path: root/drivers/net/smc911x.c
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-07Network: convert network devices to use struct device instead of class_deviceGreg Kroah-Hartman
This lets the network core have the ability to handle suspend/resume issues, if it wants to. Thanks to Frederik Deweerdt <frederik.deweerdt@gmail.com> for the arm driver fixes. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-03[PATCH] net/smc911x: match up spin lock/unlockPeter Korsgaard
smc911x_phy_configure's error handling unconditionally unlocks the spinlock even if it wasn't locked. Patch fixes it. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Cc: Jeff Garzik <jeff@garzik.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-22[PATCH] smc911 workqueue fixesAndrew Morton
Teach this driver about the workqueue changes. Cc: Vitaly Wool <vitalywool@gmail.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] smc911x: fix netpoll compilation faliureVitaly Wool
Fix the compilation failure for smc911x.c when NET_POLL_CONTROLLER is set. Signed-off-by: Vitaly Wool <vitalywool@gmail.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-19Merge branch 'upstream-fixes' into upstreamJeff Garzik
2006-08-19[PATCH] smc911x: Re-release spinlock on spurious interruptPeter Korsgaard
The smc911x driver forgets to release the spinlock on spurious interrupts. This little patch fixes it. Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-14[PATCH] remove unnecessary config.h includes from drivers/net/Dave Jones
config.h is automatically included by kbuild these days. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-20[netdrvr smc911x] trim trailing whitespaceJeff Garzik
2006-04-20[PATCH] RE: [PATCH 1/1] net driver: Add support for SMSC LAN911x line of ↵Dustin McIntire
ethernet chips > > The patch was badly wordwrapped. Please fix and resend. > OK, I've fixed the wrapping and removed the CONFIG_ARM restriction. I've also did my best to modify the C style to conform to the comments. I noticed that the patch is getting ignored by majordomo due to its size >100K. Should it be broken up somehow to allow posting to the lists? Signed-off-by: Dustin McIntire <dustin@sensoria.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
