path: root/drivers/net/skfp/smt.c
2010-05-17drivers/net: remove useless semicolonsJoe Perches
switch and while statements don't need semicolons at end of statement [ Fixup minor conflicts with recent wimax merge... -DaveM ] Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-17drivers/net/skfp: fix sparse warning: Should it be static?Hannes Eder
Impact: Move function declarations to header file. Fix this sparse warnings: drivers/net/skfp/cfm.c:146:6: warning: symbol 'all_selection_criteria' was not declared. Should it be static? drivers/net/skfp/drvfbi.c:186:6: warning: symbol 'mac1_irq' was not declared. Should it be static? drivers/net/skfp/drvfbi.c:284:6: warning: symbol 'read_address' was not declared. Should it be static? drivers/net/skfp/drvfbi.c:323:6: warning: symbol 'init_board' was not declared. Should it be static? drivers/net/skfp/fplustm.c:72:24: warning: symbol 'fddi_broadcast' was not declared. Should it be static? drivers/net/skfp/fplustm.c:679:6: warning: symbol 'mac2_irq' was not declared. Should it be static? drivers/net/skfp/fplustm.c:805:6: warning: symbol 'mac3_irq' was not declared. Should it be static? drivers/net/skfp/fplustm.c:856:5: warning: symbol 'init_fplus' was not declared. Should it be static? drivers/net/skfp/pcmplc.c:404:6: warning: symbol 'init_plc' was not declared. Should it be static? drivers/net/skfp/pcmplc.c:1592:5: warning: symbol 'pcm_status_twisted' was not declared. Should it be static? drivers/net/skfp/smtinit.c:68:5: warning: symbol 'init_smt' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-30net: use the common ascii hex helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28NULL noise in drivers/netAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10drivers/net/: all drivers/net/ cleanup with ARRAY_SIZEDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-06-01potential parse error in ifdefYoann Padioleau
I have made a tool to parse the kernel that does not pre-process the source. That means that my parser tries to parse all the code, including code in the #else branch or code that is not often compiled because the driver is not very used (or not used at all). So, my parser sometimes reports parse error not originally detected by gcc. Here is my (first) patch. [akpm@linux-foundation.org: fix amd8111e.c] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Acked-by: Matthew Wilcox <matthew@wil.cx> Acked-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Jeff Garzik <jeff@garzik.org> Acked-by: James Bottomley <James.Bottomley@steeleye.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-05net: use bitrev8Akinobu Mita
Use bitrev8 for bmac, mace, macmace, macsonic, and skfp drivers. [akpm@osdl.org: use the API, not the array] Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mirko Lindner <mlindner@syskonnect.de> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2005-10-30[PATCH] sparse cleanups: NULL pointers, C99 struct init.Randy Dunlap
Convert most of the remaining "Using plain integer as NULL pointer" sparse warnings to use NULL. (Not duplicating patches that are already in -mm, -bird, or -kj.) Convert isdn driver struct initializer to use C99 syntax. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] drivers/net/skfp/: cleanupsAdrian Bunk
This patch contains the following cleanups: - make needlessly global code static - remove the completely unused smtparse.c - remove the following unused global functions: - drvfbi.c: init_dma - drvfbi.c: dis_dma - drvfbi.c: get_rom_byte - drvfbi.c: mac_drv_vpd_read - drvfbi.c: mac_drv_pci_fix - fplustm.c: mac_set_func_addr - fplustm.c: mac_del_multicast - hwmtm.c: mac_drv_rx_frag - pcmplc.c: pcm_set_lct_short - smt.c: smt_please_reconnect - smt.c: smt_change_t_neg - smtdef.c: smt_set_defaults Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-06-26[PATCH] drivers/net/skfp/: fix LITTLE_ENDIANAdrian Bunk
This patch fixes the LITTLE_ENDIAN #define and a function prototype. Signed-off-by: Adrian Bunk <bunk@stusta.de>
