path: root/drivers/net/smc91x.h
2008-04-07Revert "smc91x: fix build breakage from the SMC_GET_MAC_ADDR API upgrade"Linus Torvalds
This reverts commit 9e6db60825ef7e7999abc610ce256ba768e58162, which was merged without the API it needed, causing build breakage. Reported-by: Bryan Wu <cooloney@kernel.org> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-25smc91x: fix build breakage from the SMC_GET_MAC_ADDR API upgradeBryan Wu
Cc: Jeff Garzik <jeff@garzik.org> Cc: Deepak Saxena <dsaxena@plexity.net> Cc: Nicolas Pitre <nico@cam.org> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-08mn10300: add the MN10300/AM33 architecture to the kernelDavid Howells
Add architecture support for the MN10300/AM33 CPUs produced by MEI to the kernel. This patch also adds board support for the ASB2303 with the ASB2308 daughter board, and the ASB2305. The only processor supported is the MN103E010, which is an AM33v2 core plus on-chip devices. [akpm@linux-foundation.org: nuke cvs control strings] Signed-off-by: Masakazu Urade <urade.masakazu@jp.panasonic.com> Signed-off-by: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28[ARM] 4746/1: pcm027: network support for phyCORE-PXA270Robert Schwebel
This patch adds SMC91x support for the phyCORE-PXA270 CPU module (aka PCM-027). Signed-off-by: Juergen Beisert <j.beisert@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28[NET] smc91x: Make smc91x use IRQ resource trigger flagsRussell King
smc91x is shared between many different platforms. Each platform needs to specify the interrupt type, and in some cases the irq type depends on more than just the build configuration - it depends on runtime checks. Rather than throwing this code into the SMC_IRQ_FLAGS definition, provide a way for these flags to be passed via the IRQ resource itself. Note that IRQF_TRIGGER_* constants are intentionally defined to correspond with the IORESOURCE_IRQ_* interrupt type flags, in much the same way that the low bits of PCI iomem resources correspond with the BAR flag bits. Also provide a way to configure smc91x to read the IRQ flags from the resource. Once all platforms have been converted over (signified by all definitions of SMC_IRQ_FLAGS being -1) SMC_IRQ_FLAGS should be removed. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Nicolas Pitre <nico@cam.org> Acked-by: Jeff Garzik <jgarzik@redhat.com>
2007-11-23Blackfin SMC91x Driver: punt CONFIG_BFIN -- we already have CONFIG_BLACKFINMike Frysinger
Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-10add support for smc91x ethernet interface on zyloniteeric miao
This patch adds LAN91C111 ethernet interface support for zylonite (a.k.a Marvell's PXA3xx Development Platform) with smc91x driver. It would be better if a patch would support zylonite along with all other PXA boards with a single binary of smc91x driver, but it looks quite difficult for the moment, so ugly #ifdef is still used here. Signed-off-by: Aleksey Makarov <amakarov@ru.mvista.com> Acked-by: eric miao <eric.miao@marvell.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-15[NET] smc91x: fix PXA DMA support codeRussell King
The PXA DMA support code for smc91x doesn't pass a struct device to the dma_*map_single() functions, which leads to an oops in the dma bounce code. We have a struct device which was used to probe the SMC chip. Use it. (This patch is slightly larger because it requires struct smc_local to move into the header file.) Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-10smc91x Hitachi Solution Engine (SuperH) SupportNobuhiro Iwamatsu
Hi, all. This patch supports Hitachi Solution Engine (SuperH) of smc91x. Please apply this patch . regards, Nobuhiro -- Nobuhiro Iwamatsu E-Mail : iwamatsu@nigauri.org GPG ID : 3170EBE9 Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-07net: smc91x: Build fixes for general sh boards.Paul Mundt
SH boards in general only wire this up in 8 or 16-bit mode, and as we never had the wrappers for 32-bit mode defined, SMC_CAN_USE_32BIT caused build failure for the non-Solution Engine boards. This gets it building again. Also kill off the straggling set_irq_type() definition, this is left over cruft that was missed when the rest of it switched to IRQ flags. Signed-off-by: Paul Mundt <lethal@linux-sh.org> -- drivers/net/smc91x.h | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-06-11Blackfin SMC91X ethernet supporting driver: SMC91C111 LEDs are note drived ↵Jean-Christian de Rivaz
in the kernel like in uboot Signed-off-by: Jean-Christian de Rivaz <jc@eclis.ch> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-06-03smc91x: sh solution engine fixes.Paul Mundt
The current smc91x I/O routines ifdef the solution engine subtypes individually, which is rather bogus, as they can simply use CONFIG_SOLUTION_ENGINE instead. This fixes it for some of the other solution engines that weren't included in the ifdef list (SH7206 specifically). There are also inb/outb definitions which are totally bogus (missing brackets in _both_ cases, SMC_CAN_USE_8BIT == 0, and even better, they try to use a 16-bit access to fake 8-bit access). Kill that nonsense off completely. Signed-off-by: Paul Mundt <lethal@linux-sh.org> -- drivers/net/smc91x.h | 5 +---- 1 file changed, 1 insertion(+), 4 deletions(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08smc91x SuperH supportNobuhiro Iwamatsu
This patch supports SuperH of smc91x. smc91x installed on the board of SuperH comes to work by applying this patch. Please apply this patch . Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-07Blackfin: add blackfin support in smc91x ethernet controller driverWu, Bryan
As SMC91X ethernet controller are used in blackfin STAMP 533 development board, this patch add blackfin support to the smc91x linux driver. Signed-off-by: Bryan Wu <bryan.wu@analog.com> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-11[PATCH] smc91x: Kill off excessive versatile hooks.Paul Mundt
This looks like a result of too many auto-merges. The CONFIG_ARCH_VERSATILE case was handled a total of 6 times. This kills 5 of them. Signed-off-by: Paul Mundt <lethal@linux-sh.org> -- drivers/net/smc91x.h | 90 --------------------------------------------------- 1 file changed, 90 deletions(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-04[PATCH] net: smc91x add missing bracketMariusz Kozlowski
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-04[PATCH] Update smc91x driver with ARM Versatile board infoDeepak Saxena
We need to specify a Versatile-specific SMC_IRQ_FLAGS value or the new generic IRQ layer will complain thusly: No IRQF_TRIGGER set_type function for IRQ 25 (<NULL>) Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Cc: Jeff Garzik <jeff@garzik.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Nicolas Pitre <nico@cam.org> On Fri, 20 Oct 2006 22:50:40 +0100 Russell King <rmk@arm.linux.org.uk> wrote: > On Fri, Oct 20, 2006 at 02:42:04PM -0700, akpm@osdl.org wrote: > > We need to specify a Versatile-specific SMC_IRQ_FLAGS value or the new > > generic IRQ layer will complain thusly: > > I don't think I heard anything back from my previous suggestion that > the IRQ flags are passed through the platform device IRQ resource. > > Doing so would avoid adding yet another platform specific block into > the file. > > BTW, Integrator platforms will also suffer from this, which will add > another ifdef to this header. > > Let's do it right and arrange to pass these flags from the platform > code. It's not like they're in a critical path. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-04[PATCH] __iomem annotations: smc91xAl Viro
2006-10-21[PATCH] Update smc91x driver with ARM Versatile board infoDeepak Saxena
We need to specify a Versatile-specific SMC_IRQ_FLAGS value or the new generic IRQ layer will complain thusly: No IRQF_TRIGGER set_type function for IRQ 25 (<NULL>) Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Cc: Jeff Garzik <jeff@garzik.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Nicolas Pitre <nico@cam.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-10-11[PATCH] Update smc91x driver with ARM Versatile board infoDeepak Saxena
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-29[PATCH] OMAP: Add smc91x support for TI OMAP2420 H4 boardKomal Shah
Add smc91x support for TI OMAP2420 H4 EVM board. Cc: <nico@cam.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25[PATCH] Update smc91x driver with ARM Versatile board infoDeepak Saxena
2006-08-19[PATCH] build fixes: smc91xDavid Brownell
Unclear how these bugs arrived, presumably from incorrect cleanup of the 16-bit-only paths, but smc91x wouldn't build for OMAP. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Nicolas Pitre <nico@cam.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-19[PATCH] Update smc91x driver with ARM Versatile board infoDeepak Saxena
2006-08-14[PATCH] smc91x: disable DMA mode on the logicpd pxa270Lennert Buytenhek
Enabling PXA DMA for the smc91x on the logicpd pxa270 produces unacceptable interference with the TFT panel, so disable it. Also delete the lpd270 versions of the SMC_{in,out}[bl]() macros, as they aren't used, since the board only supports 16bit accesses. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-12[PATCH] Update smc91x driver with ARM Versatile board infoDeepak Saxena
We need to specify a Versatile-specific SMC_IRQ_FLAGS value or the new generic IRQ layer will complain thusly: No IRQF_TRIGGER set_type function for IRQ 25 (<NULL>) Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-20Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (22 commits) [ARM] 3559/1: S3C2442: core and serial port [ARM] 3557/1: S3C24XX: centralise and cleanup uart registration [ARM] 3558/1: SMDK24XX: LED platform devices [ARM] 3534/1: add spi support to lubbock platform [ARM] 3554/1: ARM: Fix dyntick locking [ARM] 3553/1: S3C24XX: earlier print of cpu idcode info [ARM] 3552/1: S3C24XX: Move VA of GPIO for low-level debug [ARM] 3551/1: S3C24XX: PM code failes to compile with CONFIG_DCACHE_WRITETHROUGH [ARM] 3550/1: OSIRIS: fix serial port map for 1:1 [ARM] 3548/1: Fix the ARMv6 CPU id in compressed/head.S [ARM] 3335/1: Old-abi Thumb sys_syscall broken [ARM] 3467/1: [3/3] Support for Philips PNX4008 platform: defconfig [ARM] 3466/1: [2/3] Support for Philips PNX4008 platform: chip support [ARM] 3465/1: [1/3] Support for Philips PNX4008 platform: headers [ARM] 3407/1: lpd7x: documetation update [ARM] 3406/1: lpd7x: compilation fix for smc91x [ARM] 3405/1: lpd7a40x: CPLD ssp driver [ARM] 3404/1: lpd7a40x: AMBA CLCD support [ARM] 3403/1: lpd7a40x: updated default configurations [ARM] 3402/1: lpd7a40x: serial driver bug fix ...
2006-06-18[ARM] 3406/1: lpd7x: compilation fix for smc91xMarc Singer
Patch from Marc Singer Reworking of the adaptation macros to allow driver to compile again for the lpd7x's. Also, support added for the lh79520 so it may use the smc91x. Signed-off-by: Marc Singer <elf@buici.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-01[PATCH] smc91x: add support for LogicPD PXA270 platformLennert Buytenhek
This patch adds support for the smc91x on the LogicPD PXA270 to the smc91x driver. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-21[PATCH] smc91x: allow for dynamic bus access configsNicolas Pitre
All accessor's different methods are now selected with C code and unused ones statically optimized away at compile time instead of being selected with #if's and #ifdef's. This has many advantages such as allowing the compiler to validate the syntax of the whole code, making it cleaner and easier to understand, and ultimately allowing people to define configuration symbols in terms of variables if they really want to dynamically support multiple bus configurations at the same time (with the unavoidable performance cost). Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-01-08[PATCH] IRQ type flagsRussell King
Some ARM platforms have the ability to program the interrupt controller to detect various interrupt edges and/or levels. For some platforms, this is critical to setup correctly, particularly those which the setting is dependent on the device. Currently, ARM drivers do (eg) the following: err = request_irq(irq, ...); set_irq_type(irq, IRQT_RISING); However, if the interrupt has previously been programmed to be level sensitive (for whatever reason) then this will cause an interrupt storm. Hence, if we combine set_irq_type() with request_irq(), we can then safely set the type prior to unmasking the interrupt. The unfortunate problem is that in order to support this, these flags need to be visible outside of the ARM architecture - drivers such as smc91x need these flags and they're cross-architecture. Finally, the SA_TRIGGER_* flag passed to request_irq() should reflect the property that the device would like. The IRQ controller code should do its best to select the most appropriate supported mode. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-12[ARM] Use correct IO operations for PlebRussell King
Use read/write IO operations rather than in/out, as per other SA1100 platforms. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-11[PATCH] smc91x: DB1200 support.Pete Popov
The following patch support the SMC9111 present on DB1200 boards. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-30[PATCH] m32r: SMC91x driver updateHirokazu Takata
Update SMC91x driver for m32r. - Remove needless NONCACHE_OFFSET adjustment. > [PATCH 2.6.14-rc4] m32r: NONCACHE_OFFSET in _port2addr > Change _port2addr() not to add NONCACHE_OFFSET. > Adding NONCACHE_OFFSET requires needless address adjusting by a driver > using ioremap() like a SMC91x driver. - Fix lots of warnings as following: /usr/src/ctest/git/kernel/drivers/net/smc91x.c: In function `smc_reset': /usr/src/ctest/git/kernel/drivers/net/smc91x.c:324: warning: passing arg 2 of `_outw' makes integer from pointer without a cast /usr/src/ctest/git/kernel/drivers/net/smc91x.c:325: warning: passing arg 2 of `_outw' makes integer from pointer without a cast /usr/src/ctest/git/kernel/drivers/net/smc91x.c:341: warning: passing arg 2 of `_outw' makes integer from pointer without a cast /usr/src/ctest/git/kernel/drivers/net/smc91x.c:342: warning: passing arg 2 of `_outw' makes integer from pointer without a cast : /usr/src/ctest/git/kernel/drivers/net/smc91x.c:1915: warning: passing arg 1 of `_inw' makes integer from pointer without a cast /usr/src/ctest/git/kernel/drivers/net/smc91x.c:1915: warning: passing arg 1 of `_inw' makes integer from pointer without a cast Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] bogus #if (smc91x.h)viro@ZenIV.linux.org.uk
2005-07-31[PATCH] Fix OMAP specific typo in smc91x.hTony Lindgren
--ReaqsoxgOBHFXBhH Content-Type: text/plain; charset=us-ascii Content-Disposition: inline Hi Jeff, Here's a little patch fixing a typo in smc91x.h. Regards, Tony --ReaqsoxgOBHFXBhH Content-Type: text/x-chdr; charset=us-ascii Content-Disposition: inline; filename="patch-fix-typo-smc91x.h" Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-27[PATCH] smc91x needs settable IRQ trigger typeDavid Brownell
For boards that invert the SMC91x IRQ line (maybe an FPGA inverts it), the set_irq_type() call can't assume IRQT_RISING. These particular boards currently use OMAP-specific calls to change the trigger type, but the boards break when set_irq_type() stops being a NOP. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2005-05-27[PATCH] smc91x: improve diagnostic infoNicolas Pitre
... and remove duplicate status defines. Signed-off-by: Nicolas Pitre <nico@cam.org> Index: linux-2.6/drivers/net/smc91x.c ===================================================================
2005-05-12 [PATCH] smc91x warning fixNicolas Pitre
A few IO addr type conversions were missing. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
