path: root/drivers/net/tokenring/madgemc.c
2006-04-02BUG_ON() Conversion in drivers/net/Eric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-08-19[netdrvr] Convert madgemc to new MCA API.Jochen Friedrich
Now that all tms380 devices have a valid struct device with dma_mask, remove dmalimit from tmsdev_init(). Kconfig: depend tms380tr and madgemc on MCA. abyss.c, proteon.c, skisa.c, tmspci.c, tms380tr.h: remove dmalimit parameter from tmsdev_init(). tms380tr.c: use device->dma_mask instead of dmalimit. madgemc.c: move to new MCA API using struct device. Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-26[PATCH] drivers/net/tokenring/: cleanupsAdrian Bunk
This patch contains the follwing cleanups: - make needlessly global code static - remove obsolete Emacs settings Signed-off-by: Adrian Bunk <bunk@stusta.de>
