cached neighbours from ipv6 routes. The e1000e conflict is an addition of a new statistic in the ethtool code, trivial. The vmxnet3 conflict is about one change in 'net' removing a guarding conditional, whilst in 'net-next' we had a netdev_info() conversion. The iwlwifi conflict is dealing with a WARN_ON() conversion in 'net-next' vs. a revert happening in 'net'. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-04drivers: net: usb: Remove unnecessary alloc/OOM messagesJoe Perches
alloc failures already get standardized OOM messages and a dump_stack. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-04net: usbnet: fix tx_dropped statisticsBjørn Mork
It is normal for minidrivers accumulating frames to return NULL from their tx_fixup function. We do not want to count this as a drop, or log any debug messages. A different exit path is therefore chosen for such drivers, skipping the debug message and the tx_dropped increment. The test for accumulating drivers was however completely bogus, making the exit path selection depend on whether the user had enabled tx_err logging or not. This would arbitrarily mess up accounting for both accumulating and non-accumulating minidrivers, and would result in unwanted debug messages for the accumulating drivers. Fix by testing for FLAG_MULTI_PACKET instead, which probably was the intention from the beginning. This usage match the documented behaviour of this flag: Indicates to usbnet, that USB driver accumulates multiple IP packets. Affects statistic (counters) and short packet handling. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-30net: usbnet: prevent buggy devices from killing usBjørn Mork
A device sending 0 length frames as fast as it can has been observed killing the host system due to the resulting memory pressure. Temporarily disable RX skb allocation and URB submission when the current error ratio is high, preventing us from trying to allocate an infinite number of skbs. Reenable as soon as we are finished processing the done queue, allowing the device to continue working after short error bursts. Signed-off-by: Bjørn Mork <bjorn@mork.no> Acked-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-21usbnet: add new flag FLAG_NOARP for usb net devicesWei Shuai
We do have some USB net devices, which cannot do ARP. so we can introduce a new flag FLAG_NOARP, then client drivers can easily handle this kind of devices Signed-off-by: Wei Shuai <cpuwolf@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-19usbnet: generic manage_power()Oliver Neukum
Centralise common code for manage_power() in usbnet by making a generic simple implementation Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-19usbnet: handle PM failure gracefullyOliver Neukum
If a device fails to do remote wakeup, this is no reason to abort an open totally. This patch just continues without runtime PM. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c Minor conflict between the BCM_CNIC define removal in net-next and a bug fix added to net. Based upon a conflict resolution patch posted by Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-09usbnet: ratelimit kevent may have been dropped warningsSteve Glendinning
when something goes wrong, a flood of these messages can be generated by usbnet (thousands per second). This doesn't generally *help* the condition so this patch ratelimits the rate of their generation. There's an underlying problem in usbnet's kevent deferral mechanism which needs fixing, specifically that events *can* get dropped and not handled. This patch doesn't address this, but just mitigates fallout caused by the current implemention. Signed-off-by: Steve Glendinning <steve.glendinning@shawell.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-07usbnet: runtime wake up device before calling usbnet_{read|write}_cmdMing Lei
This patch gets the runtime PM reference count before calling usbnet_{read|write}_cmd, and puts it after completion of the usbnet_{read|write}_cmd, so that the usb control message can always be sent to one active device in the non-PM context. Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-07usbnet: introduce usbnet_{read|write}_cmd_nopmMing Lei
This patch introduces the below two helpers to prepare for solving the usbnet runtime PM problem, which may cause some network utilities (ifconfig, ethtool,...) touch a suspended device. usbnet_read_cmd_nopm() usbnet_write_cmd_nopm() The above two helpers should be called by usbnet resume/suspend callback to avoid deadlock. Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-26net: usb: Fix memory leak on Tx data pathHemant Kumar
Driver anchors the tx urbs and defers the urb submission if a transmit request comes when the interface is suspended. Anchoring urb increments the urb reference count. These deferred urbs are later accessed by calling usb_get_from_anchor() for submission during interface resume. usb_get_from_anchor() unanchors the urb but urb reference count remains same. This causes the urb reference count to remain non-zero after usb_free_urb() gets called and urb never gets freed. Hence call usb_put_urb() after anchoring the urb to properly balance the reference count for these deferred urbs. Also, unanchor these deferred urbs during disconnect, to free them up. Signed-off-by: Hemant Kumar <hemantk@codeaurora.org> Acked-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-26usbnet: introduce usbnet 3 command helpersMing Lei
This patch introduces the below 3 usb command helpers: usbnet_read_cmd / usbnet_write_cmd / usbnet_write_cmd_async so that each low level driver doesn't need to implement them by itself, and the dma buffer allocation for usb transfer and runtime PM things can be handled just in one place. Acked-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-11usbnet: Support devices reporting idlenessOliver Neukum
Some device types support a form of power management in which the device suggests to the host that the device may be suspended now. Support for that is best located in usbnet. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-03net: usbnet: fix softirq storm on suspendBjørn Mork
Suspending an open usbnet device results in constant rescheduling of usbnet_bh. commit 65841fd5 "usbnet: handle remote wakeup asap" refactored the usbnet_bh code to allow sharing the urb allocate and submit code with usbnet_resume. In this process, a test for, and immediate return on, ENOLINK from rx_submit was unintentionally dropped. The rx queue will not grow if rx_submit fails, making usbnet_bh reschedule itself. This results in a softirq storm if the error is persistent. rx_submit translates the usb_submit_urb error EHOSTUNREACH into ENOLINK, so this is an expected and persistent error for a suspended device. The old code tested for this condition and avoided rescheduling. Putting this test back. Cc: <stable@vger.kernel.org> # v3.5 Cc: Ming Lei <ming.lei@canonical.com> Cc: Oliver Neukum <oneukum@suse.de> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-31usbnet: fix deadlock in resumeOliver Neukum
A usbnet device can share a multifunction device with a storage device. If the storage device is autoresumed the usbnet devices also needs to be autoresumed. Allocating memory with GFP_KERNEL can deadlock in this case. This should go back into all kernels that have commit 65841fd5132c3941cdf5df09e70df3ed28323212 That is 3.5 Signed-off-by: Oliver Neukum <oneukum@suse.de> CC: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-16net: usb: Use eth_random_addrJoe Perches
Convert the existing uses of random_ether_addr to the new eth_random_addr. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/usb/qmi_wwan.c net/batman-adv/translation-table.c net/ipv6/route.c qmi_wwan.c resolution provided by Bjørn Mork. batman-adv conflict is dealing merely with the changes of global function names to have a proper subsystem prefix. ipv6's route.c conflict is merely two side-by-side additions of network namespace methods. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-22usbnet: handle remote wakeup asapMing Lei
If usbnet is resumed by remote wakeup, generally there are some packets comming to be handled, so allocate and submit rx URBs in usbnet_resume to avoid delays introduced by tasklet. Otherwise, usbnet may have been runtime suspended before the usbnet_bh is executed to schedule Rx URBs. Without the patch, usbnet can't recieve any packets from peer in runtime suspend state if runtime PM is enabled and autosuspend_delay is set as zero. Signed-off-by: Ming Lei <ming.lei@canonical.com> Acked-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-22usbnet: decrease suspend count if returning -EBUSY for runtime suspendMing Lei
This patch decreases dev->suspend_count in the -EBUSY failure path of usbnet_suspend. Without the change, the later runtime suspend will do nothing except for increasing dev->suspend_count. Signed-off-by: Ming Lei <ming.lei@canonical.com> Acked-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-22usbnet: clear OPEN flag in failure pathMing Lei
Without clearing OPEN flag in failure path, runtime or system resume may submit interrupt/rx URB and start tx queue mistakenly on a interface in DOWN state. Signed-off-by: Ming Lei <ming.lei@canonical.com> Acked-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-17usbnet: sanitise overlong driver information stringsPhil Sutter
As seen on smsc75xx, driver_info->description being longer than 32 characters messes up 'ethtool -i' output. Signed-off-by: Phil Sutter <phil.sutter@viprinet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-12usbnet: don't initialize transfer buffer before submit status URBtom.leiming@gmail.com
The line below in intr_complete isn't needed, memset(urb->transfer_buffer, 0, urb->transfer_buffer_length); so just remove it. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-12usbnet: remove declaration for intr_completetom.leiming@gmail.com
Remove declaration for intr_complete so that ctags may be happy to decrease duplicated symbols, also decrease one line code. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-12usbnet: remove usb_get/put_dev in .probe and .disconnecttom.leiming@gmail.com
usb_device is parent device of usb_interface in the view of driver model, so its reference count is always held during .probe/.disconnect of usb_interface instance. This patch just removes the unnecessay usb_get/put_dev. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-05-15usbnet: fix skb traversing races during unlink(v2)Ming Lei
Commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d(net/usbnet: avoid recursive locking in usbnet_stop()) fixes the recursive locking problem by releasing the skb queue lock before unlink, but may cause skb traversing races: - after URB is unlinked and the queue lock is released, the refered skb and skb->next may be moved to done queue, even be released - in skb_queue_walk_safe, the next skb is still obtained by next pointer of the last skb - so maybe trigger oops or other problems This patch extends the usage of entry->state to describe 'start_unlink' state, so always holding the queue(rx/tx) lock to change the state if the referd skb is in rx or tx queue because we need to know if the refered urb has been started unlinking in unlink_urbs. The other part of this patch is based on Huajun's patch: always traverse from head of the tx/rx queue to get skb which is to be unlinked but not been started unlinking. Signed-off-by: Huajun Li <huajun.li.lee@gmail.com> Signed-off-by: Ming Lei <tom.leiming@gmail.com> Cc: Oliver Neukum <oneukum@suse.de> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
