path: root/drivers/net/usb/catc.c
2013-01-06ethtool: fix drvinfo strings set in driversJiri Pirko
Use strlcpy where possible to ensure the string is \0 terminated. Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN and custom defines. Use snprintf instead of sprint. Remove unnecessary inits of ->fw_version Remove unnecessary inits of drvinfo struct. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-20USB: remove dbg() usage in USB networking driversGreg Kroah-Hartman
The dbg() USB macro is so old, it predates me. The USB networking drivers are the last hold-out using this macro, and we want to get rid of it, so replace the usage of it with the proper netdev_dbg() or dev_dbg() (depending on the context) calls. Some places we end up using a local variable for the debug call, so also convert the other existing dev_* calls to use it as well, to save tiny amounts of code space. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-18USB: Disable hub-initiated LPM for comms devices.Sarah Sharp
Hub-initiated LPM is not good for USB communications devices. Comms devices should be able to tell when their link can go into a lower power state, because they know when an incoming transmission is finished. Ideally, these devices would slam their links into a lower power state, using the device-initiated LPM, after finishing the last packet of their data transfer. If we enable the idle timeouts for the parent hubs to enable hub-initiated LPM, we will get a lot of useless LPM packets on the bus as the devices reject LPM transitions when they're in the middle of receiving data. Worse, some devices might blindly accept the hub-initiated LPM and power down their radios while they're in the middle of receiving a transmission. The Intel Windows folks are disabling hub-initiated LPM for all USB communications devices under a xHCI USB 3.0 host. In order to keep the Linux behavior as close as possible to Windows, we need to do the same in Linux. Set the disable_hub_initiated_lpm flag for for all USB communications drivers. I know there aren't currently any USB 3.0 devices that implement these class specifications, but we should be ready if they do. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Marcel Holtmann <marcel@holtmann.org> Cc: Gustavo Padovan <gustavo@padovan.org> Cc: Johan Hedberg <johan.hedberg@gmail.com> Cc: Hansjoerg Lipp <hjlipp@web.de> Cc: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Jan Dumon <j.dumon@option.com> Cc: Petko Manolov <petkan@users.sourceforge.net> Cc: Steve Glendinning <steve.glendinning@smsc.com> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Kalle Valo <kvalo@qca.qualcomm.com> Cc: "Luis R. Rodriguez" <mcgrof@qca.qualcomm.com> Cc: Jouni Malinen <jouni@qca.qualcomm.com> Cc: Vasanthakumar Thiagarajan <vthiagar@qca.qualcomm.com> Cc: Senthil Balasubramanian <senthilb@qca.qualcomm.com> Cc: Christian Lamparter <chunkeey@googlemail.com> Cc: Brett Rudley <brudley@broadcom.com> Cc: Roland Vossen <rvossen@broadcom.com> Cc: Arend van Spriel <arend@broadcom.com> Cc: "Franky (Zhenhui) Lin" <frankyl@broadcom.com> Cc: Kan Yan <kanyan@broadcom.com> Cc: Dan Williams <dcbw@redhat.com> Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Cc: Ivo van Doorn <IvDoorn@gmail.com> Cc: Gertjan van Wingerde <gwingerde@gmail.com> Cc: Helmut Schaa <helmut.schaa@googlemail.com> Cc: Herton Ronaldo Krzesinski <herton@canonical.com> Cc: Hin-Tak Leung <htl10@users.sourceforge.net> Cc: Larry Finger <Larry.Finger@lwfinger.net> Cc: Chaoming Li <chaoming_li@realsil.com.cn> Cc: Daniel Drake <dsd@gentoo.org> Cc: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
2012-04-25USB: catc.c: remove err() usageGreg Kroah-Hartman
err() was a very old USB-specific macro that I thought had gone away. This patch removes it from being used in the driver and uses dev_err() instead. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-11-18USB: convert drivers/net/* to use module_usb_driver()Greg Kroah-Hartman
This converts the drivers in drivers/net/* to use the module_usb_driver() macro which makes the code smaller and a bit simpler. Added bonus is that it removes some unneeded kernel log messages about drivers loading and/or unloading. Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Oliver Neukum <oliver@neukum.name> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Petko Manolov <petkan@users.sourceforge.net> Cc: Steve Glendinning <steve.glendinning@smsc.com> Cc: Christian Lamparter <chunkeey@googlemail.com> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Dan Williams <dcbw@redhat.com> Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Cc: Ivo van Doorn <IvDoorn@gmail.com> Cc: Gertjan van Wingerde <gwingerde@gmail.com> Cc: Helmut Schaa <helmut.schaa@googlemail.com> Cc: Herton Ronaldo Krzesinski <herton@canonical.com> Cc: Hin-Tak Leung <htl10@users.sourceforge.net> Cc: Larry Finger <Larry.Finger@lwfinger.net> Cc: Chaoming Li <chaoming_li@realsil.com.cn> Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: "David S. Miller" <davem@davemloft.net> Cc: Roel Kluin <roel.kluin@gmail.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Jiri Pirko <jpirko@redhat.com> Cc: Pavel Roskin <proski@gnu.org> Cc: Yoann DI-RUZZA <y.diruzza@lim.eu> Cc: George <george0505@realtek.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-17net: remove use of ndo_set_multicast_list in driversJiri Pirko
replace it by ndo_set_rx_mode Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-31drivers/net/usb/catc.c: Fix potential deadlock in catc_ctrl_run()Alexey Khoroshilov
catc_ctrl_run() calls usb_submit_urb() with GFP_KERNEL, while it is called from catc_ctrl_async() and catc_ctrl_done() with catc->ctrl_lock spinlock held. The patch replaces GFP_KERNEL with GFP_ATOMIC. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ethtool: cosmetic: Use ethtool ethtool_cmd_speed APIDavid Decotigny
This updates the network drivers so that they don't access the ethtool_cmd::speed field directly, but use ethtool_cmd_speed() instead. For most of the drivers, these changes are purely cosmetic and don't fix any problem, such as for those 1GbE/10GbE drivers that indirectly call their own ethtool get_settings()/mii_ethtool_gset(). The changes are meant to enforce code consistency and provide robustness with future larger throughputs, at the expense of a few CPU cycles for each ethtool operation. All drivers compiled with make allyesconfig ion x86_64 have been updated. Tested: make allyesconfig on x86_64 + e1000e/bnx2x work Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-18net/usb: convert to use netdev_for_each_mc_addrJiri Pirko
also removed needless checks in smsc95xx Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-29drivers/net/usb/catc.c: use %pM to shown MAC addressH Hartley Sweeten
Use the %pM kernel extension to display the MAC address. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02netdev: drivers should make ethtool_ops constStephen Hemminger
No need to put ethtool_ops in data, they should be const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01usbnet: convert to netdev_tx_tStephen Hemminger
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21usbnet: convert catc device to net_device_opsStephen Hemminger
2009-03-21usbnet: convert catc to internal net_device_statsStephen Hemminger
2008-12-18net: prepare usb net drivers for addition of status as a parameterOliver Neukum
USB is going to switch the signature of the callbacks to void callback(struct urb *urb, int status) This patch will ease the transition. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-17USB: remove info() macro from usb network driversGreg Kroah-Hartman
USB should not be having it's own printk macros, so remove info() and use the system-wide standard of dev_info() wherever possible. Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: remove warn() macro from usb net driversGreg Kroah-Hartman
USB should not be having it's own printk macros, so remove warn() and use the system-wide standard of dev_warn() wherever possible. In the few places that will not work out, use a basic printk(). Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-21misc drivers/net endianness noiseAl Viro
2007-07-10[NET]: Kill eth_copy_and_sum().David S. Miller
It hasn't "summed" anything in over 7 years, and it's just a straight mempcy ala skb_copy_to_linear_data() so just get rid of it. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-09Move USB network drivers to drivers/net/usb.Jeff Garzik
It is preferable to group drivers by usage (net, scsi, ATA, ...) than by bus. When reviewing drivers, the [PCI|USB|PCMCIA|...] maintainer is probably less qualified on networking issues than a networking maintainer. Also, from a practical standpoint, chips often appear on multiple buses, which is why we do not put drivers into drivers/pci/net. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
