path: root/drivers/net/smsc911x.h
2008-11-06SMSC LAN911x and LAN921x vendor driverSteve Glendinning
Attached is a driver for SMSC's LAN911x and LAN921x families of embedded ethernet controllers. There is an existing smc911x driver in the tree; this is intended to replace it. Dustin McIntire (the author of the smc911x driver) has expressed his support for switching to this driver. This driver contains workarounds for all known hardware issues, and has been tested on all flavours of the chip on multiple architectures. This driver now uses phylib, so this patch also adds support for the device's internal phy Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: Bahadir Balban <Bahadir.Balban@arm.com> Signed-off-by: Dustin Mcintire <dustin@sensoria.com> Signed-off-by: Bill Gatliff <bgat@billgatliff.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
