Following the removal of the unused struct net_device * parameter from
the NAPI functions named *netif_rx_* in commit 908a7a1, they are
exactly equivalent to the corresponding *napi_* functions and are
therefore redundant.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
When the napi api was changed to separate its 1:1 binding to the net_device
struct, the netif_rx_[prep|schedule|complete] api failed to remove the now
vestigual net_device structure parameter. This patch cleans up that api by
properly removing it..
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
The chip can strip CRC automatically on receiving. Enable it.
Also fix potential RX_BUF_SIZE calculation bug which was obscured by
alignment. And use proper symbols (NET_IP_ALIGN, ETH_FCS_LEN, etc.)
instead of magic numbers.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
The generic packet receive code takes care of setting
netdev->last_rx when necessary, for the sake of the
bonding ARP monitor.
Drivers need not do it any more.
Some cases had to be skipped over because the drivers
were making use of the ->last_rx value themselves.
This converts pretty much everything to print_mac. There were
a few things that had conflicts which I have just dropped for
now, no harm done.
I've built an allyesconfig with this and looked at the files
that weren't built very carefully, but it's a huge patch.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Fix an obvious typo introduced by
commit 298cf9beb9679522de995e249eccbd82f7c51999
(phylib: move to dynamic allocation of struct mii_bus).
<-- snip -->
CC drivers/net/tc35815.o
drivers/net/tc35815.c: In function 'tc_mii_init':
drivers/net/tc35815.c:799: error: 'err_out_free_mii_bus' undeclared (first use in this function)
drivers/net/tc35815.c:799: error: (Each undeclared identifier is reported only once
drivers/net/tc35815.c:799: error: for each function it appears in.)
drivers/net/tc35815.c:781: error: label 'err_out_free_mii_bus' used but not defined
make[3]: *** [drivers/net/tc35815.o] Error 1
<-- snip -->
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This patch introduces mdiobus_alloc() and mdiobus_free(), and
makes all mdio bus drivers use these functions to allocate their
struct mii_bus'es dynamically.
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
Acked-by: Andy Fleming <afleming@freescale.com>
In preparation of giving mii_bus objects a device tree presence of
their own, rename struct mii_bus's ->dev argument to ->parent, since
having a 'struct device *dev' that points to our parent device
conflicts with introducing a 'struct device dev' representing our own
device.
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER
architecture does:
This enables us to cleanly fix the Calgary IOMMU issue that some devices
are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423).
I think that per-device dma_mapping_ops support would be also helpful for
KVM people to support PCI passthrough but Andi thinks that this makes it
difficult to support the PCI passthrough (see the above thread). So I
CC'ed this to KVM camp. Comments are appreciated.
A pointer to dma_mapping_ops to struct dev_archdata is added. If the
pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's
NULL, the system-wide dma_ops pointer is used as before.
If it's useful for KVM people, I plan to implement a mechanism to register
a hook called when a new pci (or dma capable) device is created (it works
with hot plugging). It enables IOMMUs to set up an appropriate
dma_mapping_ops per device.
The major obstacle is that dma_mapping_error doesn't take a pointer to the
device unlike other DMA operations. So x86 can't have dma_mapping_ops per
device. Note all the POWER IOMMUs use the same dma_mapping_error function
so this is not a problem for POWER but x86 IOMMUs use different
dma_mapping_error functions.
The first patch adds the device argument to dma_mapping_error. The patch
is trivial but large since it touches lots of drivers and dma-mapping.h in
all the architecture.
This patch:
dma_mapping_error() doesn't take a pointer to the device unlike other DMA
operations. So we can't have dma_mapping_ops per device.
Note that POWER already has dma_mapping_ops per device but all the POWER
IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device
argument.
[akpm@linux-foundation.org: fix sge]
[akpm@linux-foundation.org: fix svc_rdma]
[akpm@linux-foundation.org: build fix]
[akpm@linux-foundation.org: fix bnx2x]
[akpm@linux-foundation.org: fix s2io]
[akpm@linux-foundation.org: fix pasemi_mac]
[akpm@linux-foundation.org: fix sdhci]
[akpm@linux-foundation.org: fix sparc]
[akpm@linux-foundation.org: fix ibmvscsi]
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Muli Ben-Yehuda <muli@il.ibm.com>
Cc: Avi Kivity <avi@qumranet.com>
The drivers were touching net queue before it has been started, so
without this patch, the drivers will potentially WARN at
net/core/dev.c:1328.
I don't have the hardware for the drivers below, so this patch is
untested, and thus should be carefully peer reviewed.
tc35815.c
au1000_eth.c
bfin_mac.c
macb.c
^ The four drivers are using phylib, they're calling netif_start_queue()
in open() callback. So trivially remove netif_tx_schedule_all().
Phylib will handle netif_carrier_*().
cpmac.c
fec_mpc52xx.c
fs_enet/fs_enet-main.c
sh_eth.c
^ The same as above, but these were also needlessly calling
netif_carrier_*() functions. So removed queue calls and also remove
carrier calls, since phylib will handle it. fs_enet-main.c also didn't
call netif_start_queue() at open(), this is fixed now.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
They logically all want to trigger a schedule for all device
TX queues.
On Rx FIFO overflow error, the controller consume a buffer descriptor
but currently the driver does not give it back to the controller.
This results unrecoverable 'Buffer List Exhausted' condition. This
patch fix this problem by moving a "fbl_count--" line to proper place.
Call netif_carrier_off() before starting PHY device. This is a
behavior before converting to generic PHY layer.
On Sat, 12 Apr 2008 05:00:49 -0400, Jeff Garzik <jeff@garzik.org> wrote:
> applied 1-6
Thanks.
Could you apply this too, or hopufully fold into Andy Fleming's "phy:
Change mii_bus id field to a string" patch (commit c69fedae) ?
Subject: [PATCH] tc35815: build fix
Fix build failure caused by Andy Fleming's "phy: Change mii_bus id
field to a string" patch.
Cosmetic TAB/whitespace cleanups and some style cleanups. No
functional changes.
Convert the tc35815 driver to use the generic PHY layer in
drivers/net/phy. Also rename 'boardtype' to 'chiptype' which hould be
more appropriate.
Use managed pci functions and kill unnecessary volatiles.
Use netdev_priv() instead of dev->priv.
Use print_mac() and DECLARE_MAC_BUF().
Use struct net_device_stats embedded in struct net_device.
The tc35815-mac platform device used a pci bus number and a devfn to
identify its target device, but the pci bus number may vary if some
bus-bridges are found. Use irq number which is be unique for embedded
controllers.
Fix the various misspellings of "system", controller", "interrupt" and
"[un]necessary".
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
bea3348eef27e6044b6161fd04c3152215f96411 broke the build of tc35815.c
for the non-NAPI case:
drivers/net/tc35815.c: In function 'tc35815_interrupt':
drivers/net/tc35815.c:1464: error: redefinition of 'lp'
drivers/net/tc35815.c:1443: error: previous definition of 'lp' was here
Signed-off-by: Jeff Garzik <jeff@garzik.org>
These have been superceded by the new ->get_sset_count() hook.
It's been a useless no-op for long enough in 2.6 so I figured it's time to
remove it. The number of people that could object because they're
maintaining unified 2.4 and 2.6 drivers is probably rather small.
[ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ]
Several devices have multiple independant RX queues per net
device, and some have a single interrupt doorbell for several
queues.
In either case, it's easier to support layouts like that if the
structure representing the poll is independant from the net
device itself.
The signature of the ->poll() call back goes from:
int foo_poll(struct net_device *dev, int *budget)
to
int foo_poll(struct napi_struct *napi, int budget)
The caller is returned the number of RX packets processed (or
the number of "NAPI credits" consumed if you want to get
abstract). The callee no longer messes around bumping
dev->quota, *budget, etc. because that is all handled in the
caller upon return.
The napi_struct is to be embedded in the device driver private data
structures.
Furthermore, it is the driver's responsibility to disable all NAPI
instances in it's ->stop() device close handler. Since the
napi_struct is privatized into the driver's private data structures,
only the driver knows how to get at all of the napi_struct instances
it may have per-device.
With lots of help and suggestions from Rusty Russell, Roland Dreier,
Michael Chan, Jeff Garzik, and Jamal Hadi Salim.
Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra,
Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan.
[ Ported to current tree and all drivers converted. Integrated
Stephen's follow-on kerneldoc additions, and restored poll_list
handling to the old style to fix mutual exclusion issues. -DaveM ]
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
All drivers implement ethtool get_perm_addr the same way -- by calling
the generic function. So we can inline the generic function into the
caller and avoid going through the drivers.
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
Fix wrong argument of tc35815_read_plat_dev_addr()
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
TX49XX SoCs include PCI NIC (TC35815 compatible) connected via its
internal PCI bus, but the NIC's PROM interface is not connected to
SEEPROM. So we must provide its ethernet address by another way.
Acked-by: Jeff Garzik <jeff@garzik.org>
Apply changes in commit 4c13eb6657fe9ef7b4dc8f1a405c902e9e5234e0 to
newly added piece of code.
The tc35815 driver lacks a call to pci_dma_sync_single_for_device() on
receiving. Recent fix of MIPS dma_sync_single_for_cpu() reveal this
bug.
Current tc35815 driver is very obsolete and less maintained for a long
time. Replace it with a new driver based on one from CELF patch
archive.
Major advantages of CELF version (version 1.23, for kernel 2.6.10) are:
* Independent of JMR3927.
(Actually independent of MIPS, but AFAIK the chip is used only on
MIPS platforms)
* TX4938 support.
* 64-bit proof.
* Asynchronous and on-demand auto negotiation.
* High performance on non-coherent architecture.
* ethtool support.
* Many bugfixes and cleanups.
And improvoments since version 1.23 are:
* TX4939 support.
* NETPOLL support.
* NAPI support. (disabled by default)
* Reduce memcpy on receiving.
* PM support.
* Many cleanups and bugfixes.
One less thing for drivers writers to worry about.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
No need to stop tc35815 before resetting the board. This fixes the
build of tc35815 as a module. This also means there is no caller of
tc35815_killall left, so remove that function also.
* clear_page() use is wrong. We might have multiple pages.
Use memset() instead.
* Call pci_unregister_driver() in module exit.
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com>
Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com>
Cc: Jeff Garzik <jeff@garzik.org>
infrastructure for it.
Let it rip!
