path: root/drivers/net/usb/Kconfig
2011-09-15MII: fix Kconfig dependencies for MIIJeff Kirsher
MII Kconfig option is apart of the core networking drivers and by default NET_CORE is enabled so drivers selecting MII will have MII enabled as well. It was found using the randconfig option during testing, MII would be selected but NET_CORE could be disabled. This caused a dependency error. Resolved the dependency by selecting NET_CORE when MII is selected. Reported-by: Emil Tantilov <emil.s.tantilov@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-16net/usb: Add Samsung Kalmia driver for Samsung GT-B3730Marius B. Kotsbak
Introducing driver for the network port of Samsung Kalmia based USB LTE modems. It has also an ACM interface that previous patches associates with the "option" module. To access those interfaces, the modem must first be switched from modem mode using a tool like usb_modeswitch. As the proprietary protocol has been discovered by watching the MS Windows driver behavior, there might be errors in the protocol handling, but stable and fast connection has been established for hours with Norwegian operator NetCom that distributes this modem with their LTE/4G subscription. More and updated information about how to use this driver is available here: http://www.draisberghof.de/usb_modeswitch/bb/viewtopic.php?t=465 https://github.com/mkotsbak/Samsung-GT-B3730-linux-driver Signed-off-by: Marius B. Kotsbak <marius@kotsbak.com> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-04-10usb: plusb: Add support for PL-25A1simon
This patch adds support for the PL-25A1 by adding the appropriate USB ID's. This chip is used in the Belkin 'Windows Easy Transfer' Cables. Signed-off-by: Simon Wood <simon@mungewell.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-30net/usb: Ethernet quirks for the LG-VL600 4G modemAndrzej Zaborowski
This adds a driver for the CDC Ethernet part of this modem. The device's ID is blacklisted in cdc_ether.c and is white-listed in this new driver because of the quirks needed to make it useful. The modem's firmware exposes a CDC ACM port for modem control and a CDC Ethernet port for network data. The descriptors look fine but both ports actually are some sort of multiplexers requiring non- standard headers added/removed from every packet or they get ignored. All information is based on a usb traffic log from a Windows machine. On the Verizon 4G network I've seen speeds up to 1.1MB/s so far with this driver, a speed-o-meter site reports 16.2Mbps/10.5Mbps. Userspace scripts are required to talk to the CDC ACM port. Signed-off-by: Andrzej Zaborowski <balrogg@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-06USB CDC NCM host driverAlexey Orishko
The patch provides USB CDC NCM host driver support in the Linux Kernel. Changes: drivers/net/usb/cdc_ncm.c: - initial submission of the CDC NCM host driver; - verified on Intel 32/64 bit, Intel Atom, ST-Ericsson U8500 (ARM) - throughput measured over 100 Mbits duplex; - driver supports 16-bit NTB format only, but it is more than enough for transfers up to 64K; - driver can handle up to 32 datagrams in received NTB; - timer is used to collect several packets in Tx direction drivers/net/usb/Kconfig: - a new entry to compile CDC NCM host driver drivers/net/usb/Makefile: - a new entry to compile CDC NCM host driver Signed-off-by: Alexey Orishko <alexey.orishko@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-08introduce cx82310_eth: Conexant CX82310-based ADSL router USB ethernet driverOndrej Zary
This patch introduces cx82310_eth driver - driver for USB ethernet port of ADSL routers based on Conexant CX82310 chips. Such routers usually have ethernet port(s) too which are bridged together with the USB ethernet port, allowing the USB-connected machine to communicate to the network (and also internet through the ADSL, of course). This is my first driver, so please check thoroughly. As there's no protocol documentation, it was done with usbsnoop dumps from Windows driver, some parts (the commands) inspired by cxacru driver and also other usbnet drivers. The driver passed my testing - some real work and also pings sized from 0 to 65507 B. The only problem I found is the ifconfig error counter. When I return 0 (or 1 but empty skb) from rx_fixup(), usbnet increases the error counter although it's not an error condition (because packets can cross URB boundaries). Maybe the usbnet should be fixed to allow rx_fixup() to return empty skbs (or some other value, e.g. 2)? The USB ID of my device is 0x0572:0xcb01 which conflicts with some ADSL modems using cxacru driver (they probably use the same chipset but simpler firmware). The modems seem to use bDeviceClass 0 and iProduct "ADSL USB MODEM", my router uses bDeviceClass 255 and iProduct "USB NET CARD". The driver matches only devices with class 255 and checks for the iProduct string during init. I already posted a patch for the cxacru driver to ignore these devices. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-30net/usb: remove default in Kconfig for sierra_net driverElina Pasheva
The following patch removes the default from the Kconfig entry for sierra_net driver as recommended. Signed-off-by: Elina Pasheva <epasheva@sierrawireless.com> Signed-off-by: Rory Filer <rfiler@sierrawireless.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27net/usb: add sierra_net.c driverElina Pasheva
Re-submitted based on comments from netdev community. Summary of the changes: 1. Improved error handling. 2. Added the missing timeout arguments to usb_control_msg(). The following is a new Linux driver which exposes certain models of Sierra Wireless modems to the operating system as Network Interface Cards (NICs). This driver requires a version of the sierra.c driver which supports blacklisting to work properly. The blacklist in sierra.c rejects the interfaces claimed by sierra_net.c. Likewise, the sierra_net.c driver only accepts (i.e. whitelists) the interface(s) used for USB-to-WWAN traffic. The version of sierra.c which supports blacklisting is available from the sierra wireless knowledge base page for older kernels. It is also available in Linux kernel starting from version 2.6.31. This driver works with all Sierra Wireless devices configured with PID=68A3 like USB305, USB306 provided the corresponding firmware version is I2.0 (for USB305) or M3.0 (for USB306) and later. This driver will not work with earlier firmware versions than the ones shown above. In this case the driver will issue an error message indicating incompatibility and will not serve the device's USB-to-WWAN interface. Sierra_net.c sits atop a pre-existing Linux driver called usbnet.c. A series of hook functions are provided in sierra_net.c which are called by usbnet.c in response to a particular condition such as receipt or transmission of a data packet. As such, usbnet.c does most of the work of making a modem appear to the system as a network device and for properly exchanging traffic between the USB subsystem and the Network card interface. Sierra_net.c is concerned with managing the data exchanged between the USB-to-WWAN interface and the upper layers of the operating system. Signed-off-by: Elina Pasheva <epasheva@sierrawireless.com> Signed-off-by: Rory Filer <rfiler@sierrawireless.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21drivers/net/usb: Add new driver iphethDiego Giagio
Add new driver to use tethering with an iPhone device. After initial submission, apply fixes to fit the new driver into the kernel standards. There are still a couple of minor (almost cosmetic-level) issues, but the driver is fully functional right now. Signed-off-by: L. Alberto Giménez <agimenez@sysvalve.es> Signed-off-by: Diego Giagio <diego@giagio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16smsc75xx: SMSC LAN75xx USB gigabit ethernet adapter driverSteve Glendinning
This patch adds a driver for SMSC's LAN7500 family of USB 2.0 to gigabit ethernet adapters. It's loosely based on the smsc95xx driver but the device registers for LAN7500 are completely different. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04cdc_ether: additional Ericsson MBM PID's to the whitelistTorgny Johansson
Signed-off-by: Torgny Johansson <torgny.johansson@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-21USB host CDC Phonet network interface driverRémi Denis-Courmont
Many Nokia handsets support a Phonet interface to the cellular modem via a vendor-specific USB interface. CDC Phonet follows the Communications Device Class model, with one control interface, and and a pair of inactive and active data alternative interface. The later has two bulk endpoint, one per direction. This was tested against Nokia E61, Nokia N95, and the existing Phonet gadget function for the Linux composite USB gadget framework. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-19cdc_ether: additional PID's to the whitelistJonas Sjöquist
This patch adds five PID's to the whitelist set of devices. Devices added to the whitelist: Dell Wireless 5530 HSPA Ericsson Mobile Broadband Module variants (F3507g, F3607gw and F3307) Toshiba F3507g Signed-off-by: Jonas Sjöquist <jonas.sjoquist@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: include/net/tcp.h
2009-05-04usbnet: CDC EEM support (v5)Omar Laazimani
This introduces a CDC Ethernet Emulation Model (EEM) host side driver to support USB EEM devices. EEM is different from the Ethernet Control Model (ECM) currently supported by the "CDC Ethernet" driver. One key difference is that it doesn't require of USB interface alternate settings to manage interface state; some maldesigned hardware can't handle that part of USB. It also avoids a separate USB interface for control and status updates. [ dbrownell@users.sourceforge.net: fix skb leaks, add rx packet checks, improve fault handling, EEM conformance updates, cleanup ] Signed-off-by: Omar Laazimani <omar.oberthur@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-21usb driver for intellon int51x1 based PLC like devolo dlan duoPeter Holik
usb driver for intellon int51x1 based PLC like devolo dlan duo with improvements suggested by the guys of the mailinglist: - name and prefix with int51x1 (Florian Fainelli) - use conversion functions cpu_to_le16 / le16_to_cpu (Oliver Neukum) - use pskb_may_pull instead of skb->len (Ilpo Järvinen) - better code in tx_fixup (Ilpo Järvinen) - use gotos for error handling (Ilpo Järvinen) - better description (Jon Smirl) Signed-off-by: Peter Holik <peter@holik.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08net: Add SMSC LAN9500 USB2.0 10/100 ethernet adapter driverSteve Glendinning
Attached is a driver for SMSC's LAN9500 USB2.0 10/100 ethernet adapter. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-14Kconfig: HSO driver bugfixes and updatesDavid Brownell
Move the Kconfig for the new "Option" driver so it's not in the middle of the usbnet-based drivers, so the dependency displays in the Kconfig user interfaces don't get trashed. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-11HSO: add option hso driverGreg Kroah-Hartman
This driver is for a number of different Option devices. Originally written by Option and Andrew Bird, but cleaned up massivly for acceptance into mainline by me and others. Many thanks to the following for their help in cleaning up the driver by providing feedback and patches to it: - Paulius Zaleckas <paulius.zaleckas@teltonika.lt> - Oliver Neukum <oliver@neukum.org> - Alan Cox <alan@lxorguk.ukuu.org.uk> - Javier Marcet <javier@krausbeck.org> Cc: Andrew Bird <ajb@spheresystems.co.uk> Cc: Javier Marcet <javier@krausbeck.org> Cc: Filip Aben <f.aben@option.com> Cc: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Cc: Oliver Neukum <oliver@neukum.org> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-03-28usb net: asix does not really need 10/100mbitMike Frysinger
The asix usb driver currently depends on NET_ETHERNET which means you cannot enable this driver if you only have 1000mbit enabled in your kernel. Since there is no real dependency between the NET_ETHERNET portion and the asix driver, simply drop it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Greg KH <greg@kroah.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-07[NET]: Let USB_USBNET always select MII.Adrian Bunk
All this USB_USBNET_MII trickery is simply not worth it considering how few code it saves. As a side effect, this also fixes the following compile error reported by Toralf Förster: <-- snip --> ... LD .tmp_vmlinux1 drivers/built-in.o: In function `usbnet_set_settings': (.text+0xf1876): undefined reference to `mii_ethtool_sset' drivers/built-in.o: In function `usbnet_get_settings': (.text+0xf1836): undefined reference to `mii_ethtool_gset' drivers/built-in.o: In function `usbnet_get_link': (.text+0xf18d6): undefined reference to `mii_link_ok' drivers/built-in.o: In function `usbnet_nway_reset': (.text+0xf18f6): undefined reference to `mii_nway_restart' make: *** [.tmp_vmlinux1] Error 1 <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-20file link fix for Pegasus USB net driver helpCal Peake
Update the file link in the Pegasus USB network driver's help text. Signed-off-by: Cal Peake <cp@absolutedigital.net> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-06-09net: fix typo in drivers/net/usb/KconfigSam Ravnborg
Replace invisible character with a space. The diff looks like this on my terminal: - <A0>Choose this option if you're using a host-to-host cable - <A0>with one of these chips. + Choose this option if you're using a host-to-host cable + with one of these chips. Reported by: Massimo Maiurana <maiurana@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Massimo Maiurana <maiurana@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-09Move USB network drivers to drivers/net/usb.Jeff Garzik
It is preferable to group drivers by usage (net, scsi, ATA, ...) than by bus. When reviewing drivers, the [PCI|USB|PCMCIA|...] maintainer is probably less qualified on networking issues than a networking maintainer. Also, from a practical standpoint, chips often appear on multiple buses, which is why we do not put drivers into drivers/pci/net. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
