The intent here was to test if the allocation failed but we tested
"SharedMemSize" instead of "SharedMemAddr" by mistake.
Reviewed-by: Jiri Pirko <jpirko@redhat.com>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
To avoid more patches, I also fixed other spelling
and grammar bugs when they were in the same or
following line:
successfull -> successful
parse -> parses
controler -> controller
controlers -> controllers
Cc: Jiri Kosina <trivial@kernel.org>
Signed-off-by: Stefan Weil <weil@mail.berlios.de>
This patch removes from drivers/net/ all the unnecessary
return; statements that precede the last closing brace of
void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
It also does not remove null void functions with return.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
with some cleanups by hand.
Compile tested x86 allmodconfig only.
Now that core network takes care of trans_start updates, dont do it
in drivers themselves, if possible. Drivers can avoid one cache miss
(on dev->trans_start) in their start_xmit() handler.
Exceptions are NETIF_F_LLTX drivers
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss
anything). Used spatch and did small tweaks and conding style changes when
it was suitable.
Jirka
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section
in every case.
Use the %pMF kernel extension to display the MAC address.
The address will still be displayed in the FDDI Canonical format.
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
In a couple of cases collapse some extra code like:
int retval = NETDEV_TX_OK;
return retval;
into
return NETDEV_TX_OK;
This patch converts the remaining occurences of raw return values to their
symbolic counterparts in ndo_start_xmit() functions that were missed by the
previous automatic conversion.
Additionally code that assumed the symbolic value of NETDEV_TX_OK to be zero
is changed to explicitly use NETDEV_TX_OK.
This patch is the result of an automatic spatch transformation to convert
all ndo_start_xmit() return values of 0 to NETDEV_TX_OK.
Some occurences are missed by the automatic conversion, those will be
handled in a seperate patch.
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively.
0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases
where its in direct proximity to one of the other values.
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Impact: Move function declarations to header file.
Fix this sparse warnings:
drivers/net/skfp/cfm.c:146:6: warning: symbol 'all_selection_criteria' was not declared. Should it be static?
drivers/net/skfp/drvfbi.c:186:6: warning: symbol 'mac1_irq' was not declared. Should it be static?
drivers/net/skfp/drvfbi.c:284:6: warning: symbol 'read_address' was not declared. Should it be static?
drivers/net/skfp/drvfbi.c:323:6: warning: symbol 'init_board' was not declared. Should it be static?
drivers/net/skfp/fplustm.c:72:24: warning: symbol 'fddi_broadcast' was not declared. Should it be static?
drivers/net/skfp/fplustm.c:679:6: warning: symbol 'mac2_irq' was not declared. Should it be static?
drivers/net/skfp/fplustm.c:805:6: warning: symbol 'mac3_irq' was not declared. Should it be static?
drivers/net/skfp/fplustm.c:856:5: warning: symbol 'init_fplus' was not declared. Should it be static?
drivers/net/skfp/pcmplc.c:404:6: warning: symbol 'init_plc' was not declared. Should it be static?
drivers/net/skfp/pcmplc.c:1592:5: warning: symbol 'pcm_status_twisted' was not declared. Should it be static?
drivers/net/skfp/smtinit.c:68:5: warning: symbol 'init_smt' was not declared. Should it be static?
Signed-off-by: Hannes Eder <hannes@hanneseder.net>
Fix inverted logic
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
drivers/net/skfp/skfddi.c:620:13: warning: symbol 'skfp_interrupt' was not declared. Should it be static?
drivers/net/skfp/skfddi.c:687:25: warning: symbol 'skfp_ctl_get_stats' was not declared. Should it be static?
drivers/net/skfp/skfddi.c:1232:6: warning: symbol 'CheckSourceAddress' was not declared. Should it be static?
Similar to ethernet. Convert infrastructure and the one lone FDDI
driver (for the one lone user of that hardware??). Compile tested only.
The generic packet receive code takes care of setting
netdev->last_rx when necessary, for the sake of the
bonding ARP monitor.
Drivers need not do it any more.
Some cases had to be skipped over because the drivers
were making use of the ->last_rx value themselves.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Since hardware header operations are part of the protocol class
not the device instance, make them into a separate object and
save memory.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
It's been a useless no-op for long enough in 2.6 so I figured it's time to
remove it. The number of people that could object because they're
maintaining unified 2.4 and 2.6 drivers is probably rather small.
[ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ]
To clearly state the intent of copying to linear sk_buffs, _offset being a
overly long variant but interesting for the sake of saving some bytes.
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Now all the _type_trans routines are consistent in this regard.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
- Eliminate check for irq handler 'dev_id==NULL' where the
condition never occurs.
- Eliminate needless casts to/from void*
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com>
Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com>
Cc: Jeff Garzik <jeff@garzik.org>
This patch contains the following cleanups:
- make needlessly global code static
- remove the completely unused smtparse.c
- remove the following unused global functions:
- drvfbi.c: init_dma
- drvfbi.c: dis_dma
- drvfbi.c: get_rom_byte
- drvfbi.c: mac_drv_vpd_read
- drvfbi.c: mac_drv_pci_fix
- fplustm.c: mac_set_func_addr
- fplustm.c: mac_del_multicast
- hwmtm.c: mac_drv_rx_frag
- pcmplc.c: pcm_set_lct_short
- smt.c: smt_please_reconnect
- smt.c: smt_change_t_neg
- smtdef.c: smt_set_defaults
infrastructure for it.
Let it rip!
