In preparation to enabling -Wimplicit-fallthrough, mark switch cases
where we are expecting to fall through.
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
In preparation for unconditionally passing the struct timer_list pointer to
all timer callbacks, switch to using the new timer_setup() and from_timer()
to pass the timer pointer explicitly.
Cc: Woojung Huh <woojung.huh@microchip.com>
Cc: Microchip Linux Driver Support <UNGLinuxDriver@microchip.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Philippe Reynes <tremyfr@gmail.com>
Cc: Jarod Wilson <jarod@redhat.com>
Cc: Arvind Yadav <arvind.yadav.cs@gmail.com>
Cc: "Bjørn Mork" <bjorn@mork.no>
Cc: "Stefan Brüns" <stefan.bruens@rwth-aachen.de>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Greg Ungerer <gerg@linux-m68k.org>
Cc: linux-usb@vger.kernel.org
Cc: netdev@vger.kernel.org
Use setup_timer function instead of initializing timer with the
function and data fields.
Signed-off-by: Allen Pais <allen.lkml@gmail.com>
usb_device_id are not supposed to change at runtime. All functions
working with usb_device_id provided by <linux/usb.h> work with
const usb_device_id. So mark the non-const structs as const.
Fix checkpatch.pl error:
ERROR: space prohibited before open square bracket '['.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
The ethtool api {get|set}_settings is deprecated.
We move this driver to new api {get|set}_link_ksettings.
As I don't have the hardware, I'd be very pleased if
someone may test this patch.
Signed-off-by: Philippe Reynes <tremyfr@gmail.com>
Allocating USB buffers on the stack is not portable, and no longer
works on x86_64 (with VMAP_STACK enabled as per default).
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
With centralized MTU checking, there's nothing productive done by
eth_change_mtu that isn't already done in dev_set_mtu, so mark it as
deprecated and remove all usage of it in the kernel. All callers have been
audited for calls to alloc_etherdev* or ether_setup directly, which means
they all have a valid dev->min_mtu and dev->max_mtu. Now eth_change_mtu
prints out a netdev_warn about being deprecated, for the benefit of
out-of-tree drivers that might be utilizing it.
Of note, dvb_net.c actually had dev->mtu = 4096, while using
eth_change_mtu, meaning that if you ever tried changing it's mtu, you
couldn't set it above 1500 anymore. It's now getting dev->max_mtu also set
to 4096 to remedy that.
v2: fix up lantiq_etop, missed breakage due to drive not compiling on x86
CC: netdev@vger.kernel.org
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Replace all trans_start updates with netif_trans_update helper.
change was done via spatch:
struct net_device *d;
- d->trans_start = jiffies
+ netif_trans_update(d)
Compile tested only.
Cc: user-mode-linux-devel@lists.sourceforge.net
Cc: linux-xtensa@linux-xtensa.org
Cc: linux1394-devel@lists.sourceforge.net
Cc: linux-rdma@vger.kernel.org
Cc: MPT-FusionLinux.pdl@broadcom.com
Cc: linux-scsi@vger.kernel.org
Cc: linux-can@vger.kernel.org
Cc: linux-parisc@vger.kernel.org
Cc: linux-omap@vger.kernel.org
Cc: linux-hams@vger.kernel.org
Cc: linux-wireless@vger.kernel.org
Cc: linux-s390@vger.kernel.org
Cc: devel@driverdev.osuosl.org
Cc: b.a.t.m.a.n@lists.open-mesh.org
Cc: linux-bluetooth@vger.kernel.org
Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
Acked-by: Antonio Quartulli <a@unstable.cc>
Use the built-in function instead of memset.
net: get rid of SET_ETHTOOL_OPS
Dave Miller mentioned he'd like to see SET_ETHTOOL_OPS gone.
This does that.
Mostly done via coccinelle script:
struct ethtool_ops *ops;
struct net_device *dev;
- SET_ETHTOOL_OPS(dev, ops);
+ dev->ethtool_ops = ops;
Compile tested only, but I'd seriously wonder if this broke anything.
Suggested-by: Dave Miller <davem@davemloft.net>
Signed-off-by: Wilfried Klaebe <w-lkml@lebenslange-mailadresse.de>
Acked-by: Felipe Balbi <balbi@ti.com>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
This covers everything under drivers/net except for wireless, which
has been submitted separately.
Several files refer to an old address for the Free Software Foundation
in the file header comment. Resolve by replacing the address with
the URL <http://www.gnu.org/licenses/> so that we do not have to keep
updating the header comments anytime the address changes.
CC: Oliver Neukum <oliver@neukum.org>
CC: Steve Glendinning <steve.glendinning@shawell.net>
CC: Oliver Neukum <oneukum@suse.de>
Convert the memset/memcpy uses of 6 to ETH_ALEN
where appropriate.
Also convert some struct definitions and u8 array
declarations of [6] to ETH_ALEN.
Acked-by: Arend van Spriel <arend@broadcom.com>
Use strlcpy where possible to ensure the string is \0 terminated.
Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN
and custom defines.
Use snprintf instead of sprint.
Remove unnecessary inits of ->fw_version
Remove unnecessary inits of drvinfo struct.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
The dbg() USB macro is so old, it predates me. The USB networking drivers are
the last hold-out using this macro, and we want to get rid of it, so replace
the usage of it with the proper netdev_dbg() or dev_dbg() (depending on the
context) calls.
Some places we end up using a local variable for the debug call, so also
convert the other existing dev_* calls to use it as well, to save tiny amounts
of code space.
Hub-initiated LPM is not good for USB communications devices. Comms
devices should be able to tell when their link can go into a lower power
state, because they know when an incoming transmission is finished.
Ideally, these devices would slam their links into a lower power state,
using the device-initiated LPM, after finishing the last packet of their
data transfer.
If we enable the idle timeouts for the parent hubs to enable
hub-initiated LPM, we will get a lot of useless LPM packets on the bus
as the devices reject LPM transitions when they're in the middle of
receiving data. Worse, some devices might blindly accept the
hub-initiated LPM and power down their radios while they're in the
middle of receiving a transmission.
The Intel Windows folks are disabling hub-initiated LPM for all USB
communications devices under a xHCI USB 3.0 host. In order to keep
the Linux behavior as close as possible to Windows, we need to do the
same in Linux.
Set the disable_hub_initiated_lpm flag for for all USB communications
drivers. I know there aren't currently any USB 3.0 devices that
implement these class specifications, but we should be ready if they do.
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Cc: Hansjoerg Lipp <hjlipp@web.de>
Cc: Tilman Schmidt <tilman@imap.cc>
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Jan Dumon <j.dumon@option.com>
Cc: Petko Manolov <petkan@users.sourceforge.net>
Cc: Steve Glendinning <steve.glendinning@smsc.com>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: Kalle Valo <kvalo@qca.qualcomm.com>
Cc: "Luis R. Rodriguez" <mcgrof@qca.qualcomm.com>
Cc: Jouni Malinen <jouni@qca.qualcomm.com>
Cc: Vasanthakumar Thiagarajan <vthiagar@qca.qualcomm.com>
Cc: Senthil Balasubramanian <senthilb@qca.qualcomm.com>
Cc: Christian Lamparter <chunkeey@googlemail.com>
Cc: Brett Rudley <brudley@broadcom.com>
Cc: Roland Vossen <rvossen@broadcom.com>
Cc: Arend van Spriel <arend@broadcom.com>
Cc: "Franky (Zhenhui) Lin" <frankyl@broadcom.com>
Cc: Kan Yan <kanyan@broadcom.com>
Cc: Dan Williams <dcbw@redhat.com>
Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Cc: Ivo van Doorn <IvDoorn@gmail.com>
Cc: Gertjan van Wingerde <gwingerde@gmail.com>
Cc: Helmut Schaa <helmut.schaa@googlemail.com>
Cc: Herton Ronaldo Krzesinski <herton@canonical.com>
Cc: Hin-Tak Leung <htl10@users.sourceforge.net>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Chaoming Li <chaoming_li@realsil.com.cn>
Cc: Daniel Drake <dsd@gentoo.org>
Cc: Ulrich Kunitz <kune@deine-taler.de>
err() was a very old USB-specific macro that I thought had
gone away. This patch removes it from being used in the
driver and uses dev_err() instead.
This converts the drivers in drivers/net/* to use the
module_usb_driver() macro which makes the code smaller and a bit
simpler.
Added bonus is that it removes some unneeded kernel log messages about
drivers loading and/or unloading.
Cc: Wolfgang Grandegger <wg@grandegger.com>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Oliver Neukum <oliver@neukum.name>
Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi>
Cc: Roel Kluin <roel.kluin@gmail.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Jiri Pirko <jpirko@redhat.com>
Cc: Pavel Roskin <proski@gnu.org>
Cc: Yoann DI-RUZZA <y.diruzza@lim.eu>
Cc: George <george0505@realtek.com>
replace it by ndo_set_rx_mode
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
catc_ctrl_run() calls usb_submit_urb() with GFP_KERNEL, while it is called from
catc_ctrl_async() and catc_ctrl_done() with catc->ctrl_lock spinlock held.
The patch replaces GFP_KERNEL with GFP_ATOMIC.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
This updates the network drivers so that they don't access the
ethtool_cmd::speed field directly, but use ethtool_cmd_speed()
instead.
For most of the drivers, these changes are purely cosmetic and don't
fix any problem, such as for those 1GbE/10GbE drivers that indirectly
call their own ethtool get_settings()/mii_ethtool_gset(). The changes
are meant to enforce code consistency and provide robustness with
future larger throughputs, at the expense of a few CPU cycles for each
ethtool operation.
All drivers compiled with make allyesconfig ion x86_64 have been
updated.
Tested: make allyesconfig on x86_64 + e1000e/bnx2x work
Signed-off-by: David Decotigny <decot@google.com>
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
also removed needless checks in smsc95xx
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss
anything). Used spatch and did small tweaks and conding style changes when
it was suitable.
Jirka
Use the %pM kernel extension to display the MAC address.
Only files where David Miller is the primary git-signer.
wireless, wimax, ixgbe, etc are not modified.
Compile tested x86 allyesconfig only
Not all files compiled (not x86 compatible)
Added a few > 80 column lines, which I ignored.
Existing checkpatch complaints ignored.
No need to put ethtool_ops in data, they should be const.
This patch is the result of an automatic spatch transformation to convert
all ndo_start_xmit() return values of 0 to NETDEV_TX_OK.
Some occurences are missed by the automatic conversion, those will be
handled in a seperate patch.
USB is going to switch the signature of the callbacks to
void callback(struct urb *urb, int status)
This patch will ease the transition.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
The generic packet receive code takes care of setting
netdev->last_rx when necessary, for the sake of the
bonding ARP monitor.
Drivers need not do it any more.
Some cases had to be skipped over because the drivers
were making use of the ->last_rx value themselves.
USB should not be having it's own printk macros, so remove info() and
use the system-wide standard of dev_info() wherever possible.
Cc: Jeff Garzik <jgarzik@pobox.com>
USB should not be having it's own printk macros, so remove warn() and
use the system-wide standard of dev_warn() wherever possible. In the
few places that will not work out, use a basic printk().
It hasn't "summed" anything in over 7 years, and it's
just a straight mempcy ala skb_copy_to_linear_data()
so just get rid of it.
It is preferable to group drivers by usage (net, scsi, ATA, ...) than
by bus. When reviewing drivers, the [PCI|USB|PCMCIA|...] maintainer
is probably less qualified on networking issues than a networking
maintainer. Also, from a practical standpoint, chips often
appear on multiple buses, which is why we do not put drivers into
drivers/pci/net.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
