path: root/drivers/net/tokenring
2006-12-04[PATCH] remote memory corruptor in ibmtr.cAl Viro
ip_summed changes last summer had missed that one. As the result, we have ip_summed interpreted as CHECKSUM_PARTIAL now. IOW, ->csum is interpreted as offset of checksum in the packet. net/core/* will both read and modify the value as that offset, with obvious reasons. At the very least it's a remote memory corruptor. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-02[PATCH] pci_module_init() convertion in olympic.cHenrik Kretzschmar
pci_module_init() convertion in olympic.c Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-10-31[PATCH] tokenring: fix module_init error handlingAkinobu Mita
- Call platform_driver_unregister() before return when no cards found. (fixes data corruption when no cards found) - Check platform_device_register_simple() return value Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Mike Phillips <mikep@linuxtr.net> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> drivers/net/tokenring/proteon.c | 9 +++++++-- drivers/net/tokenring/skisa.c | 9 +++++++-- 2 files changed, 14 insertions(+), 4 deletions(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-10-06drivers/net: eliminate irq handler impossible checks, needless castsJeff Garzik
- Eliminate check for irq handler 'dev_id==NULL' where the condition never occurs. - Eliminate needless casts to/from void* Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-03BUG_ON cleanup in drivers/net/tokenring/Eric Sesterhenn
This patch converts one if() BUG(); to BUG_ON(); so it can be safely optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-25[PATCH] drivers/net/tokenring/lanstreamer.h Removal of old codeMichal Piotrowski
Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-25[PATCH] drivers/net/tokenring/lanstreamer.c Removal of old codeMichal Piotrowski
2006-08-19drivers/net: Remove deprecated use of pci_module_init()Jeff Garzik
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-19[PATCH] smctr section fixAndrew Morton
WARNING: drivers/net/tokenring/smctr.o - Section mismatch: reference to .init.text: from .text between 'init_module' (at offset 0x2ba0) and 'smctr_reset_adapter' WARNING: drivers/net/tokenring/smctr.o - Section mismatch: reference to .init.text:smctr_probe from .text between 'init_module' (at offset 0x2bf4) and 'smctr_reset_adapter' Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-19[PATCH] ibmtr section fixAndrew Morton
WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.data:ibmtr_mem_base from .text between 'ibmtr_probe1' (at offset 0x6e6) and 'ibmtr_probe_card' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.data:ibmtr_mem_base from .text between 'ibmtr_probe1' (at offset 0x74a) and 'ibmtr_probe_card' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.data:ibmtr_mem_base from .text between 'ibmtr_probe1' (at offset 0x7fd) and 'ibmtr_probe_card' Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[PATCH] Dereference in tokenring/olympic.cEric Sesterhenn
hi, coverity found (bug id #225) that we might call free_netdev() with NULL argument, when alloc_trdev() fails. This patch changes the goto, so we dont call free_netdev() for dev == NULL. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-02BUG_ON() Conversion in drivers/net/Eric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-31[PATCH] uml: kconfigsAl Viro
kconfig sanitized around drivers/net Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-17Merge branch 'upstream-fixes'Jeff Garzik
2006-02-17[PATCH] smctr warning fixAndrew Morton
drivers/net/tokenring/smctr.c: In function `smctr_load_firmware': drivers/net/tokenring/smctr.c:2981: warning: assignment discards qualifiers from pointer target type Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2006-01-17[PATCH] drivers/net/*: use time_after() and friendsMarcelo Feitoza Parisi
They deal with wrapping correctly and are nicer to read. Also make jiffies-holding variables unsigned long. Signed-off-by: Marcelo Feitoza Parisi <marcelo@feitoza.com.br> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-05Merge branch 'master'Jeff Garzik
2005-10-04[PATCH] bogus kfree() in ibmtrAl Viro
On several failure exits in ibmtr we end up doing kfree() on dev->priv, with dev allocated by alloc_trdev() and ->priv never reassigned. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-14[PATCH] drivers/net: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-24Merge upstream into 'upstream' branch of netdev-2.6.git.Jeff Garzik
Hand fix merge conflict in drivers/net/tokenring/Kconfig.
2005-08-23[PATCH] Kconfig fix (tms380tr and ISA_DMA_API)Al Viro
ISA parts of tms380tr are using ISA DMA helpers and should depend on ISA_DMA_API. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-19[netdrvr] Convert madgemc to new MCA API.Jochen Friedrich
Now that all tms380 devices have a valid struct device with dma_mask, remove dmalimit from tmsdev_init(). Kconfig: depend tms380tr and madgemc on MCA. abyss.c, proteon.c, skisa.c, tmspci.c, tms380tr.h: remove dmalimit parameter from tmsdev_init(). tms380tr.c: use device->dma_mask instead of dmalimit. madgemc.c: move to new MCA API using struct device. Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-31[PATCH] tms380tr: move to DMA APIJochen Friedrich
This patch makes tms380tr use the new DMA API. Now that on Alpha, this API also supports bus master DMA for ISA (platform) devices, i changed the driver to use this new API. This also works around a bug in the firmware loader: The example provided in Documentation/firmware_class no longer works, as the firmware loader now calls get_kobj_path_length() and the kernel promptly oopses, as the home-grown device doesn't have a parent. Of course, this doesn't happen with a "real" device which has its bus (or pseudo bus in the case of platform) as parent. Converted tms380tr to use new DMA API: - proteon.c, skisa.c: use platform pseudo bus to create a struct device - Space.c: delete init hooks - abyss.c, tmspci.c: pass struct device to tms380tr.c - tms380tr.c, tms380tr.h: new DMA API, use real device fo firmware loader Signed-off-by: Jochen Friedrich <jochen@scram.de> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-26[PATCH] net/lanstreamer: replace schedule_timeout() with ↵Nishanth Aravamudan
ssleep()/msleep_interruptible() Use ssleep() / msleep_interruptible() [as appropriate] instead of schedule_timeout() to guarantee the task delays as expected. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Maximilian Attems <janitor@sternwelten.at> Signed-off-by: Domen Puncer <domen@coderock.org>
2005-06-26[PATCH] drivers/net/tokenring/: cleanupsAdrian Bunk
This patch contains the follwing cleanups: - make needlessly global code static - remove obsolete Emacs settings Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-06-26drivers/net/: Use the DMA_{64,32}BIT_MASK constantsDomen Puncer
Use the DMA_{64,32}BIT_MASK constants from dma-mapping.h when calling pci_set_dma_mask() or pci_set_consistent_dma_mask() This patch includes dma-mapping.h explicitly because it caused errors on some architectures otherwise. See http://marc.theaimsgroup.com/?t=108001993000001&r=1&w=2 for details Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Domen Puncer <domen@coderock.org>
2005-05-12[netdrvrs] Use netif_carrier_* instead of IFF_RUNNING
