path: root/drivers/net/tulip/eeprom.c
2010-06-01drivers/net/tulip/eeprom.c: Remove unnecessary kmalloc castsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-13drivers/net/tulip/eeprom.c: fix bogus "(null)" in tulip init messagesJoe Perches
On Wed, 2010-03-10 at 08:41 -0800, David Miller wrote: > From: Mikael Pettersson <mikpe@it.uu.se> > Date: Wed, 10 Mar 2010 16:33:28 +0100 > > Booting 2.6.34-rc1 on a machine with a tulip nic I see > > a number of kernel messages that include "(null)" where > > previous kernels included the string "tulip0": > CC:'ing the guilty party :-) It's one of the following > commits: Thanks Mikael. Anonymity has some good attributes. Blame avoidance is one of them. I've broad shoulders. It's me, then Dwight Howard... There might be another few of these where ->name or ->dev was used before struct device or net_device was registered. I'll go back and check. tulip_core has: if (tp->flags & HAS_MEDIA_TABLE) { sprintf(dev->name, DRV_NAME "%d", board_idx); /* hack */ tulip_parse_eeprom(dev); strcpy(dev->name, "eth%d"); /* un-hack */ } So I don't feel _too_ bad. tulip_parse_eeprom is done before register_netdev so the logging there can not use netdev_<level> or dev_<level>(&dev->dev Signed-off-by: Joe Perches <joe@perches.com> Tested-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-31tulip/eeprom.c: Use dev_<level> and pr_<level>Joe Perches
Convert printks to dev_<level> where a dev is available Convert printks to pr_<level> where not Coalesce format strings Change print formats with %d.dx to %0dx Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12netdevice: safe convert to netdev_priv() #part-3Wang Chen
We have some reasons to kill netdev->priv: 1. netdev->priv is equal to netdev_priv(). 2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously netdev_priv() is more flexible than netdev->priv. But we cann't kill netdev->priv, because so many drivers reference to it directly. This patch is a safe convert for netdev->priv to netdev_priv(netdev). Since all of the netdev->priv is only for read. But it is too big to be sent in one mail. I split it to 4 parts and make every part smaller than 100,000 bytes, which is max size allowed by vger. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-24drivers/net/tulip: update first comment in tulip filesGrant Grundler
Three basic changes to the comments at the top of each file: 1) remove stale "Maintained by" line...I prefer people look in MAINTAINERS. 2) Drop reference to stale sf.net/tulip website (I didn't see anything of value there) 3) Point people at bugzilla.kernel.org to submit bugs...will always get tracked regardless of who the maintainer is. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Acked-by-stale-maintainer: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-03-28[netdrvr] tulip_read_eeprom fixes for BUG 4420Grant Grundler
If "location" is > "addr_len" bits, the high bits of location would interfere with the READ_CMD sent to the eeprom controller. A patch was submitted to bug: http://bugzilla.kernel.org/show_bug.cgi?id=4420 which simply truncated the "location", read whatever was in "location modulo addr_len", and returned that value. That avoids confusing the eeprom but seems like the wrong solution to me. Correct would be to not read beyond "1 << addr_len" address of the eeprom. I am submitting two changes to implement this: 1) tulip_read_eeprom will return zero (since we can't return -EINVAL) if this is attempted (defensive programming). 2) In tulip_core.c, fix the tulip_read_eeprom caller so they don't iterate past addr_len bits and make sure the entire tp->eeprom[] array is cleared. I konw we don't strictly need both. I would prefer both in the tree since it documents the issue and provides a second "defense" from the bug from creeping back in. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-11[PATCH] Change tulip maintainerValerie Henson
Signed-off-by: Valerie Henson <val_henson@linux.intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> MAINTAINERS | 4 ++-- drivers/net/tulip/21142.c | 2 +- drivers/net/tulip/eeprom.c | 2 +- drivers/net/tulip/interrupt.c | 2 +- drivers/net/tulip/media.c | 2 +- drivers/net/tulip/pnic.c | 2 +- drivers/net/tulip/pnic2.c | 2 +- drivers/net/tulip/timer.c | 2 +- drivers/net/tulip/tulip_core.c | 2 +- 9 files changed, 10 insertions(+), 10 deletions(-)
2006-05-26[netdrvr] trim trailing whitespace: 8139*.c, epic100, forcedeth, tulip/*Jeff Garzik
2005-06-26Tulip fixes for Cobalt Qube/RaQRalf Baechle
