path: root/drivers/net/starfire.c
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-24Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (217 commits) net/ieee80211: fix more crypto-related build breakage [PATCH] Spidernet: add ethtool -S (show statistics) [NET] GT96100: Delete bitrotting ethernet driver [PATCH] mv643xx_eth: restrict to 32-bit PPC_MULTIPLATFORM [PATCH] Cirrus Logic ep93xx ethernet driver r8169: the MMIO region of the 8167 stands behin BAR#1 e1000, ixgb: Remove pointless wrappers [PATCH] Remove powerpc specific parts of 3c509 driver [PATCH] s2io: Switch to pci_get_device [PATCH] gt96100: move to pci_get_device API [PATCH] ehea: bugfix for register access functions [PATCH] e1000 disable device on PCI error drivers/net/phy/fixed: #if 0 some incomplete code drivers/net: const-ify ethtool_ops declarations [PATCH] ethtool: allow const ethtool_ops [PATCH] sky2: big endian [PATCH] sky2: fiber support [PATCH] sky2: tx pause bug fix drivers/net: Trim trailing whitespace [PATCH] ehea: IBM eHEA Ethernet Device Driver ... Manually resolved conflicts in drivers/net/ixgb/ixgb_main.c and drivers/net/sky2.c related to CHECKSUM_HW/CHECKSUM_PARTIAL changes by commit 84fa7933a33f806bbbaae6775e87459b1ec584c0 that just happened to be next to unrelated changes in this update.
2006-09-22[NET]: Replace CHECKSUM_HW by CHECKSUM_PARTIAL/CHECKSUM_COMPLETEPatrick McHardy
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose checksum still needs to be completed) and CHECKSUM_COMPLETE (for incoming packets, device supplied full checksum). Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-08-19drivers/net: Remove deprecated use of pci_module_init()Jeff Garzik
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[netdrvr] minor cleanups in Becker-derived driversJeff Garzik
- fealnx: convert #define to enum - fealnx, sundance: mark chip info table __devinitdata - fealnx: use dev_printk() during probe - fealnx: formatting cleanups - starfire: remove obsolete comment - sundance, via-rhine: add some whitespace where useful, in tables - sundance: prefer "{ }" table terminator - via-rhine: mark PCI probe table const Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[netdrvr] Remove Linux-specific changelogs from several Becker template driversJeff Garzik
When in-kernel net drivers branched from Donald Becker's vanilla driver set, in the days before BitKeeper and git, a driver changelog was maintained in the driver source code. These days, the kernel's changelog is far superior and much more accurate, so the in-driver changelogs are removed. Another relic of the Becker/kernel split was version numbering, using "foo-LKx.y.z" notation, resulting in weird version numbers like "1.17b-LK1.1.9". These drivers are for older hardware, and see few changes these days, so the version numbers were all bumped to something more simple. Finally, in xircom_tulip_cb specifically, an additional cleanup removes the always-enabled CARDBUS cpp macro. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[NET]: Avoid allocating skb in skb_padHerbert Xu
First of all it is unnecessary to allocate a new skb in skb_pad since the existing one is not shared. More importantly, our hard_start_xmit interface does not allow a new skb to be allocated since that breaks requeueing. This patch uses pskb_expand_head to expand the existing skb and linearize it if needed. Actually, someone should sift through every instance of skb_pad on a non-linear skb as they do not fit the reasons why this was originally created. Incidentally, this fixes a minor bug when the skb is cloned (tcpdump, TCP, etc.). As it is skb_pad will simply write over a cloned skb. Because of the position of the write it is unlikely to cause problems but still it's best if we don't do it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-12[PATCH] net drivers: fix section attributes for gccRandy Dunlap
If CONFIG_HOTPLUG=n, gcc doesn't like some __initdata to be const (rodata) and other __initdata not const, so make the non-const __initdata const. gcc errors: drivers/net/bnx2.c:66: error: version causes a section type conflict drivers/net/starfire.c:338: error: version causes a section type conflict drivers/net/typhoon.c:137: error: version causes a section type conflict drivers/net/natsemi.c:241: error: version causes a section type conflict Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-02BUG_ON() Conversion in drivers/net/Eric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-03Merge branch 'net-const'Jeff Garzik
2006-03-03Massive net driver const-ification.Arjan van de Ven
2006-01-17[PATCH] starfire: Implement suspend/resumeStefan Rompf
This patch implements suspend and resume methods for the starfire driver. It allows me to put my desktop PC with a starfire dual board into S4. Signed-Off-By: Stefan Rompf <stefan@loplof.de> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] starfire: free_irq() on error path of netdev_open()Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-03[netdrvr starfire] fix highmem and broken firmware issuesIon Badulescu
Unfortunately, [your patch] might address the crash but doesn't address the real problem. It turns out that the problem is one of padding (the firmware cksum engine works only on 32-bit chunks, yuck), so the special casing for length == 1 wasn't sufficient anyway. This patch addresses the issue, as well the other issue of i386 + CONFIG_HIGHMEM being broken. It is pretty much the same workaround that Adaptec themselves used in their Windows driver. I have yet to check if it fixes the problem when the skb is non-linear, but this patch _will_ solve the problem for 99% of the users out there (those not using sendfile). Signed-off-by: Ion Badulescu <ionut@badula.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-28[NET]: Remove gratuitous use of skb->tail in network drivers.David S. Miller
Many drivers use skb->tail unnecessarily. In these situations, the code roughly looks like: dev = dev_alloc_skb(...); [optional] skb_reserve(skb, ...); ... skb->tail ... But even if the skb_reserve() happens, skb->data equals skb->tail. So it doesn't make any sense to use anything other than skb->data in these cases. Another case was the s2io.c driver directly mucking with the skb->data and skb->tail pointers. It really just wanted to do an skb_reserve(), so that's what the code was changed to do instead. Another reason I'm making this change as it allows some SKB cleanups I have planned simpler to merge. In those cleanups, skb->head, skb->tail, and skb->end pointers are removed, and replaced with skb->head_room and skb->tail_room integers. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jgarzik@pobox.com>
2005-05-12 [netdrvr starfire] Add GPL'd firmware, remove compat codeJeff Garzik
Contributed by Ion Badulescu <ionut@badula.org>, further fixed up by me.
