path: root/drivers/net/tokenring/skisa.c
2008-12-26drivers/net/tokenring: fix sparse warnings: make symbols staticHannes Eder
Fix this sparse warnings: drivers/net/tokenring/ibmtr.c:1840:6: warning: symbol 'tok_rerun' was not declared. Should it be static? drivers/net/tokenring/madgemc.c:469:16: warning: symbol 'madgemc_setnselout_pins' was not declared. Should it be static? drivers/net/tokenring/proteon.c:286:16: warning: symbol 'proteon_setnselout_pins' was not declared. Should it be static? drivers/net/tokenring/skisa.c:303:16: warning: symbol 'sk_isa_setnselout_pins' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-03MAINTAINERS: remove Adam Fritzler, remove his email address in other sourcesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-31[PATCH] tokenring: fix module_init error handlingAkinobu Mita
- Call platform_driver_unregister() before return when no cards found. (fixes data corruption when no cards found) - Check platform_device_register_simple() return value Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Mike Phillips <mikep@linuxtr.net> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> drivers/net/tokenring/proteon.c | 9 +++++++-- drivers/net/tokenring/skisa.c | 9 +++++++-- 2 files changed, 14 insertions(+), 4 deletions(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-08-19[netdrvr] Convert madgemc to new MCA API.Jochen Friedrich
Now that all tms380 devices have a valid struct device with dma_mask, remove dmalimit from tmsdev_init(). Kconfig: depend tms380tr and madgemc on MCA. abyss.c, proteon.c, skisa.c, tmspci.c, tms380tr.h: remove dmalimit parameter from tmsdev_init(). tms380tr.c: use device->dma_mask instead of dmalimit. madgemc.c: move to new MCA API using struct device. Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-31[PATCH] tms380tr: move to DMA APIJochen Friedrich
This patch makes tms380tr use the new DMA API. Now that on Alpha, this API also supports bus master DMA for ISA (platform) devices, i changed the driver to use this new API. This also works around a bug in the firmware loader: The example provided in Documentation/firmware_class no longer works, as the firmware loader now calls get_kobj_path_length() and the kernel promptly oopses, as the home-grown device doesn't have a parent. Of course, this doesn't happen with a "real" device which has its bus (or pseudo bus in the case of platform) as parent. Converted tms380tr to use new DMA API: - proteon.c, skisa.c: use platform pseudo bus to create a struct device - Space.c: delete init hooks - abyss.c, tmspci.c: pass struct device to tms380tr.c - tms380tr.c, tms380tr.h: new DMA API, use real device fo firmware loader Signed-off-by: Jochen Friedrich <jochen@scram.de> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-26[PATCH] drivers/net/tokenring/: cleanupsAdrian Bunk
This patch contains the follwing cleanups: - make needlessly global code static - remove obsolete Emacs settings Signed-off-by: Adrian Bunk <bunk@stusta.de>
