path: root/drivers/net/sfc
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-25Merge branch 'master' of ↵David S. Miller
2010-02-19sfc: SFE4002/SFN4112F: Widen temperature and voltage tolerancesBen Hutchings
The temperature and voltage limits currently set on these boards are too conservative and will cause the driver to stop the net device erroneously in some systems. Based on a review of the chip datasheets and advice from the designer of these boards: - Raise the maximum board temperatures to the specified maximum ambient temperatures for their PHYs plus the expected temperature bias of the board - Raise the maximum controller temperature to 90 degrees - Lower the minimum temperatures to 0 degrees - Widen the voltage tolerances to at least +/- 10% Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-19sfc: Fix sign of efx_mcdi_poll_reboot() error in efx_mcdi_poll()Ben Hutchings
efx_mcdi_poll() uses positive error numbers, matching the MCDI protocol. It must negate the result of efx_mcdi_poll_reboot() which returns the usual negative error numbers. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-18net: convert multiple drivers to use netdev_for_each_mc_addr, part2Jiri Pirko
Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/rate.c
2010-02-12sfc: Fix SFE4002 initialisationSteve Hodgson
From: Steve Hodgson <shodgson@solarflare.com> Commit 357d46a17e54c9a87e0e6ef3930ff4ab2d232b81 "sfc: QT202x: Remove unreliable MMD check at initialisation" broke initialisation of the SFE4002. efx_mdio_reset_mmd() returns a positive value rather than 0 on success. The above commit causes this value to be propagated up by qt202x_reset_phy(), which is treated as a failure by its callers. Change qt202x_reset_phy() to return 0 if successful. The PCI layer treats >0 as "fail, but please call remove() anyway", which means that unloading the driver would cause a crash. Add a WARN_ON() on the failure path of efx_pci_probe() to provide early warning if there are any other cases where we do this. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-03sfc: Do not include unneeded headersBen Hutchings
Earlier refactoring has made these inclusions unnecessary. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03sfc: Fix some incorrect or redundant commentsBen Hutchings
In particular, the comment about EVQ_RPTR_REG is based on inconsistent preliminary hardware documentation, though the following code was fixed long before release. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03sfc: Remove declarations of nonexistent functionsBen Hutchings
2010-02-03sfc: Add some missing bits to register self-test masksSteve Hodgson
2010-02-03sfc: Survive ISR0=0 bug in the shared IRQ caseGuido Barzini
2010-02-03sfc: Implement NVRAM selftest for SFC9000 familyBen Hutchings
2010-02-03sfc: Replace PHY MDIO test with an 'alive' testBen Hutchings
SFC9000-family boards do not all use MDIO PHYs, so we need a different test for PHY aliveness. Introduce a PHY operation test_alive(). For PHYs attached to Falcon, use a common implementation based on the existing PHY MDIO test. For PHYs managed through MCDI, use the appropriate MCDI request. Change test name in ethtool from 'core mdio' to 'phy alive'. Rename test_results::mdio to phy_alive and test_results::phy to phy_ext. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03sfc: Enable autonegotiated flow-control by default if supportedSteve Hodgson
2010-02-03sfc: Handle firmware assertion failure while resettingSteve Hodgson
This allows the driver to recover if the MC firmware has crashed due to an assertion failure. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03sfc: Update MCDI protocol definitionsBen Hutchings
2010-01-28Merge branch 'master' of ↵David S. Miller
2010-01-25sfc: Use fixed-size buffers for MCDI NVRAM requestsBen Hutchings
The low-level MCDI code always uses 32-bit MMIO operations, and callers must pad input and output buffers to multiples of 4 bytes. The MCDI NVRAM functions are not doing this. Also, their buffers are declared as variable-length arrays with no explicit maximum length. Switch to a fixed buffer size based on the chunk size used by the MTD driver (which is a multiple of 4). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-25sfc: Add workspace for GMAC bug workaround to MCDI MAC_STATS bufferGuido Barzini
Due to a hardware bug in the SFC9000 family, the firmware must transfer raw GMAC statistics to host memory before aggregating them into the cooked (speed-independent) MAC statistics. Extend the stats buffer to support this. The length of the buffer is explicit in the MAC_STATS command, so this change is backward-compatible on both sides. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23Merge branch 'master' of ↵David S. Miller
2010-01-19sfc: QT202x: Remove unreliable MMD check at initialisationMatthew Slattery
Checking the PHY XS MMD here is unnecessary and can give false negatives. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-13sfc: Fix conditions for MDIO self-testBen Hutchings
The MDIO self-test should not be run on boards without an MDIO PHY, such as SFN5122F-R3 and later revisions. It should also not try to address a specific MMD in an MDIO clause 22 PHY. Check the mode_support field to decide which mode to use, if any. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-13sfc: Fix polling for slow MCDI operationsBen Hutchings
When the interface is down and we are using polled mode for MCDI operations, we busy-wait for completion for approximately 1 jiffy using udelay() and then back off to schedule(). But the completion will not wake the task, since we are using polled mode! We must use schedule_timeout_uninterruptible() instead. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-10Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/benet/be_cmds.h include/linux/sysctl.h
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-23sfc: Disable TX descriptor prefetch watchdogBen Hutchings
This hardware watchdog can misfire, so it does more harm than good. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-23sfc: QT2025C: Add error message for suspected bad SFP+ cablesBen Hutchings
Some cables have EEPROMs that conflict with the PHY's on-board EEPROM so it cannot load firmware. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-23sfc: QT2025C: Work around PHY firmware initialisation bugMatthew Slattery
The PHY's firmware very occasionally appears to lock up very early, but with the heartbeat update still running. Rebooting the microcontroller core seems to be sufficient to recover. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-23sfc: QT2025C: Switch into self-configure mode when not in loopbackMatthew Slattery
The PHY boots in a mode which is not necessarily optimal. This change switches it to self-configure mode (except when in loopback, which won't work in that mode if an SFP+ module is not present) by rebooting the PHY's microcontroller, and replicating the sequence of configuration writes from the boot EEPROM with the appropriate changes. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-23sfc: QT2025C: Work around PHY bugMatthew Slattery
If we see the PHY remaining stuck in a link-down state due to PCS being down while PMA/PMD is up, we briefly switch to PMA/PMD loopback and back, which usually unsticks it. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-23sfc: Fix DMA mapping cleanup in case of an error in TSONeil Turton
We need buffer->len to remain valid to work out the correct address to be unmapped. We therefore need to clear buffer->len after the unmap operation. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-23sfc: Include XGXS in XMAC link status check except in XGMII loopbackBen Hutchings
The XGXS block may not get a link immediately in XGXS or XAUI loopback modes, so we still need to check it. Split falcon_xaui_link_ok() into falcon_xgxs_link_ok(), which checks only the Falcon XGXS block, and falcon_xmac_link_ok(), which checks one or both sides of the link as appropriate. Also rename falcon_check_xaui_link() to falcon_xmac_link_ok_retry(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-23sfc: Move PHY software state initialisation from init() into probe()Steve Hodgson
This prevents efx->link_advertising from being blatted during a reset. The phy_short_reach sysfs node is now destroyed later in the port shutdown process, so check for STATE_RUNNING after acquiring the rtnl_lock (just like in set_phy_flash_cfg). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-13drivers/net/sfc: Correct code taking the size of a pointerJulia Lawall
The function efx_iterate_state contains the code memcpy(&payload->msg, payload_msg, sizeof(payload_msg)); This is the only use of payload_msg. The type of payload_msg is changed from a pointer to an array, so that the result of sizeof really is the length of the string. A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression *x; expression f; type T; @@ *f(...,(T)x,...) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Update version, copyright dates, authorsBen Hutchings
This driver has been mostly rewritten since Michael Brown's initial work, so swap the order of the authors. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Implement TSO for TCP/IPv6Ben Hutchings
2009-11-29sfc: Add support for SFC9000 family (2)Ben Hutchings
This integrates support for the SFC9000 family of 10G Ethernet controllers and LAN-on-motherboard chips, starting with the SFL9021 'Siena' and SFC9020 'Bethpage'. Credit for this code is largely due to my colleagues at Solarflare: Guido Barzini Steve Hodgson Kieran Mansley Matthew Slattery Neil Turton Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Add support for SFC9000 family (1)Ben Hutchings
This adds support for the SFC9000 family of 10G Ethernet controllers and LAN-on-motherboard chips, starting with the SFL9021 'Siena' and SFC9020 'Bethpage'. The SFC9000 family is based on the SFC4000 'Falcon' architecture, but with some significant changes: - Two ports are associated with two independent PCI functions (except SFC9010) - Integrated 10GBASE-T PHY(s) (SFL9021/9022) - MAC, PHY and board peripherals are managed by firmware - Driver does not require board-specific code - Firmware supports wake-on-LAN and lights-out management through NC-SI - IPv6 checksum offload and RSS - Filtering by MAC address and VLAN (not included in this code) - PCI SR-IOV (not included in this code) Credit for this code is largely due to my colleagues at Solarflare: Guido Barzini Steve Hodgson Kieran Mansley Matthew Slattery Neil Turton Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Add firmware protocol definitions (MCDI)Steve Hodgson
2009-11-29sfc: Move shared NIC code from falcon.c to new source file nic.cBen Hutchings
2009-11-29sfc: Rename falcon.h to nic.hBen Hutchings
nic.h is no longer specific to Falcon. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Allow for additional checksum offload featuresBen Hutchings
2009-11-29sfc: Extend MTD driver for use with new NICsBen Hutchings
In new NICs flash is managed by firmware and we will use high-level operations on partitions rather than direct SPI commands. Add support for multiple MTD partitions per flash device and remove the direct link between MTD and SPI devices. Maintain a list of MTD partitions in struct efx_nic. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Remove static PHY data and enumerationsBen Hutchings
New NICs have firmware managing the PHY, and we will discover the PHY capabilities at run-time. Replace the static data with probe() and test_name() operations. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Extend loopback mode enumerationBen Hutchings
New NICs and PHYs support a wider variety of loopback modes. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Fold falcon_probe_nic_variant() into falcon_probe_nic()Ben Hutchings
falcon_probe_nic_variant() does a lot less than it used to, and a lot less than it claims to. Fold the remainder into its caller. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Separate shared NIC code from Falcon-specific and rename accordinglyBen Hutchings
