path: root/drivers/net/sunlance.c
2006-09-25[SUNLANCE]: Mark sparc_lance_probe_one as __devinit.David S. Miller
Fixes section mismatch warnings when built as a module. Also, mark find_ledma and sun4 init function as __devinit too. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-08-29[SUNLANCE]: Fix probing problem.Krzysztof Helt
The current probe table causes ledma and lebuffer "le" devices to get probed twice which is not what we want. Match just "le" and look directly at the parent to get the correct top-level node information. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-28[SUNLANCE]: fix compilation on sparc-UPAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[NET] sunlance: Convert to new SBUS driver framework.David S. Miller
2006-06-20[SPARC]: Kill __irq_itoa().David S. Miller
This ugly hack was long overdue to die. It was a way to print out Sparc interrupts in a more freindly format, since IRQ numbers were arbitrary opaque 32-bit integers which vectored into PIL levels. These 32-bit integers were not necessarily in the 0-->NR_IRQS range, but the PILs they vectored to were. The idea now is that we will increase NR_IRQS a little bit and use a virtual<-->real IRQ number mapping scheme similar to PowerPC. That makes this IRQ printing hack irrelevant, and furthermore only a handful of drivers actually used __irq_itoa() making it even less useful. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-24[SPARC]: module version cleanupsTom 'spot' Callaway
Minor cleanups for sparc specific drivers (sunbmac, sunqe, sunlance, sunhme, esp) so that they have a full module version definition that is consistent with other upstream drivers. Signed-off-by: Tom 'spot' Callaway <tcallawa@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
