path: root/drivers/net/sky2.c
2008-11-19sky2: convert to net_device_opsStephen Hemminger
Convert to new network device ops interface. Slight additional complexity here because the second port does not allow netpoll and therefore has different virtual function table. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-12sky2: Fix WOL regressionRafael J. Wysocki
Since dev->power.should_wakeup bit is used by the PCI core to decide whether the device should wake up the system from sleep states, set/unset this bit whenever WOL is enabled/disabled using sky2_set_wol(). Remove an open-coded reference to the standard PCI PM registers that is not used any more. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-03sky2: display product info on boot.Stephen Hemminger
Change bootup messages to print more information. This is to help users who may have old buggy EEPROM image. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-03sky2: EEPROM read/write bug fixesStephen Hemminger
Cleanup and harden the routines accessing the EEPROM. 1. Prevent spin forever waiting for the TWSI bus 2. Fix write eeprom to write full words rather than only 16 bits Luckly the vendor doesn't provide EEPROM in Linux format so it must never have been used. 3. Don't allow partial eeprom writes, not needed, not safe. These are non-urgent bug fixes. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-14sky2: Fix suspend/hibernation/shutdown regression with WOL enabled (rev. 2)Rafael J. Wysocki
On my test box with the Asus M3A32-MVP main board there is a regression from 2.6.26 related to suspend, hibernation and shutdown. Namely, if Wake-on-LAN is enabled with 'ethtool -s eth0 wol g', the box hangs solid during all of these operations, while executing either sky2_suspend(), or sky2_shutdown(). This patch fixes it for me. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-14[netdrvr] remove unnecessary #includeHuang Weiyi
The drivers below do not use LINUX_VERSION_CODE nor KERNEL_VERSION. drivers/net/acenic.c drivers/net/bnx2x_link.c drivers/net/bnx2x_main.c drivers/net/cpmac.c drivers/net/gianfar_sysfs.c drivers/net/ipg.h drivers/net/ppp_mppe.c drivers/net/pppol2tp.c drivers/net/r6040.c drivers/net/sh_eth.c drivers/net/sky2.c drivers/net/tehuti.h drivers/net/typhoon.c This patch removes the said #include <linux/version.h>. Signed-off-by: Huang Weiyi <hwy@cn.fujitsu.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-07sky2: fix PM related regressionsStephen Hemminger
Fix the problems reported for 2.6.27-rc1 caused by over aggressive power management. Turning clock off on PCI Express is problematic for WOL, and when doing multi-booting. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-22sky2: don't stop queue on shutdownStephen Hemminger
It is unnecessary, to stop queue and turn off carrier in shutdown routine. With new netdev_queue this causes warnings. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-19Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/tx.c
2008-06-17sky2: version 1.22Stephen Hemminger
New version to reflect new hardware support Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-17sky2: 88E8057 chip supportStephen Hemminger
Add support for Yukon 2 Ultra 2 chip set (88E8057) based on code in latest version of vendor driver (sk98lin 10.60.2.3). Untested on real hardware. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-17sky2: use DEFINE_PCI_DEVICE_TABLEStephen Hemminger
PCI device table can be marked as devinitconst by using macro. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-17sky2: chip version printoutStephen Hemminger
Change how chip version is printed so that if an unknown version is detected nothing breaks. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-17sky2: phy setup changesStephen Hemminger
Change the setup of the PHY registers on some chip ids. These changes make the latest sky2 driver follow the vendor driver. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-17sky2: 88E8040T pci device idStephen Hemminger
Missed one pci id for 88E8040T. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-13Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smc911x.c
2008-06-10sky2: Hold RTNL while calling dev_close()Ben Hutchings
dev_close() must be called holding the RTNL. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30sky2: pci power savingsStephen Hemminger
Turn on special bits to save more power when device is shutdown. Tested on a limited range of hardware, some of the bits are for hardware that probably isn't even in production (like Yukon Supreme) and was ported from the vendor driver. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30sky2: put PHY in sleep when downStephen Hemminger
Put PHY int sleep mode (from vendor sk98lin 10.50 driver) when the network device is brought down. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30sky2: split phy power into two functionsStephen Hemminger
Later changes add more code to PHY power changes so refactor now. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-25Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/cpmac.c net/mac80211/mlme.c
2008-05-22sky2: restore vlan acceleration on resetStephen Hemminger
If device has to be reset by sky2_restart, then need to restore the VLAN acceleration settings. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-13[netdrvr] Trim trailing whitespace for several driversJeff Garzik
2008-04-12sky2: missing chip name for Yukon SupremeStephen Hemminger
Any usage of sky2 on new Yukon Supreme would cause a NULL dereference. The chip is very new, so the support is still untested; vendor has not sent any eval hardware. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-02sky2: fix suspend/resume racesStephen Hemminger
There are a couple of possible races on suspend/resume. First the driver needs to block new packets from being queued for Tx. The other less likely problem is the watchdog timer going off during resume. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-24sky2: fix LED managementStephen Hemminger
Fix problems in LED management, so ethtool -p works correctly on Yukon-EC and other chips. The driver was incorrectly setting the PHY LED overide bits. Moral: read the spec sheet, not the vendor driver. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-05sky2: fix for Yukon FE (regression in 2.6.25)Stephen Hemminger
The Yukon FE chip has a ram buffer therefore it needs the alignment restriction and hang check workarounds. Therefore: * Autodetect the prescence/absence of ram buffer * Rename the flag value to reflect this * Use it consistently (ie don't reread register) Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-03sky2: fix Wake On Lan interaction with BIOSStephen Hemminger
This patch disables config mode access after clearing PCI settings. Some BIOS's seem to not do WOL if config bit still set. Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=9721 Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-03sky2: restore multicast addresses after recoveryStephen Hemminger
If the sky2 deadman timer forces a recovery, the multicast hash list is lost. Move the call to sky2_set_multicast to the end of sky2_up() so all paths that bring device up will restore multicast. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28sky2: version 1.21Stephen Hemminger
Update driver version reflects new hardware support. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28sky2: support for Yukon SupremeStephen Hemminger
Add support from sk98lin vendor driver 10.50.1.3 for 88E8055 and 88E8075 chips. I don't have this hardware to test, so this changes are untested. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28sky2: rx allocation threshold changeStephen Hemminger
When using larger MTU's sky2 driver changes from allocating one data area, to using multiple pages. The threshold for this was based on a heuristic where the cost of a single allocation is bigger than one page. Since the allocator has changed, this heuristic is now incorrect; instead just make the threshold be when the total size of the allocation is greater than one page. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28sky2: align IP header on Rx if possibleStephen Hemminger
The sky2 driver was not aligning the IP header on receive buffers. This workaround is only needed on hardware with broken FIFO, newer chips without FIFO can just DMA to unaligned address. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-18Revert "sky2: remove check for PCI wakeup setting from BIOS"Stephen Hemminger
This reverts commit 84cd2dfb04d23a961c5f537baa243fa54d0987ac. Some BIOS's break if Wake On Lan is enabled, and the machine can't boot. Better to have some user's have to call ethtool to enable WOL than to break a single user's boot. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-12sky2: remove check for PCI wakeup setting from BIOSStephen Hemminger
The driver checks status of PCI power management to mark default setting of Wake On Lan. On some systems this works, but often it reports a that WOL is disabled when it isn't. This patch gets rid of that check and just reports the wake on lan status based on the hardware capablity. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-12sky2: large memory workaround.Stephen Hemminger
This patch might fix problems with 4G or more of memory. It stops the driver from doing a small optimization for Tx and Rx, and instead always sets the high-page on tx/rx descriptors. Fixes-bug: http://bugzilla.kernel.org/show_bug.cgi?id=9725 Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-08[NET]: Fix drivers to handle napi_disable() disabling interrupts.David S. Miller
When we add the generic napi_disable_pending() breakout logic to net_rx_action() it means that napi_disable() can cause NAPI poll interrupt events to be disabled. And this is exactly what we want. If a napi_disable() is pending, and we are looping in the ->poll(), we want ->poll() event interrupts to stay disabled and we want to complete the NAPI poll ASAP. When ->poll() break out during device down was being handled on a per-driver basis, often these drivers would turn interrupts back on when '!netif_running()' was detected. And this would just cause a reschedule of the NAPI ->poll() in the interrupt handler before the napi_disable() could get in there and grab the NAPI_STATE_SCHED bit. The vast majority of drivers don't care if napi_disable() might have the side effect of disabling NAPI ->poll() event interrupts. In all such cases, when a napi_disable() is performed, the driver just disabled interrupts or is about to. However there were three exceptions to this in PCNET32, R8169, and SKY2. To fix those cases, at the subsequent napi_enable() points, I added code to ensure that the ->poll() interrupt events are enabled in the hardware. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Don Fry <pcnet32@verizon.net>
2007-12-14sky2: RX lockup fixStephen Hemminger
I'm using a Marvell 88E8062 on a custom PPC64 blade and ran into RX lockups while validating the sky2 driver. The receive MAC FIFO would become stuck during testing with high traffic. One port of the 88E8062 would lockup, while the other port remained functional. Re-inserting the sky2 module would not fix the problem - only a power cycle would. I looked over Marvell's most recent sk98lin driver and it looks like they had a "workaround" for the Yukon XL that the sky2 doesn't have yet. The sk98lin driver disables the RX MAC FIFO flush feature for all revisions of the Yukon XL. According to skgeinit.c of the sk98lin driver, "Flushing must be enabled (needed for ASF see dev. #4.29), but the flushing mask should be disabled (see dev. #4.115)". Nice. I implemented this same change in the sky2 driver and verified that the RX lockup I was seeing was resolved. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-04sky2: recovery deadlock fixStephen Hemminger
Prevent deadlock in sky2 recovery logic. sky2_down calls napi_synchronize which gets stuck if napi was already disabled. Fix by rearranging slightly and not calling napi_disable until after both ports are stopped. The napi_disable probably is being overly paranoid, but it is safe now. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-01sky2: turn of dynamic Tx watermark workaround (FE+ only)Stephen Hemminger
Add workaround for issues FE+ (A0) transmit watermark. This is copied verbatim from vendor driver sk98lin (10.22.4.3). Don't have that chip version and no more information seems to be available. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-01sky2: don't use AER routinesStephen Hemminger
Using PCIE advanced error recovery stuff creates more user problems than it's worth. The AER stuff depends on MMCONFIG and in many configurations it just doesn't work. Plus it doesn't add any real functionality to the driver. The sky2 driver handles its own errors fine as is. This reverts 555382cbfc6d2187b53888190755e56f52308cd6 Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-01sky2: revert to access PCI config via device spaceStephen Hemminger
Using the hardware window into PCI config space is more reliable and smaller/faster than using the pci_config routines. It avoids issues with MMCONFIG etc. Reverts: 167f53d05fccb47b6eeadac7f6705b3f2f042d03 Please apply for 2.6.24 Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-23sky2: disable rx checksum on Yukon XLStephen Hemminger
The Marvell Yukon XL chipset appears to have a hardware glitch where it will repeat the checksum of the last packet. Of course, this is timing sensitive and only happens sometimes... More info: http://bugzilla.kernel.org/show_bug.cgi?id=9381 As a workaround just disable hardware checksumming by default on this chip version. The earlier workaround for PCIX, dual port was also on Yukon XL so don't need to disable checksumming there. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-10sky2: new pci id'sStephen Hemminger
Found a couple of more chips in the latest version of the vendor driver. They are minor variations on existing chips. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-10sky2: netpoll on port 0 onlyStephen Hemminger
Netpoll will only work on port 0 because of the restrictive relationship between NAPI and netpoll. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-10sky2: version 1.20Stephen Hemminger
Version update to 1.20 Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-10sky2: handle advanced error recovery config issuesStephen Hemminger
The PCI AER support may not work for a couple of reasons. It may not be configured into the kernel or there may be a BIOS bug that prevents MMCONFIG from working. If MMCONFIG doesn't work then the PCI registers that control AER will not be accessible via pci_read_config functions; luckly there is another window to access PCI space in the device, so use that. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-10sky2: remove unneeded mask updateStephen Hemminger
The IRQ's is already masked on shutdown, and on startup avoid touching PHY until after phy_init(). Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-10sky2: dont change LED after autonegStephen Hemminger
Don't need to change LED's after auto negotiation, the chip sets them correctly. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
