path: root/drivers/net/tokenring/madgemc.c
2009-03-27tokenring: convert drivers to net_device_opsStephen Hemminger
Convert madge and proteon drivers which are really just subclasses of tms380. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-17drivers/net/tokenring: fix sparse warning: symbol shadows an earlier oneHannes Eder
Impact: Remove redundant variables. Fix this sparse warnings: drivers/net/tokenring/lanstreamer.c:619:21: warning: symbol 'i' shadows an earlier one drivers/net/tokenring/lanstreamer.c:589:13: originally declared here drivers/net/tokenring/madgemc.c:695:34: warning: symbol 'tp' shadows an earlier one drivers/net/tokenring/madgemc.c:689:26: originally declared here drivers/net/tokenring/olympic.c:702:21: warning: symbol 'i' shadows an earlier one drivers/net/tokenring/olympic.c:440:13: originally declared here Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-26drivers/net/tokenring: fix sparse warnings: make symbols staticHannes Eder
Fix this sparse warnings: drivers/net/tokenring/ibmtr.c:1840:6: warning: symbol 'tok_rerun' was not declared. Should it be static? drivers/net/tokenring/madgemc.c:469:16: warning: symbol 'madgemc_setnselout_pins' was not declared. Should it be static? drivers/net/tokenring/proteon.c:286:16: warning: symbol 'proteon_setnselout_pins' was not declared. Should it be static? drivers/net/tokenring/skisa.c:303:16: warning: symbol 'sk_isa_setnselout_pins' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-03MAINTAINERS: remove Adam Fritzler, remove his email address in other sourcesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10dev->priv to netdev_priv(dev), drivers/net/tokenring/Yoann Padioleau
Replacing accesses to dev->priv to netdev_priv(dev). The replacment is safe when netdev_priv is used to access a private structure that is right next to the net_device structure in memory. Cf http://groups.google.com/group/comp.os.linux.development.system/browse_thread/thread/de19321bcd94dbb8/0d74a4adcd6177bd This is the case when the net_device structure was allocated with a call to alloc_netdev or one of its derivative. Here is an excerpt of the semantic patch that performs the transformation @ rule1 @ type T; struct net_device *dev; @@ dev = ( alloc_netdev | alloc_etherdev | alloc_trdev ) (sizeof(T), ...) @ rule1bis @ struct net_device *dev; expression E; @@ dev->priv = E @ rule2 depends on rule1 && !rule1bis @ struct net_device *dev; type rule1.T; @@ - (T*) dev->priv + netdev_priv(dev) PS: I have performed the same transformation on the whole kernel and it affects around 70 files, most of them in drivers/net/. Should I split my patch for each subnet directories ? (wireless/, wan/, etc) Thanks to Thomas Surrel for helping me refining my semantic patch. Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> 3c359.c | 58 +++++++++++++++++++++++++++++----------------------------- ibmtr.c | 38 +++++++++++++++++++------------------- lanstreamer.c | 32 ++++++++++++++++---------------- madgemc.c | 4 ++-- olympic.c | 36 ++++++++++++++++++------------------ tmspci.c | 4 ++-- 6 files changed, 86 insertions(+), 86 deletions(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-02PCI: Cleanup the includes of <linux/pci.h>Jean Delvare
I noticed that many source files include <linux/pci.h> while they do not appear to need it. Here is an attempt to clean it all up. In order to find all possibly affected files, I searched for all files including <linux/pci.h> but without any other occurence of "pci" or "PCI". I removed the include statement from all of these, then I compiled an allmodconfig kernel on both i386 and x86_64 and fixed the false positives manually. My tests covered 66% of the affected files, so there could be false positives remaining. Untested files are: arch/alpha/kernel/err_common.c arch/alpha/kernel/err_ev6.c arch/alpha/kernel/err_ev7.c arch/ia64/sn/kernel/huberror.c arch/ia64/sn/kernel/xpnet.c arch/m68knommu/kernel/dma.c arch/mips/lib/iomap.c arch/powerpc/platforms/pseries/ras.c arch/ppc/8260_io/enet.c arch/ppc/8260_io/fcc_enet.c arch/ppc/8xx_io/enet.c arch/ppc/syslib/ppc4xx_sgdma.c arch/sh64/mach-cayman/iomap.c arch/xtensa/kernel/xtensa_ksyms.c arch/xtensa/platform-iss/setup.c drivers/i2c/busses/i2c-at91.c drivers/i2c/busses/i2c-mpc.c drivers/media/video/saa711x.c drivers/misc/hdpuftrs/hdpu_cpustate.c drivers/misc/hdpuftrs/hdpu_nexus.c drivers/net/au1000_eth.c drivers/net/fec_8xx/fec_main.c drivers/net/fec_8xx/fec_mii.c drivers/net/fs_enet/fs_enet-main.c drivers/net/fs_enet/mac-fcc.c drivers/net/fs_enet/mac-fec.c drivers/net/fs_enet/mac-scc.c drivers/net/fs_enet/mii-bitbang.c drivers/net/fs_enet/mii-fec.c drivers/net/ibm_emac/ibm_emac_core.c drivers/net/lasi_82596.c drivers/parisc/hppb.c drivers/sbus/sbus.c drivers/video/g364fb.c drivers/video/platinumfb.c drivers/video/stifb.c drivers/video/valkyriefb.c include/asm-arm/arch-ixp4xx/dma.h sound/oss/au1550_ac97.c I would welcome test reports for these files. I am fine with removing the untested files from the patch if the general opinion is that these changes aren't safe. The tested part would still be nice to have. Note that this patch depends on another header fixup patch I submitted to LKML yesterday: [PATCH] scatterlist.h needs types.h http://lkml.org/lkml/2007/3/01/141 Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02BUG_ON() Conversion in drivers/net/Eric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-08-19[netdrvr] Convert madgemc to new MCA API.Jochen Friedrich
Now that all tms380 devices have a valid struct device with dma_mask, remove dmalimit from tmsdev_init(). Kconfig: depend tms380tr and madgemc on MCA. abyss.c, proteon.c, skisa.c, tmspci.c, tms380tr.h: remove dmalimit parameter from tmsdev_init(). tms380tr.c: use device->dma_mask instead of dmalimit. madgemc.c: move to new MCA API using struct device. Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-26[PATCH] drivers/net/tokenring/: cleanupsAdrian Bunk
This patch contains the follwing cleanups: - make needlessly global code static - remove obsolete Emacs settings Signed-off-by: Adrian Bunk <bunk@stusta.de>
