path: root/drivers/net/skge.c
2006-04-12[PATCH] dlink pci cards using wrong driverStephen Hemminger
This patch fixes the problem of some Dlink cards picking the wrong driver. It looks like these cards use Yukon 1 chipset, not Yukon 2. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-23[PATCH] skge: version 1.5Stephen Hemminger
Update version to allow tracking of complaints. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-23[PATCH] skge: compute available ring buffersStephen Hemminger
Don't need to keep track of available buffers, it is simpler to just compute the value (ala e1000). Don't need tes on link up because should always have available buffers then. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-23[PATCH] skge: dont free skb until multi-part transmit completeStephen Hemminger
Don't free transmit buffers until the whole set of transmit descriptors has been marked as done. Otherwise, we risk freeing a skb before the whole transmit is done. This changes the transmit completion handling from incremental to a two pass algorithm. First pass scans and records the start of the last done descriptor, second cleans up until that point. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-23[PATCH] skge: multicast statistics fixStephen Hemminger
Fix count of multicast packets. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-23[PATCH] skge: rx_reuse called twiceStephen Hemminger
In the error case we call skge_rx_reuse twice. This is harmless but unnecessary. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-23[PATCH] skge: dont use dev_alloc_skb for rx buffsStephen Hemminger
The skge driver was using dev_alloc_skb which reserves space for the Ethernet header. This unnecessary and it should just use alloc_skb, also by using GFP_KERNEL during startup it won't run into problems when a user asks for a huge ring size or mtu and potentially drains the reserved atomic pool. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-23[PATCH] skge: align receive buffersStephen Hemminger
The skge driver aligns the header on the initial receive buffers, but but doesn't on followon receive buffer allocations. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-21[PATCH] skge: version 1.4Stephen Hemminger
Update version number Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-21[PATCH] skge: handle pci errors betterStephen Hemminger
When a PCI error occurs, try and report more info. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-21[PATCH] skge: formmating and whitespace cleanupStephen Hemminger
Reformat some code to make it easier to read. And whitespace fixes. Signed-off-by: Stephen Hemminger <sheminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-21[PATCH] skge: use mmiowbStephen Hemminger
Add mmio barriers at the appropriate places, don't have a platform that needs them, but this is where the documentation of the patch says to add them. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-21[PATCH] skge: use kcallocStephen Hemminger
Use kcalloc when allocating ring data structure. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-21[PATCH] skge: dma configuration cleanupStephen Hemminger
Cleanup of the part of the code that sets up DMA configuration. Should cause no real change in operation, just clearer. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-21[PATCH] skge: check the allocation of ring bufferStephen Hemminger
The SysKonnect Genesis and Yukon chip sets have restrictions on the possible control block area. The memory needs to not cross 4 Gig boundary, and it needs to be 8 byte aligned. This patch checks and fails to bring the device up if region is unacceptable. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-21[PATCH] skge: use auto masking of irqsStephen Hemminger
Improve performance of skge driver by not touching irq mask register as much. Since the interrupt source auto-masks, the driver can just leave it disabled until the end of the soft irq. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-21[PATCH] skge: use NAPI for tx cleanup.Stephen Hemminger
Cleanup transmit buffers using NAPI. This allows the transmit routine to leave interrupts enabled, and that improves performance. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-02-23skge: protect interrupt maskStephen Hemminger
There is a race between updating the irq mask and setting it which can be triggered on SMP with a bad cable. Similar patch from Ingo Molnar and Thomas Gleixner Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
2006-02-23skge: genesis phy initialzationStephen Hemminger
The SysKonnect Genesis based board would fail on initialization with phy_read errors caused by not waiting for last phy write. Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
2006-02-23skge: NAPI/irq race fixStephen Hemminger
Fix a race in the receive NAPI, irq handling. The interrupt clear and the start need to be separated. Otherwise there is a window between the last frame received and the NAPI done level handling. Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
2006-02-17[PATCH] skge: speed settingStephen Hemminger
This is a clone of John Linville's fixed for speed setting on sky2 driver. The skge driver has the same code (and bug). It would not allow manually forcing 100 and 10 mbit. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2006-01-17[PATCH] skge: fix dma mask setup.Stephen Hemminger
There are a couple of problems in the DMA setup code for skge. * In the 64 bit case, it doesn't set the consistent mask. * In the 32 bit case, the error check is backwards! It likely will only be visible as a bug on 64 bit platforms. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2006-01-04Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-24[PATCH] skge: error handling on resumeStephen Hemminger
Also have to handle out of memory condition on resume. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-12-24[PATCH] skge: version number (1.3)Stephen Hemminger
Enough changes for one version. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-12-24[PATCH] skge: handle out of memory on ring parameter changeStephen Hemminger
If changing ring parameters is unable to allocate memory, we need to return an error and take the device down. Fixes-bug: http://bugzilla.kernel.org/show_bug.cgi?id=5715 Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-12-24[PATCH] skge: handle out of memory on MTU size changesStephen Hemminger
Changing the MTU size causes the receiver to have to reallocate buffers. If this allocation fails, then we need to return an error, and take the device offline. It can then be brought back up or reconfigured for a smaller MTU. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-12-24[PATCH] skge: avoid up/down on pause param changesStephen Hemminger
Change the pause settings doesn't need to cause link to go down/up. It can be handled by the phy_reset code. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-12-24[PATCH] skge: avoid up/down on speed changesStephen Hemminger
Change the speed settings doesn't need to cause link to go down/up. It can be handled by doing the same logic as nway_reset. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-12-13[netdrvr skge] fix buildJeff Garzik
2005-12-12[PATCH] skge: get rid of warning on raceStephen Hemminger
Get rid of warning in case of race with ring full and lockless tx on the skge driver. It is possible to be in the transmit routine with no available slots and already stopped. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-12-01[netdrvr skge] fix typo, fix buildJeff Garzik
2005-12-01[PATCH] skge: handle VLAN checksum correctly on yukon rev 0Stephen Hemminger
If using UDP over VLAN, with the skge driver there is a possibility of generating an incorrect checksum. This is a unlikely occurrence because it is only an issue on Yukon revision 0, and that revision doesn't seem to exist on any current hardware (probably early prototype). Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-08[PATCH] skge: increase version numberStephen Hemminger
Increase the driver version number and print version when probing. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-08[PATCH] skge: spelling fixesStephen Hemminger
Fix some of my bad spelling. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-08[PATCH] skge: use prefetch on receiveStephen Hemminger
Use prefetch() in the interrupt path to try and look ahead at the next place will be looking at in the ring. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-08[PATCH] skge: goto low power mode on shutdownStephen Hemminger
Go into power down mode on shutdown. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-08[PATCH] skge: add mii ioctl supportStephen Hemminger
Basic MII ioctl support for skge driver. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-08[PATCH] skge: use kzallocStephen Hemminger
Can use kzalloc in skge driver. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-08[PATCH] skge: clear PCI PHY COMA mode on bootStephen Hemminger
When skge is booted up, the PHY may be stuck in power down state by the previous OS. So we may need to turn it on. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-03Merge branch 'upstream-fixes'Jeff Garzik
2005-10-03[PATCH] skge: set mac address oops with bondingStephen Hemminger
Skge driver was bringing link up/down when changing mac address. This doesn't work in the bonding environment, and is more effort than needed. Fixes-bug: http://bugzilla.kernel.org/show_bug.cgi?id=5271 Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-23[PATCH] skge: fix Yukon-Lite A0 workaroundStephen Hemminger
This is one of those workarounds sucked over from sk98lin driver. The skge driver needs to detect the Yukon-Lite A0 chip properly, and turn of Rx FIFO Flush. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-22Merge /spare/repo/linux-2.6/Jeff Garzik
2005-09-21Merge /spare/repo/linux-2.6/Jeff Garzik
2005-09-21[PATCH] skge: check length from PHYStephen Hemminger
Cleanup receive buffer allocation and management, Add more error handling checks from PHY and bump version. Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-21[PATCH] skge: expand ethtool debug register dumpStephen Hemminger
Expand the returned data for ethtool debug access to include all of the mapped PCI area; except for the small set of registers that are for diagnostic RAM access. Access to those registers will hang the system. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-14[PATCH] skge: gmac register access errors in dual portStephen Hemminger
Merge of four previous patches and the Kconfig fix * Remove debug printk's * whitespace cleanup and version number change * clear interrupts, reset phy, and reset hardware on shutdown * ignore 64bit counter overflow interrupts * fix a couple of places where second port could clobber state of first port. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-14[PATCH] skge: support ETHTOOL_GPERMADDRJohn W. Linville
Add support for ETHTOOL_GPERMADDR to skge. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
