path: root/drivers/net/tokenring/olympic.c
2009-02-17drivers/net/tokenring: fix sparse warning: symbol shadows an earlier oneHannes Eder
Impact: Remove redundant variables. Fix this sparse warnings: drivers/net/tokenring/lanstreamer.c:619:21: warning: symbol 'i' shadows an earlier one drivers/net/tokenring/lanstreamer.c:589:13: originally declared here drivers/net/tokenring/madgemc.c:695:34: warning: symbol 'tp' shadows an earlier one drivers/net/tokenring/madgemc.c:689:26: originally declared here drivers/net/tokenring/olympic.c:702:21: warning: symbol 'i' shadows an earlier one drivers/net/tokenring/olympic.c:440:13: originally declared here Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21olympic: convert to net_device_opsStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21olympic: convert to internal network device statsStephen Hemminger
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-08[NET]: Undo code bloat in hot paths due to print_mac().David S. Miller
If print_mac() is used inside of a pr_debug() the compiler can't see that the call is redundant so still performs it even of pr_debug() ends up being a nop. So don't use print_mac() in such cases in hot code paths, use MAC_FMT et al. instead. As noted by Joe Perches, pr_debug() could be modified to handle this better, but that is a change to an interface used by the entire kernel and thus needs to be validated carefully. This here is thus the less risky fix for 2.6.25 Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-04net/tokenring/olympic.c section fixesAdrian Bunk
My previous section fix only turned one section problem into another section problem. This patch fixes it for real. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-03olympic_open() must be __devinitAdrian Bunk
This patch fixes the following section mismatch: <-- snip --> ... WARNING: drivers/net/built-in.o(.text+0x155573): Section mismatch in reference from the function olympic_open() to the function .devinit.text:olympic_init() ... <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28endianness annotations and fixes for olympicAl Viro
* missing braces in !readl(...) & ... * trivial endianness annotations * in olympic_arb_cmd() the loop collecting fragments of packet is b0rken on big-endian - we have (next_ptr && (buf_ptr=olympic_priv->olympic_lap + ntohs(next_ptr))) as condition and it should have swab16(), not ntohs() - it's host-endian byteswapped, not big-endian. So if we get more than one fragment on big-endian host, we get screwed. This ntohs() got missed back when the rest of those had been switched to swab16() in 2.4.0-test2-pre1 - at a guess, nobody had hit fragmented packets during the testing of PPC fixes. PS: Ken Aaker cc'd on assumption that he is the same guy who'd done the original set of PPC fixes in olympic Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10dev->priv to netdev_priv(dev), drivers/net/tokenring/Yoann Padioleau
Replacing accesses to dev->priv to netdev_priv(dev). The replacment is safe when netdev_priv is used to access a private structure that is right next to the net_device structure in memory. Cf http://groups.google.com/group/comp.os.linux.development.system/browse_thread/thread/de19321bcd94dbb8/0d74a4adcd6177bd This is the case when the net_device structure was allocated with a call to alloc_netdev or one of its derivative. Here is an excerpt of the semantic patch that performs the transformation @ rule1 @ type T; struct net_device *dev; @@ dev = ( alloc_netdev | alloc_etherdev | alloc_trdev ) (sizeof(T), ...) @ rule1bis @ struct net_device *dev; expression E; @@ dev->priv = E @ rule2 depends on rule1 && !rule1bis @ struct net_device *dev; type rule1.T; @@ - (T*) dev->priv + netdev_priv(dev) PS: I have performed the same transformation on the whole kernel and it affects around 70 files, most of them in drivers/net/. Should I split my patch for each subnet directories ? (wireless/, wan/, etc) Thanks to Thomas Surrel for helping me refining my semantic patch. Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> 3c359.c | 58 +++++++++++++++++++++++++++++----------------------------- ibmtr.c | 38 +++++++++++++++++++------------------- lanstreamer.c | 32 ++++++++++++++++---------------- madgemc.c | 4 ++-- olympic.c | 36 ++++++++++++++++++------------------ tmspci.c | 4 ++-- 6 files changed, 86 insertions(+), 86 deletions(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[TR]: Make tr_type_trans set skb->devArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TR]: Use tr_hdr() were appropriateArnaldo Carvalho de Melo
2006-12-02[PATCH] pci_module_init() convertion in olympic.cHenrik Kretzschmar
pci_module_init() convertion in olympic.c Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[PATCH] Dereference in tokenring/olympic.cEric Sesterhenn
hi, coverity found (bug id #225) that we might call free_netdev() with NULL argument, when alloc_trdev() fails. This patch changes the goto, so we dont call free_netdev() for dev == NULL. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-01-17[PATCH] drivers/net/*: use time_after() and friendsMarcelo Feitoza Parisi
They deal with wrapping correctly and are nicer to read. Also make jiffies-holding variables unsigned long. Signed-off-by: Marcelo Feitoza Parisi <marcelo@feitoza.com.br> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-14[PATCH] drivers/net: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
