path: root/drivers/net/starfire.c
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] starfire: free_irq() on error path of netdev_open()Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-03[netdrvr starfire] fix highmem and broken firmware issuesIon Badulescu
Unfortunately, [your patch] might address the crash but doesn't address the real problem. It turns out that the problem is one of padding (the firmware cksum engine works only on 32-bit chunks, yuck), so the special casing for length == 1 wasn't sufficient anyway. This patch addresses the issue, as well the other issue of i386 + CONFIG_HIGHMEM being broken. It is pretty much the same workaround that Adaptec themselves used in their Windows driver. I have yet to check if it fixes the problem when the skb is non-linear, but this patch _will_ solve the problem for 99% of the users out there (those not using sendfile). Signed-off-by: Ion Badulescu <ionut@badula.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-28[NET]: Remove gratuitous use of skb->tail in network drivers.David S. Miller
Many drivers use skb->tail unnecessarily. In these situations, the code roughly looks like: dev = dev_alloc_skb(...); [optional] skb_reserve(skb, ...); ... skb->tail ... But even if the skb_reserve() happens, skb->data equals skb->tail. So it doesn't make any sense to use anything other than skb->data in these cases. Another case was the s2io.c driver directly mucking with the skb->data and skb->tail pointers. It really just wanted to do an skb_reserve(), so that's what the code was changed to do instead. Another reason I'm making this change as it allows some SKB cleanups I have planned simpler to merge. In those cleanups, skb->head, skb->tail, and skb->end pointers are removed, and replaced with skb->head_room and skb->tail_room integers. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jgarzik@pobox.com>
2005-05-12 [netdrvr starfire] Add GPL'd firmware, remove compat codeJeff Garzik
Contributed by Ion Badulescu <ionut@badula.org>, further fixed up by me.
