path: root/drivers/net/tulip/timer.c
2010-01-31tulip/timer.c: Use dev_<level> and pr_<level>Joe Perches
Convert printks to dev_<level> where a dev is available Convert printks to pr_<level> where not Coalesce format strings Change print formats with %d.dx to %0dx Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-24drivers/net/tulip: update first comment in tulip filesGrant Grundler
Three basic changes to the comments at the top of each file: 1) remove stale "Maintained by" line...I prefer people look in MAINTAINERS. 2) Drop reference to stale sf.net/tulip website (I didn't see anything of value there) 3) Point people at bugzilla.kernel.org to submit bugs...will always get tracked regardless of who the maintainer is. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Acked-by-stale-maintainer: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-05-02PCI: Cleanup the includes of <linux/pci.h>Jean Delvare
I noticed that many source files include <linux/pci.h> while they do not appear to need it. Here is an attempt to clean it all up. In order to find all possibly affected files, I searched for all files including <linux/pci.h> but without any other occurence of "pci" or "PCI". I removed the include statement from all of these, then I compiled an allmodconfig kernel on both i386 and x86_64 and fixed the false positives manually. My tests covered 66% of the affected files, so there could be false positives remaining. Untested files are: arch/alpha/kernel/err_common.c arch/alpha/kernel/err_ev6.c arch/alpha/kernel/err_ev7.c arch/ia64/sn/kernel/huberror.c arch/ia64/sn/kernel/xpnet.c arch/m68knommu/kernel/dma.c arch/mips/lib/iomap.c arch/powerpc/platforms/pseries/ras.c arch/ppc/8260_io/enet.c arch/ppc/8260_io/fcc_enet.c arch/ppc/8xx_io/enet.c arch/ppc/syslib/ppc4xx_sgdma.c arch/sh64/mach-cayman/iomap.c arch/xtensa/kernel/xtensa_ksyms.c arch/xtensa/platform-iss/setup.c drivers/i2c/busses/i2c-at91.c drivers/i2c/busses/i2c-mpc.c drivers/media/video/saa711x.c drivers/misc/hdpuftrs/hdpu_cpustate.c drivers/misc/hdpuftrs/hdpu_nexus.c drivers/net/au1000_eth.c drivers/net/fec_8xx/fec_main.c drivers/net/fec_8xx/fec_mii.c drivers/net/fs_enet/fs_enet-main.c drivers/net/fs_enet/mac-fcc.c drivers/net/fs_enet/mac-fec.c drivers/net/fs_enet/mac-scc.c drivers/net/fs_enet/mii-bitbang.c drivers/net/fs_enet/mii-fec.c drivers/net/ibm_emac/ibm_emac_core.c drivers/net/lasi_82596.c drivers/parisc/hppb.c drivers/sbus/sbus.c drivers/video/g364fb.c drivers/video/platinumfb.c drivers/video/stifb.c drivers/video/valkyriefb.c include/asm-arm/arch-ixp4xx/dma.h sound/oss/au1550_ac97.c I would welcome test reports for these files. I am fine with removing the untested files from the patch if the general opinion is that these changes aren't safe. The tested part would still be nice to have. Note that this patch depends on another header fixup patch I submitted to LKML yesterday: [PATCH] scatterlist.h needs types.h http://lkml.org/lkml/2007/3/01/141 Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-09-11[PATCH] Defer tulip_select_media() to process contextFrancois Romieu
Move tulip_select_media() processing to a workqueue, instead of delaying in interrupt context, edited by Kyle McMartin to use kevent thread, instead of creating its own workqueue. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Valerie Henson <val_henson@linux.intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-11[PATCH] Change tulip maintainerValerie Henson
Signed-off-by: Valerie Henson <val_henson@linux.intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> MAINTAINERS | 4 ++-- drivers/net/tulip/21142.c | 2 +- drivers/net/tulip/eeprom.c | 2 +- drivers/net/tulip/interrupt.c | 2 +- drivers/net/tulip/media.c | 2 +- drivers/net/tulip/pnic.c | 2 +- drivers/net/tulip/pnic2.c | 2 +- drivers/net/tulip/timer.c | 2 +- drivers/net/tulip/tulip_core.c | 2 +- 9 files changed, 10 insertions(+), 10 deletions(-)
2005-08-11[netdrvr tulip] Remove ULi-specific code from generic tulip driverPeer Chen
It has a separate driver now, 'uli526x'.
