path: root/drivers/net/sh_eth.c
2011-03-14net: sh_eth: add set_mdio_gate in bb_infoYoshihiro Shimoda
The SH7757's ETHER and GETHER use common MDIO pin. The MDIO pin is selected by specific register. So this patch adds new interface in bb_info, and when the sh_eth driver use the mdio, the register can be changed by the function. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-14net: sh_eth: add support for SH7757's GETHERYoshihiro Shimoda
The SH7757 have GETHER and ETHER both. This patch supports them. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-14net: sh_eth: modify the PHY_INTERFACE_MODEYoshihiro Shimoda
The previous code had hardcoded the PHY_INTERFACE_MODE_MII of phy_connect. So some Gigabit PHYs will not behave correctly. The patch adds the phy_interface in sh_eth_plat_data, so we can select the phy interface. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-14net: sh_eth: remove almost #ifdef of SH7763Yoshihiro Shimoda
The SH7763 has GETHER. So the specification of some registers differs than other CPUs. This patch removes almost #ifdef of CONFIG_CPU_SUBTYPE_SH7763. Then we are able to add other CPU's GETHER easily. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-14net: sh_eth: remove the SH_TSU_ADDRYoshihiro Shimoda
The defination is hardcoded in this driver for some CPUs. This patch modifies to get resource of TSU address from platform_device. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-14net: sh_eth: modify the definitions of registerYoshihiro Shimoda
The previous code cannot handle the ETHER and GETHER both as same time because the definitions of register was hardcoded. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-22sh: sh_eth: Add support ethtoolNobuhiro Iwamatsu
This commit supports following functions. - get_settings - set_settings - nway_reset - get_msglevel - set_msglevel - get_link - get_strings - get_ethtool_stats - get_sset_count About other function, the device does not support. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-12drivers/net: remove unnecessary flush_scheduled_work() callsTejun Heo
janz-ican3, sh_eth, skge and vxge don't use workqueue at all and there is no reason to flush the system_wq. Drop flush_scheduled_work() calls and references to workqueue. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Ramkrishna Vepa <ramkrishna.vepa@exar.com> Cc: Sivakumar Subramani <sivakumar.subramani@exar.com> Cc: Sreenivasa Honnur <sreenivasa.honnur@exar.com> Cc: Jon Mason <jon.mason@exar.com> Cc: netdev@vger.kernel.org
2010-11-15net: sh_eth: Move off of deprecated I/O routines.Paul Mundt
sh_eth is the last in-tree user of the ctrl_xxx I/O routines. This simply converts them over to regular MMIO accesors. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-02drivers/net: avoid some skb->ip_summed initializationsEric Dumazet
fresh skbs have ip_summed set to CHECKSUM_NONE (0) We can avoid setting again skb->ip_summed to CHECKSUM_NONE in drivers. Introduce skb_checksum_none_assert() helper so that we keep this assertion documented in driver sources. Change most occurrences of : skb->ip_summed = CHECKSUM_NONE; by : skb_checksum_none_assert(skb); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-25drivers/net: Remove address use from assignments of function pointersJoe Perches
"foo = &function" is more commonly written "foo = function" Done with coccinelle script: // <smpl> @r@ identifier f; @@ f(...) { ... } @@ identifier r.f; @@ - &f + f // </smpl> drivers/net/tehuti.c used a function and struct with the same name, the function was renamed. Compile tested x86 only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-19net: sh_eth: remove unused variableKuninori Morimoto
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-08-04Fix spelling contorller -> controller in commentsStefan Weil
Cc: Jiri Kosina <trivial@kernel.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Stefan Weil <weil@mail.berlios.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-18net: preserve ifreq parameter when calling generic phy_mii_ioctl().Richard Cochran
The phy_mii_ioctl() function unnecessarily throws away the original ifreq. We need access to the ifreq in order to support PHYs that can perform hardware time stamping. Two maverick drivers filter the ioctl commands passed to phy_mii_ioctl(). This is unnecessary since phylib will check the command in any case. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-07net: sh_eth: add support for SH7757's ETHERYoshihiro Shimoda
The SH7757 has 2 Fast Ethernet controller (ETHER) and 2 Gigabit Ethernet Controller (GETHER). This patch supports 2 ETHER only. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-20sh_eth: Fix memleak in sh_mdio_releaseDenis Kirjanov
Allocated memory for IRQs should be freed when releasing the mii_bus Signed-off-by: Denis Kirjanov <dkirjanov@kernel.org> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-10Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/benet/be_cmds.h include/linux/sysctl.h
2010-01-03net: Test off by one in sh_eth_reset()roel kluin
If no break occurred, cnt reaches 0 after the loop. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-29Subject: drivers/net/sh_eth.c: use %pM to shown MAC addressH Hartley Sweeten
Use the %pM kernel extension to display the MAC address. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-15net: sh_eth alignment fix for sh7724 using NET_IP_ALIGN V2Magnus Damm
Fix sh_eth for sh7724 by adding NET_IP_ALIGN support V2. Without this patch the receive data is misaligned. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18drivers/net: request_irq - Remove unnecessary leading & from second argJoe Perches
Not as fancy as coccinelle. Checkpatch errors ignored. Compile tested allyesconfig x86, not all files compiled. grep -rPl --include=*.[ch] "\brequest_irq\s*\([^,\)]+,\s*\&" drivers/net | while read file ; do \ perl -i -e 'local $/; while (<>) { s@(\brequest_irq\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\ done Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sh_eth.c
2009-10-26sh_eth: Add asm/cacheflush.hNobuhiro Iwamatsu
Add include asm/cacheflush.h, because declaration of __flush_purge_region moved to asm/cacheflush.h. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13net: add Runtime PM to the sh_eth driverMagnus Damm
Add Runtime PM support to the sh_eth driver. The clock to the ethernet hardware block will be enabled as long as the network device is up. Signed-off-by: Magnus Damm <damm@opensource.se> Tested-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13net: allow sh_eth to get mac address through platform dataMagnus Damm
Extend the sh_eth driver to allow passing the mac address using the platform data structure. This to simplify board setup code. Signed-off-by: Magnus Damm <damm@opensource.se> Tested-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-29net: sh_eth: add value of ether_link pin in platform_dataYoshihiro Shimoda
The method of ETHER_LINK pin is board dependence. This patch adding paramters are: - no_ether_link : If set to 1, do not use ETHER_LINK - ether_link_active_low : If set to 1, ETHER_LINK is active low. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25sh_eth: remove redundant test on unsignedroel kluin
Unsigned boguscnt cannot be less than 0. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13net: use symbolic values for ndo_start_xmit() return codesPatrick McHardy
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively. 0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases where its in direct proximity to one of the other values. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-26sh_eth: Remove references to BUS_ID_SIZE, use MII_BUS_ID_SIZE instead.David S. Miller
2009-05-25net: sh_eth: Add support SH7724Yoshihiro Shimoda
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-25net: sh_eth: CPU dependency code collect to "struct sh_eth_cpu_data"Yoshihiro Shimoda
This improves readability by collecting CPU dependency code. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-25net: sh_eth: fix receive desciptor loopYoshihiro Shimoda
Fix the problem that this driver not update rxdesc in sh_eth_rx. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-25net: sh_eth: fix TX/RX descriptor not set physical memoryYoshihiro Shimoda
Fix the probrem that TX/RX descirptor not set physical memory. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-25net: sh_eth: fix cache coherency issueYoshihiro Shimoda
Fix the problem that may not work receive process by cache coherency issue. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-13sh_eth: convert to net_device_opsAlexander Beregalov
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-18sh_eth: Change handling of IRQNobuhiro Iwamatsu
Handling of IRQ of the SH7763/SH7764 CPU which sh_eth supported was changed. This revises it for this change. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ixgbe/ixgbe_main.c include/net/mac80211.h net/phonet/af_phonet.c
2008-11-20sh: sh_eth: Update to change of mii_busNobuhiro Iwamatsu
Update to change of mii_bus interface and fix some warning. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-10net: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Marcel Holtmann <marcel@holtmann.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-20Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/kernel-parameters.txt arch/sh/include/asm/elf.h
2008-10-08phylib: move to dynamic allocation of struct mii_busLennert Buytenhek
This patch introduces mdiobus_alloc() and mdiobus_free(), and makes all mdio bus drivers use these functions to allocate their struct mii_bus'es dynamically. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Andy Fleming <afleming@freescale.com>
2008-10-08phylib: rename mii_bus::dev to mii_bus::parentLennert Buytenhek
In preparation of giving mii_bus objects a device tree presence of their own, rename struct mii_bus's ->dev argument to ->parent, since having a 'struct device *dev' that points to our parent device conflicts with introducing a 'struct device dev' representing our own device. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Andy Fleming <afleming@freescale.com>
2008-09-11sh_eth: unsigned ndev->irq cannot be negativeroel kluin
unsigned ndev->irq cannot be negative Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-08-14[netdrvr] remove unnecessary #includeHuang Weiyi
The drivers below do not use LINUX_VERSION_CODE nor KERNEL_VERSION. drivers/net/acenic.c drivers/net/bnx2x_link.c drivers/net/bnx2x_main.c drivers/net/cpmac.c drivers/net/gianfar_sysfs.c drivers/net/ipg.h drivers/net/ppp_mppe.c drivers/net/pppol2tp.c drivers/net/r6040.c drivers/net/sh_eth.c drivers/net/sky2.c drivers/net/tehuti.h drivers/net/typhoon.c This patch removes the said #include <linux/version.h>. Signed-off-by: Huang Weiyi <hwy@cn.fujitsu.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-07[netdrvr] sh_eth: Add SH7619 supportYoshinori Sato
Add support SH7619 Internal ethernet controler. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
