Centralise common code for manage_power() in usbnet
by making a generic simple implementation
Signed-off-by: Oliver Neukum <oneukum@suse.de>
If a device fails to do remote wakeup, this is no reason
to abort an open totally. This patch just continues without
runtime PM.
drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c
Minor conflict between the BCM_CNIC define removal in net-next
and a bug fix added to net. Based upon a conflict resolution
patch posted by Stephen Rothwell.
when something goes wrong, a flood of these messages can be
generated by usbnet (thousands per second). This doesn't
generally *help* the condition so this patch ratelimits the
rate of their generation.
There's an underlying problem in usbnet's kevent deferral
mechanism which needs fixing, specifically that events *can*
get dropped and not handled. This patch doesn't address this,
but just mitigates fallout caused by the current implemention.
Signed-off-by: Steve Glendinning <steve.glendinning@shawell.net>
This patch gets the runtime PM reference count before calling
usbnet_{read|write}_cmd, and puts it after completion of the
usbnet_{read|write}_cmd, so that the usb control message can always
be sent to one active device in the non-PM context.
Signed-off-by: Ming Lei <ming.lei@canonical.com>
This patch introduces the below two helpers to prepare for solving
the usbnet runtime PM problem, which may cause some network utilities
(ifconfig, ethtool,...) touch a suspended device.
usbnet_read_cmd_nopm()
usbnet_write_cmd_nopm()
The above two helpers should be called by usbnet resume/suspend
callback to avoid deadlock.
Driver anchors the tx urbs and defers the urb submission if
a transmit request comes when the interface is suspended.
Anchoring urb increments the urb reference count. These
deferred urbs are later accessed by calling usb_get_from_anchor()
for submission during interface resume. usb_get_from_anchor()
unanchors the urb but urb reference count remains same.
This causes the urb reference count to remain non-zero
after usb_free_urb() gets called and urb never gets freed.
Hence call usb_put_urb() after anchoring the urb to properly
balance the reference count for these deferred urbs. Also,
unanchor these deferred urbs during disconnect, to free them
up.
Signed-off-by: Hemant Kumar <hemantk@codeaurora.org>
Acked-by: Oliver Neukum <oneukum@suse.de>
This patch introduces the below 3 usb command helpers:
usbnet_read_cmd / usbnet_write_cmd / usbnet_write_cmd_async
so that each low level driver doesn't need to implement them
by itself, and the dma buffer allocation for usb transfer and
runtime PM things can be handled just in one place.
Some device types support a form of power management in which
the device suggests to the host that the device may be suspended
now. Support for that is best located in usbnet.
Suspending an open usbnet device results in constant
rescheduling of usbnet_bh.
commit 65841fd5 "usbnet: handle remote wakeup asap"
refactored the usbnet_bh code to allow sharing the
urb allocate and submit code with usbnet_resume. In
this process, a test for, and immediate return on,
ENOLINK from rx_submit was unintentionally dropped.
The rx queue will not grow if rx_submit fails,
making usbnet_bh reschedule itself. This results
in a softirq storm if the error is persistent.
rx_submit translates the usb_submit_urb error
EHOSTUNREACH into ENOLINK, so this is an expected
and persistent error for a suspended device. The
old code tested for this condition and avoided
rescheduling. Putting this test back.
Cc: <stable@vger.kernel.org> # v3.5
Cc: Ming Lei <ming.lei@canonical.com>
Cc: Oliver Neukum <oneukum@suse.de>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
A usbnet device can share a multifunction device
with a storage device. If the storage device is autoresumed
the usbnet devices also needs to be autoresumed. Allocating
memory with GFP_KERNEL can deadlock in this case.
This should go back into all kernels that have
commit 65841fd5132c3941cdf5df09e70df3ed28323212
That is 3.5
CC: stable@kernel.org
Convert the existing uses of random_ether_addr to
the new eth_random_addr.
drivers/net/usb/qmi_wwan.c
net/batman-adv/translation-table.c
net/ipv6/route.c
qmi_wwan.c resolution provided by Bjørn Mork.
batman-adv conflict is dealing merely with the changes
of global function names to have a proper subsystem
prefix.
ipv6's route.c conflict is merely two side-by-side additions
of network namespace methods.
If usbnet is resumed by remote wakeup, generally there are
some packets comming to be handled, so allocate and submit
rx URBs in usbnet_resume to avoid delays introduced by tasklet.
Otherwise, usbnet may have been runtime suspended before the
usbnet_bh is executed to schedule Rx URBs.
Without the patch, usbnet can't recieve any packets from peer
in runtime suspend state if runtime PM is enabled and
autosuspend_delay is set as zero.
This patch decreases dev->suspend_count in the -EBUSY failure path
of usbnet_suspend. Without the change, the later runtime suspend
will do nothing except for increasing dev->suspend_count.
Without clearing OPEN flag in failure path, runtime or system resume
may submit interrupt/rx URB and start tx queue mistakenly on a
interface in DOWN state.
As seen on smsc75xx, driver_info->description being longer than 32
characters messes up 'ethtool -i' output.
Signed-off-by: Phil Sutter <phil.sutter@viprinet.com>
The line below in intr_complete isn't needed,
memset(urb->transfer_buffer, 0, urb->transfer_buffer_length);
so just remove it.
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Remove declaration for intr_complete so that ctags may be happy to
decrease duplicated symbols, also decrease one line code.
usb_device is parent device of usb_interface in the view of driver
model, so its reference count is always held during .probe/.disconnect
of usb_interface instance.
This patch just removes the unnecessay usb_get/put_dev.
Commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d(net/usbnet: avoid
recursive locking in usbnet_stop()) fixes the recursive locking
problem by releasing the skb queue lock before unlink, but may
cause skb traversing races:
- after URB is unlinked and the queue lock is released,
the refered skb and skb->next may be moved to done queue,
even be released
- in skb_queue_walk_safe, the next skb is still obtained
by next pointer of the last skb
- so maybe trigger oops or other problems
This patch extends the usage of entry->state to describe 'start_unlink'
state, so always holding the queue(rx/tx) lock to change the state if
the referd skb is in rx or tx queue because we need to know if the
refered urb has been started unlinking in unlink_urbs.
The other part of this patch is based on Huajun's patch:
always traverse from head of the tx/rx queue to get skb which is
to be unlinked but not been started unlinking.
Signed-off-by: Huajun Li <huajun.li.lee@gmail.com>
Cc: stable@kernel.org
drivers/net/ethernet/intel/e1000e/param.c
drivers/net/wireless/iwlwifi/iwl-agn-rx.c
drivers/net/wireless/iwlwifi/iwl-trans-pcie-rx.c
drivers/net/wireless/iwlwifi/iwl-trans.h
Resolved the iwlwifi conflict with mainline using 3-way diff posted
by John Linville and Stephen Rothwell. In 'net' we added a bug
fix to make iwlwifi report a more accurate skb->truesize but this
conflicted with RX path changes that happened meanwhile in net-next.
In e1000e a conflict arose in the validation code for settings of
adapter->itr. 'net-next' had more sophisticated logic so that
logic was used.
If register_netdev returns failure, the dev->interrupt and
its transfer buffer should be released, so just fix it.
The transfer buffer of dev->interrupt is allocated in .probe path,
but not freed in .disconnet path, so mark the interrupt URB as
URB_FREE_BUFFER to free the buffer when the URB is destroyed.
Signed-off-by: Richard Cochran <richardcochran@gmail.com>
usbnet should centrally handle busy reporting in the rx path
so subdrivers need not worry. This hurts use cases which do
rx only or predominantly.
URB unlinking is always racing with its completion and tx_complete
may be called before or during running usb_unlink_urb, so tx_complete
must not clear urb->dev since it will be used in unlink path,
otherwise invalid memory accesses or usb device leak may be caused
inside usb_unlink_urb.
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Oliver Neukum <oliver@neukum.org>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
problem by releasing the skb queue lock, but it makes usb_unlink_urb
racing with defer_bh, and the URB to being unlinked may be freed before
or during calling usb_unlink_urb, so use-after-free problem may be
triggerd inside usb_unlink_urb.
The patch fixes the use-after-free problem by increasing URB
reference count with skb queue lock held before calling
usb_unlink_urb, so the URB won't be freed until return from
usb_unlink_urb.
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Reported-by: Dave Jones <davej@redhat.com>
If host is going to autosuspend function with two interfaces and
if IP packet has arrived in-between of two usbnet_suspend() callbacks,
i.e usbnet_resume() is called in-between, tx data flow is stopped.
When autosuspend timer expires and device is put to autosuspend
again, tx queue is waked up and data can be sent again.
This behavior might be repeated several times in a row.
Tested on Intel/ARM.
Reviewed-by: Sjur Brændeland <sjur.brandeland@stericsson.com>
Tested-by: Dmitry Tarnyagin <dmitry.tarnyagin@stericsson.com>
Signed-off-by: Alexey Orishko <alexey.orishko@stericsson.com>
network drivers should reserve some headroom on incoming skbs so that we
dont need expensive reallocations, eg forwarding packets in tunnels.
This NET_SKB_PAD padding is done in various helpers, like
__netdev_alloc_skb_ip_align() in this patch, combining NET_SKB_PAD and
NET_IP_ALIGN magic.
|kernel BUG at kernel/rtmutex.c:724!
|[<c029599c>] (rt_spin_lock_slowlock+0x108/0x2bc) from [<c01c2330>] (defer_bh+0x1c/0xb4)
|[<c01c2330>] (defer_bh+0x1c/0xb4) from [<c01c3afc>] (rx_complete+0x14c/0x194)
|[<c01c3afc>] (rx_complete+0x14c/0x194) from [<c01cac88>] (usb_hcd_giveback_urb+0xa0/0xf0)
|[<c01cac88>] (usb_hcd_giveback_urb+0xa0/0xf0) from [<c01e1ff4>] (musb_giveback+0x34/0x40)
|[<c01e1ff4>] (musb_giveback+0x34/0x40) from [<c01e2b1c>] (musb_advance_schedule+0xb4/0x1c0)
|[<c01e2b1c>] (musb_advance_schedule+0xb4/0x1c0) from [<c01e2ca8>] (musb_cleanup_urb.isra.9+0x80/0x8c)
|[<c01e2ca8>] (musb_cleanup_urb.isra.9+0x80/0x8c) from [<c01e2ed0>] (musb_urb_dequeue+0xec/0x108)
|[<c01e2ed0>] (musb_urb_dequeue+0xec/0x108) from [<c01cbb90>] (unlink1+0xbc/0xcc)
|[<c01cbb90>] (unlink1+0xbc/0xcc) from [<c01cc2ec>] (usb_hcd_unlink_urb+0x54/0xa8)
|[<c01cc2ec>] (usb_hcd_unlink_urb+0x54/0xa8) from [<c01c2a84>] (unlink_urbs.isra.17+0x2c/0x58)
|[<c01c2a84>] (unlink_urbs.isra.17+0x2c/0x58) from [<c01c2b44>] (usbnet_terminate_urbs+0x94/0x10c)
|[<c01c2b44>] (usbnet_terminate_urbs+0x94/0x10c) from [<c01c2d68>] (usbnet_stop+0x100/0x15c)
|[<c01c2d68>] (usbnet_stop+0x100/0x15c) from [<c020f718>] (__dev_close_many+0x94/0xc8)
defer_bh() takes the lock which is hold during unlink_urbs(). The safe
walk suggest that the skb will be removed from the list and this is done
by defer_bh() so it seems to be okay to drop the lock here.
Reported-by: AnÃbal Almeida Pinto <anibal.pinto@efacec.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Acked-by: Oliver Neukum <oliver@neukum.org>
alloc_etherdev has a generic OOM/unable to alloc message.
Remove the duplicative messages after alloc_etherdev calls.
This patch fixes the bug added in commit v3.1-rc7-1055-gf9b491e
SKB can be NULL at this point, at least for cdc-ncm.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Acked-by: Richard Cochran <richardcochran@gmail.com>
* 'pm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (63 commits)
PM / Clocks: Remove redundant NULL checks before kfree()
PM / Documentation: Update docs about suspend and CPU hotplug
ACPI / PM: Add Sony VGN-FW21E to nonvs blacklist.
ARM: mach-shmobile: sh7372 A4R support (v4)
ARM: mach-shmobile: sh7372 A3SP support (v4)
PM / Sleep: Mark devices involved in wakeup signaling during suspend
PM / Hibernate: Improve performance of LZO/plain hibernation, checksum image
PM / Hibernate: Do not initialize static and extern variables to 0
PM / Freezer: Make fake_signal_wake_up() wake TASK_KILLABLE tasks too
PM / Hibernate: Add resumedelay kernel param in addition to resumewait
MAINTAINERS: Update linux-pm list address
PM / ACPI: Blacklist Vaio VGN-FW520F machine known to require acpi_sleep=nonvs
PM / ACPI: Blacklist Sony Vaio known to require acpi_sleep=nonvs
PM / Hibernate: Add resumewait param to support MMC-like devices as resume file
PM / Hibernate: Fix typo in a kerneldoc comment
PM / Hibernate: Freeze kernel threads after preallocating memory
PM: Update the policy on default wakeup settings
PM / VT: Cleanup #if defined uglyness and fix compile error
PM / Suspend: Off by one in pm_suspend()
PM / Hibernate: Include storage keys in hibernation image on s390
In order to make USB-to-Ethernet-adapters (depending on usbnet) support
timestamping, the "skb_defer_rx_timestamp" and "skb_tx_timestamp" function
calls are added.
Signed-off-by: Michael Riesch <michael@riesch.at>
This patch (as1482) adds a macro for testing whether or not a
pm_message value represents an autosuspend or autoresume (i.e., a
runtime PM) event. Encapsulating this notion seems preferable to
open-coding the test all over the place.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
- kenrel -> kernel
- whetehr -> whether
- ttt -> tt
- sss -> ss
drivers/net/tg3.c
This patch makes use of the EVENT_DEV_OPEN flag introduced recently to
fix one out of memory issue, which can be reproduced on omap3/4 based
pandaboard/beagle XM easily with steps below:
- enable runtime pm
echo auto > /sys/devices/platform/usbhs-omap.0/ehci-omap.0/usb1/1-1/1-1.1/power/control
- ifconfig eth0 up
- then out of memroy happened, see [1] for kernel message.
Follows my analysis:
- 'ifconfig eth0 up' brings eth0 out of suspend, and usbnet_resume
is called to schedule dev->bh, then rx urbs are submited to prepare for
recieving data;
- some usbnet devices will produce garbage rx packets flood if
info->reset is not called in usbnet_open.
- so there is no enough chances for usbnet_bh to handle and release
recieved skb buffers since many rx interrupts consumes cpu, so out of memory
for atomic allocation in rx_submit happened.
This patch fixes the issue by simply not allowing schedule of usbnet_bh until device
is opened.
[1], dmesg
[ 234.712005] smsc95xx 1-1.1:1.0: rpm_resume flags 0x4
[ 234.712066] usb 1-1.1: rpm_resume flags 0x0
[ 234.712066] usb 1-1: rpm_resume flags 0x0
[ 234.712097] usb usb1: rpm_resume flags 0x0
[ 234.712127] usb usb1: usb auto-resume
[ 234.712158] ehci-omap ehci-omap.0: resume root hub
[ 234.754028] hub 1-0:1.0: hub_resume
[ 234.754821] hub 1-0:1.0: port 1: status 0507 change 0000
[ 234.756011] hub 1-0:1.0: state 7 ports 3 chg 0000 evt 0000
[ 234.756042] hub 1-0:1.0: rpm_resume flags 0x4
[ 234.756072] usb usb1: rpm_resume flags 0x0
[ 234.756164] usb usb1: rpm_resume returns 1
[ 234.756195] hub 1-0:1.0: rpm_resume returns 0
[ 234.756195] hub 1-0:1.0: rpm_suspend flags 0x4
[ 234.756225] hub 1-0:1.0: rpm_suspend returns 0
[ 234.756256] usb usb1: rpm_resume returns 0
[ 234.757141] usb 1-1: usb auto-resume
[ 234.793151] ehci-omap ehci-omap.0: GetStatus port:1 status 001005 0 ACK POWER sig=se0 PE CONNECT
[ 234.816558] usb 1-1: finish resume
[ 234.817871] hub 1-1:1.0: hub_resume
[ 234.818420] hub 1-1:1.0: port 1: status 0507 change 0000
[ 234.820495] ehci-omap ehci-omap.0: reused qh eec50220 schedule
[ 234.820495] usb 1-1: link qh256-0001/eec50220 start 1 [1/0 us]
[ 234.820587] usb 1-1: rpm_resume returns 0
[ 234.820800] hub 1-1:1.0: state 7 ports 5 chg 0000 evt 0000
[ 234.820800] hub 1-1:1.0: rpm_resume flags 0x4
[ 234.820831] hub 1-1:1.0: rpm_resume returns 0
[ 234.820861] hub 1-1:1.0: rpm_suspend flags 0x4
[ 234.820861] hub 1-1:1.0: rpm_suspend returns 0
[ 234.821777] usb 1-1.1: usb auto-resume
[ 234.868591] hub 1-1:1.0: state 7 ports 5 chg 0000 evt 0002
[ 234.868591] hub 1-1:1.0: rpm_resume flags 0x4
[ 234.868621] hub 1-1:1.0: rpm_resume returns 0
[ 234.868652] hub 1-1:1.0: rpm_suspend flags 0x4
[ 234.868652] hub 1-1:1.0: rpm_suspend returns 0
[ 234.879486] usb 1-1.1: finish resume
[ 234.880279] usb 1-1.1: rpm_resume returns 0
[ 234.880310] smsc95xx 1-1.1:1.0: rpm_resume returns 0
[ 238.880187] ksoftirqd/0: page allocation failure. order:0, mode:0x20
[ 238.880218] Backtrace:
[ 238.880249] [<c01b9800>] (dump_backtrace+0x0/0xf8) from [<c065e1dc>] (dump_stack+0x18/0x1c)
[ 238.880249] r6:00000000 r5:00000000 r4:00000020 r3:00000002
[ 238.880310] [<c065e1c4>] (dump_stack+0x0/0x1c) from [<c026ece4>] (__alloc_pages_nodemask+0x620/0x724)
[ 238.880340] [<c026e6c4>] (__alloc_pages_nodemask+0x0/0x724) from [<c02986d4>] (kmem_getpages.clone.34+0x34/0xc8)
[ 238.880371] [<c02986a0>] (kmem_getpages.clone.34+0x0/0xc8) from [<c02988f8>] (cache_grow.clone.42+0x84/0x154)
[ 238.880371] r6:ef871aa4 r5:ef871a80 r4:ef81fd40 r3:00000020
[ 238.880401] [<c0298874>] (cache_grow.clone.42+0x0/0x154) from [<c0298b64>] (cache_alloc_refill+0x19c/0x1f0)
[ 238.880432] [<c02989c8>] (cache_alloc_refill+0x0/0x1f0) from [<c0299804>] (kmem_cache_alloc+0x90/0x190)
[ 238.880462] [<c0299774>] (kmem_cache_alloc+0x0/0x190) from [<c052e260>] (__alloc_skb+0x34/0xe8)
[ 238.880493] [<c052e22c>] (__alloc_skb+0x0/0xe8) from [<bf0509f4>] (rx_submit+0x2c/0x1d4 [usbnet])
[ 238.880523] [<bf0509c8>] (rx_submit+0x0/0x1d4 [usbnet]) from [<bf050d38>] (rx_complete+0x19c/0x1b0 [usbnet])
[ 238.880737] [<bf050b9c>] (rx_complete+0x0/0x1b0 [usbnet]) from [<bf006fd0>] (usb_hcd_giveback_urb+0xa8/0xf4 [usbcore])
[ 238.880737] r8:eeeced34 r7:eeecec00 r6:eeecec00 r5:00000000 r4:eec2dd20
[ 238.880767] r3:bf050b9c
[ 238.880859] [<bf006f28>] (usb_hcd_giveback_urb+0x0/0xf4 [usbcore]) from [<bf03c8f8>] (ehci_urb_done+0xb0/0xbc [ehci_hcd])
[ 238.880859] r6:00000000 r5:eec2dd20 r4:eeeced44 r3:eec2dd34
[ 238.880920] [<bf03c848>] (ehci_urb_done+0x0/0xbc [ehci_hcd]) from [<bf040204>] (qh_completions+0x308/0x3bc [ehci_hcd])
[ 238.880920] r7:00000000 r6:eeda21a0 r5:ffdfe3c0 r4:eeda21ac
[ 238.880981] [<bf03fefc>] (qh_completions+0x0/0x3bc [ehci_hcd]) from [<bf040ef8>] (scan_async+0xb0/0x16c [ehci_hcd])
[ 238.881011] [<bf040e48>] (scan_async+0x0/0x16c [ehci_hcd]) from [<bf040fec>] (ehci_work+0x38/0x90 [ehci_hcd])
[ 238.881042] [<bf040fb4>] (ehci_work+0x0/0x90 [ehci_hcd]) from [<bf042940>] (ehci_irq+0x300/0x34c [ehci_hcd])
[ 238.881072] r4:eeeced34 r3:00000001
[ 238.881134] [<bf042640>] (ehci_irq+0x0/0x34c [ehci_hcd]) from [<bf006828>] (usb_hcd_irq+0x40/0xac [usbcore])
[ 238.881195] [<bf0067e8>] (usb_hcd_irq+0x0/0xac [usbcore]) from [<c0239764>] (handle_irq_event_percpu+0xb8/0x240)
[ 238.881225] r6:eec504e0 r5:0000006d r4:eec504e0 r3:bf0067e8
[ 238.881256] [<c02396ac>] (handle_irq_event_percpu+0x0/0x240) from [<c0239930>] (handle_irq_event+0x44/0x64)
[ 238.881256] [<c02398ec>] (handle_irq_event+0x0/0x64) from [<c023bbd0>] (handle_level_irq+0xe0/0x114)
[ 238.881286] r6:0000006d r5:c080c14c r4:c080c100 r3:00020000
[ 238.881317] [<c023baf0>] (handle_level_irq+0x0/0x114) from [<c01ab090>] (asm_do_IRQ+0x90/0xd0)
[ 238.881317] r5:00000000 r4:0000006d
[ 238.881347] [<c01ab000>] (asm_do_IRQ+0x0/0xd0) from [<c06624d0>] (__irq_svc+0x50/0x134)
[ 238.881378] Exception stack(0xef837e20 to 0xef837e68)
[ 238.881378] 7e20: 00000001 00185610 016cc000 c00490c0 eb380000 ef800540 00000020 00004ae0
[ 238.881408] 7e40: 00000020 bf0509f4 60000013 ef837e9c ef837e40 ef837e68 c0226f0c c0298ca0
[ 238.881408] 7e60: 20000013 ffffffff
[ 238.881408] r5:fa240100 r4:ffffffff
[ 238.881439] [<c0298bb8>] (__kmalloc_track_caller+0x0/0x1d0) from [<c052e284>] (__alloc_skb+0x58/0xe8)
[ 238.881469] [<c052e22c>] (__alloc_skb+0x0/0xe8) from [<bf0509f4>] (rx_submit+0x2c/0x1d4 [usbnet])
[ 238.881500] [<bf0509c8>] (rx_submit+0x0/0x1d4 [usbnet]) from [<bf0513d8>] (usbnet_bh+0x1b4/0x250 [usbnet])
[ 238.881530] [<bf051224>] (usbnet_bh+0x0/0x250 [usbnet]) from [<c01f912c>] (tasklet_action+0xb0/0x1f8)
[ 238.881530] r6:00000000 r5:ef9757f0 r4:ef9757ec r3:bf051224
[ 238.881561] [<c01f907c>] (tasklet_action+0x0/0x1f8) from [<c01f97ac>] (__do_softirq+0x140/0x290)
[ 238.881561] r8:00000006 r7:00000101 r6:00000000 r5:c0806098 r4:00000001
[ 238.881591] r3:c01f907c
[ 238.881622] [<c01f966c>] (__do_softirq+0x0/0x290) from [<c01f99cc>] (run_ksoftirqd+0xd0/0x1f4)
[ 238.881622] [<c01f98fc>] (run_ksoftirqd+0x0/0x1f4) from [<c02113b0>] (kthread+0x90/0x98)
[ 238.881652] r7:00000013 r6:c01f98fc r5:00000000 r4:ef831efc
[ 238.881683] [<c0211320>] (kthread+0x0/0x98) from [<c01f62f4>] (do_exit+0x0/0x374)
[ 238.881713] r6:c01f62f4 r5:c0211320 r4:ef831efc
[ 238.881713] Mem-info:
[ 238.881744] Normal per-cpu:
[ 238.881744] CPU 0: hi: 186, btch: 31 usd: 38
[ 238.881744] CPU 1: hi: 186, btch: 31 usd: 169
[ 238.881774] HighMem per-cpu:
[ 238.881774] CPU 0: hi: 90, btch: 15 usd: 66
[ 238.881774] CPU 1: hi: 90, btch: 15 usd: 86
[ 238.881805] active_anon:544 inactive_anon:71 isolated_anon:0
[ 238.881805] active_file:926 inactive_file:2538 isolated_file:0
[ 238.881805] unevictable:0 dirty:10 writeback:0 unstable:0
[ 238.881805] free:57782 slab_reclaimable:864 slab_unreclaimable:186898
[ 238.881805] mapped:632 shmem:144 pagetables:50 bounce:0
[ 238.881835] Normal free:1328kB min:3532kB low:4412kB high:5296kB active_anon:0kB inactive_anon:0kB active_file:880kB inactive_file:848kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:780288kB mlocked:0kB dirty:36kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:3456kB slab_unreclaimable:747592kB kernel_stack:392kB pagetables:200kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[ 238.881866] lowmem_reserve[]: 0 1904 1904
[ 238.881896] HighMem free:229800kB min:236kB low:508kB high:784kB active_anon:2176kB inactive_anon:284kB active_file:2824kB inactive_file:9304kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:243712kB mlocked:0kB dirty:4kB writeback:0kB mapped:2528kB shmem:576kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[ 238.881927] lowmem_reserve[]: 0 0 0
[ 238.881958] Normal: 0*4kB 4*8kB 6*16kB 0*32kB 1*64kB 1*128kB 0*256kB 2*512kB 0*1024kB 0*2048kB 0*4096kB = 1344kB
[ 238.882019] HighMem: 6*4kB 2*8kB 4*16kB 4*32kB 1*64kB 1*128kB 0*256kB 2*512kB 3*1024kB 0*2048kB 55*4096kB = 229800kB
[ 238.882080] 3610 total pagecache pages
[ 238.882080] 0 pages in swap cache
[ 238.882080] Swap cache stats: add 0, delete 0, find 0/0
[ 238.882110] Free swap = 0kB
[ 238.882110] Total swap = 0kB
[ 238.933776] 262144 pages of RAM
[ 238.933776] 58240 free pages
[ 238.933776] 10503 reserved pages
[ 238.933776] 187773 slab pages
[ 238.933807] 2475 pages shared
[ 238.933807] 0 pages swap cached
Resubmit interrupt URB if device is open. Use a flag set in
usbnet_open() to determine this state. Also kill and free
interrupt URB in usbnet_disconnect().
[Rebased off git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git]
Signed-off-by: Paul Stewart <pstew@chromium.org>
Signed-off-by: Thiago Farina <tfransosi@gmail.com>
The documentation for the USB ethernet devices suggests that
only some devices are supposed to use usb0 as the network interface
name instead of eth0. The logic used there, and documented in
Kconfig for CDC is that eth0 will be used when the mac address
is a globally assigned one, but usb0 is used for the locally
managed range that is typically used on point-to-point links.
Unfortunately, this has caused a lot of pain on the smsc95xx
device that is used on the popular pandaboard without an
EEPROM to store the MAC address, which causes the driver to
call random_ether_address().
Obviously, there should be a proper MAC addressed assigned to
the device, and discussions are ongoing about how to solve
this, but this patch at least makes sure that the default
interface naming gets a little saner and matches what the
user can expect based on the documentation, including for
new devices.
The approach taken here is to flag whether a device might be a
point-to-point link with the new FLAG_POINTTOPOINT setting in
the usbnet driver_info. A driver can set both FLAG_POINTTOPOINT
and FLAG_ETHER if it is not sure (e.g. cdc_ether), or just one
of the two. The usbnet framework only looks at the MAC address
for device naming if both flags are set, otherwise it trusts the
flag.
Signed-off-by: Arnd Bergmann <arnd.bergmann@linaro.org>
Tested-by: Andy Green <andy.green@linaro.org>
This adds a driver for the CDC Ethernet part of this modem. The
device's ID is blacklisted in cdc_ether.c and is white-listed in
this new driver because of the quirks needed to make it useful.
The modem's firmware exposes a CDC ACM port for modem control and a
CDC Ethernet port for network data. The descriptors look fine but
both ports actually are some sort of multiplexers requiring non-
standard headers added/removed from every packet or they get
ignored. All information is based on a usb traffic log from a
Windows machine.
On the Verizon 4G network I've seen speeds up to 1.1MB/s so far with
this driver, a speed-o-meter site reports 16.2Mbps/10.5Mbps.
Userspace scripts are required to talk to the CDC ACM port.
Signed-off-by: Andrzej Zaborowski <balrogg@gmail.com>
returns less than zero in kevent().
We'll leak the memory allocated to 'urb' in
drivers/net/usb/usbnet.c:kevent() when we 'goto fail_lowmem' and the 'urb'
variable goes out of scope while still completely unused.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
flush_scheduled_work() is on its way out. This patch contains simple
conversions to replace flush_scheduled_work() usage with direct
cancels and flushes.
Directly cancel the used works on driver detach and flush them in
other cases.
The conversions are mostly straight forward and the only dangers are,
* Forgetting to cancel/flush one or more used works.
* Cancelling when a work should be flushed (ie. the work must be
executed once scheduled whether the driver is detaching or not).
I've gone over the changes multiple times but it would be much
appreciated if you can review with the above points in mind.
Cc: Jay Cliburn <jcliburn@gmail.com>
Cc: Michael Chan <mchan@broadcom.com>
Cc: Divy Le Ray <divy@chelsio.com>
Cc: e1000-devel@lists.sourceforge.net
Cc: Vasanthy Kolluri <vkolluri@cisco.com>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Andrew Gallatin <gallatin@myri.com>
Cc: Francois Romieu <romieu@fr.zoreil.com>
Cc: Ramkrishna Vepa <ramkrishna.vepa@exar.com>
Cc: Matt Carlson <mcarlson@broadcom.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Shreyas Bhatewara <sbhatewara@vmware.com>
Cc: netdev@vger.kernel.org
Changes:
include/linux/usb/usbnet.h:
- a new flag to indicate driver's capability to accumulate IP packets in Tx
direction and extract several packets from single skb in Rx direction.
- the procedure of counting packets in usbnet was updated due to the
accumulating of IP packets in the driver
- no short packets are sent if indicated by the flag in driver_info
structure
