path: root/drivers/net/sfc/enum.h
2009-11-29sfc: Update version, copyright dates, authorsBen Hutchings
This driver has been mostly rewritten since Michael Brown's initial work, so swap the order of the authors. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Add support for SFC9000 family (2)Ben Hutchings
This integrates support for the SFC9000 family of 10G Ethernet controllers and LAN-on-motherboard chips, starting with the SFL9021 'Siena' and SFC9020 'Bethpage'. Credit for this code is largely due to my colleagues at Solarflare: Guido Barzini Steve Hodgson Kieran Mansley Matthew Slattery Neil Turton Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Extend loopback mode enumerationBen Hutchings
New NICs and PHYs support a wider variety of loopback modes. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-24sfc: Log interrupt and reset type names, not numbersBen Hutchings
Define name tables for these enumerations in a similar way as for loopback. Move the loopback name table together with them. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-12sfc: Add support for Solarflare 10Xpress SFT9001Ben Hutchings
Add type codes for the new PHY and rename the SFX7101 type code. Add definition of clause 22 extension MMD. Adapt the 10Xpress SFX7101 code to support the SFT9001 as well. Clean up register definitions. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-12sfc: Add support for sub-10G speedsBen Hutchings
The SFC4000 has a separate MAC for use at sub-10G speeds. Introduce an efx_mac_operations structure with implementations for the two MACs. Switch between the MACs as necessary. PHY settings are independent of the MAC, so add get_settings() and set_settings() to efx_phy_operations. Also add macs field to indicate which MACs the PHY is connected to. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-06sfc: Do not reset when hardware monitor detects a faultBen Hutchings
The TX watchdog should trigger a reset, but a temperature/power alarm should not as this is unlikely to solve the problem. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-03sfc: Use explicit bool for boolean variables, parameters and return valuesBen Hutchings
Replace (cond ? 1 : 0) with cond or !!cond as appropriate, and (cond ? 0 : 1) with !cond. Remove some redundant boolean temporaries. Rename one field that looks like a flag but isn't. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-13[netdrvr] sfc: sfc: Add self-test supportBen Hutchings
Add a set of self-tests accessible thorugh ethtool. Add hardware loopback and TX disable control code to support them. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29New driver "sfc" for Solarstorm SFC4000 controller.Ben Hutchings
The driver supports the 10Xpress PHY and XFP modules on our reference designs SFE4001 and SFE4002 and the SMC models SMC10GPCIe-XFP and SMC10GPCIe-10BT. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
