path: root/drivers/net/sfc/efx.c
2011-03-23sfc: Siena: Disable write-combining when SR-IOV is enabledSteve Hodgson
If SR-IOV is enabled by firmware, even if it is not enabled in the PCI capability, TX pushes using write-combining may be corrupted. We want to know whether it is enabled before mapping the NIC registers, and even if PCI extended capabilities are not accessible. Therefore, we look for the MSI capability, which is removed if SR-IOV is enabled. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-03-04sfc: Use write-combining to reduce TX latencyBen Hutchings
Based on work by Neil Turton <nturton@solarflare.com> and Kieran Mansley <kmansley@solarflare.com>. The BIU has now been verified to handle 3- and 4-dword writes within a single 128-bit register correctly. This means we can enable write- combining and only insert write barriers between writes to distinct registers. This has been observed to save about 0.5 us when pushing a TX descriptor to an empty TX queue. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-28sfc: Update copyright datesBen Hutchings
2011-02-17sfc: Implement hardware acceleration of RFSBen Hutchings
Use the existing filter management functions to insert TCP/IPv4 and UDP/IPv4 4-tuple filters for Receive Flow Steering. For each channel, track how many RFS filters are being added during processing of received packets and scan the corresponding number of table entries for filters that may be reclaimed. Do this in batches to reduce lock overhead. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-15sfc: Add TX queues for high-priority trafficBen Hutchings
Implement the ndo_setup_tc() operation with 2 traffic classes. Current Solarstorm controllers do not implement TX queue priority, but they do allow queues to be 'paced' with an enforced delay between packets. Paced and unpaced queues are scheduled in round-robin within two separate hardware bins (paced queues with a large delay may be placed into a third bin temporarily, but we won't use that). If there are queues in both bins, the TX scheduler will alternate between them. If we make high-priority queues unpaced and best-effort queues paced, and high-priority queues are mostly empty, a single high-priority queue can then instantly take 50% of the packet rate regardless of how many of the best-effort queues have descriptors outstanding. We do not actually want an enforced delay between packets on best- effort queues, so we set the pace value to a reserved value that actually results in a delay of 0. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-15sfc: Distinguish queue lookup from test for queue existenceBen Hutchings
efx_channel_get_{rx,tx}_queue() currently return NULL if the channel isn't used for traffic in that direction. In most cases this is a bug, but some callers rely on it as an existence test. Add existence test functions efx_channel_has_{rx_queue,tx_queues}() and use them as appropriate. Change efx_channel_get_{rx,tx}_queue() to assert that the requested queue exists. Remove now-redundant initialisation from efx_set_channels(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-15sfc: Move TX queue core queue mapping into tx.cBen Hutchings
efx_hard_start_xmit() needs to implement a mapping which is the inverse of tx_queue::core_txq. Move the initialisation of tx_queue::core_txq next to efx_hard_start_xmit() to make the connection more obvious. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-01-13sfc: Restore the effect of the rss_cpus module parameterBen Hutchings
Commit a4900ac ("sfc: Create multiple TX queues") accidentally disabled the rss_cpus module parameter. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-01-13sfc: Make efx_get_tx_queue() an inline functionBen Hutchings
2010-12-10sfc: Remove ancient support for nesting of TX stopBen Hutchings
Long before this driver went into mainline, it had support for multiple TX queues per port, with lockless TX enabled. Since Linux did not know anything of this, filling up any hardware TX queue would stop the core TX queue and multiple hardware TX queues could fill up before the scheduler reacted. Thus it was necessary to keep a count of how many TX queues were stopped and to wake the core TX queue only when all had free space again. The driver also previously (ab)used the per-hardware-queue stopped flag as a counter to deal with various things that can inhibit TX, but it no longer does that. Remove the per-channel tx_stop_count, tx_stop_lock and per-hardware-queue stopped count and just use the networking core queue state directly. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2010-12-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath/ath9k/ar9003_eeprom.c net/llc/af_llc.c
2010-12-07sfc: Fix NAPI list corruption during ring reallocationBen Hutchings
Call netif_napi_{add,del}() on the NAPI contexts in the new and old channels, respectively. Since efx_init_napi() cannot fail, make its return type void. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2010-12-07sfc: Fix crash in legacy onterrupt handler during ring reallocationBen Hutchings
If we are using a legacy interrupt, our IRQ may be shared and our interrupt handler may be called even though interrupts are disabled on the NIC. When we change ring sizes, we reallocate the event queue and the interrupt handler may use an invalid pointer when called for another device's interrupt. Maintain a legacy_irq_enabled flag and test that at the top of the interrupt handler. Note that this problem results from the need to work around broken INT_ISR0 reads, and does not affect the legacy interrupt handler for Falcon A1. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2010-12-03sfc: Store MAC address from NVRAM in net_device::perm_addrBen Hutchings
For some reason we failed to make this change when perm_addr was introduced. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03sfc: Move mdio_lock to struct falcon_nic_dataBen Hutchings
We only have direct access to MDIO on Falcon, so move this out of struct efx_nic. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03sfc: Move SPI state to struct falcon_nic_dataBen Hutchings
We only have direct access to SPI on Falcon, so move all this state out of struct efx_nic. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03sfc: Remove unnecessary inclusion of various private header filesBen Hutchings
2010-10-21sfc: make functions staticstephen hemminger
Make local functions and variable static. Do some rearrangement of the string table stuff to put it where it gets used. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27sfc: Use netif_set_real_num_{rx,tx}_queues()Ben Hutchings
2010-09-21sfc: Clean up and correct comments on efx_monitor()Ben Hutchings
2010-09-21sfc: Add filter table managementBen Hutchings
2010-09-10sfc: Allow changing the DMA ring sizes dynamically via ethtoolBen Hutchings
This requires some reorganisation of channel setup and teardown to ensure that we can always roll-back a failed change. Based on work by Steve Hodgson <shodgson@solarflare.com> Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-10sfc: Make the dmaq size a run-time setting (rather than compile-time)Steve Hodgson
- Allow the ring size to be specified in non power-of-two sizes (for instance to limit the amount of receive buffers). - Automatically size the event queue. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-10sfc: Allocate each channel separately, along with its RX and TX queuesBen Hutchings
This will allow for reallocation of channel structures and rings. Change module parameter separate_tx_channels to be read-only, since we now require its value to be constant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-10sfc: Refactor channel and queue lookup and iterationBen Hutchings
In preparation for changes to the way channels and queue structures are allocated, revise the macros and functions used to look up and iterator over them. - Replace efx_for_each_tx_queue() with iteration over channels then TX queues - Replace efx_for_each_rx_queue() with iteration over channels then RX queues (with one exception, shortly to be removed) - Introduce efx_get_{channel,rx_queue,tx_queue}() functions to look up channels and queues by index - Introduce efx_channel_get_{rx,tx}_queue() functions to look up a channel's queues Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-10sfc: Fix failure paths in efx_probe_port()Ben Hutchings
2010-09-10sfc: Accumulate RX_NODESC_DROP count in rx_dropped, not rx_over_errorsBen Hutchings
rx_over_errors appears to be intended as a count of packets that overflow a packet buffer in the NIC. Given that we implement a cut-through receive path, this should always be 0. rx_dropped appears to be the correct counter for packets dropped due to lack of host buffers. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-07net: fix 64 bit counters on 32 bit archesEric Dumazet
There is a small possibility that a reader gets incorrect values on 32 bit arches. SNMP applications could catch incorrect counters when a 32bit high part is changed by another stats consumer/provider. One way to solve this is to add a rtnl_link_stats64 param to all ndo_get_stats64() methods, and also add such a parameter to dev_get_stats(). Rule is that we are not allowed to use dev->stats64 as a temporary storage for 64bit stats, but a caller provided area (usually on stack) Old drivers (only providing get_stats() method) need no changes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-30sfc: Add support for RX flow hash controlBen Hutchings
Allow ethtool to query the number of RX rings, the fields used in RX flow hashing and the hash indirection table. Allow ethtool to update the RX flow hash indirection table. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-25sfc: Move siena_nic_data::ipv6_rss_key to efx_nic::rx_hash_keyBen Hutchings
We will use this hash key for Toeplitz IPv4 hashing too. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-24sfc: Record hardware RX hash on each skb where possibleBen Hutchings
2010-06-24sfc: Replace EFX_DRIVER_NAME with KBUILD_MODNAMEBen Hutchings
2010-06-24sfc: Implement message level controlBen Hutchings
Replace EFX_ERR() with netif_err(), EFX_INFO() with netif_info(), EFX_LOG() with netif_dbg() and EFX_TRACE() and EFX_REGDUMP() with netif_vdbg(). Replace EFX_ERR_RL(), EFX_INFO_RL() and EFX_LOG_RL() using explicit calls to net_ratelimit(). Implement the ethtool operations to get and set message level flags, and add a 'debug' module parameter for the initial value. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-12sfc: Implement 64-bit net device statistics on all architecturesBen Hutchings
2010-06-02sfc: Only count bad packets in rx_errorsBen Hutchings
rx_errors is defined as 'bad packets received', but we are currently including various overflow errors as well. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02sfc: Allow shared pages to be recycledSteve Hodgson
Insert a structure at the start of the shared page that tracks the dma mapping refcnt. DMA into the next cache line of the (shared) page (plus EFX_PAGE_IP_ALIGN). When recycling a page, check the page refcnt. If the page is otherwise unused, then resurrect the other receive buffer that previously referenced the page. Be careful not to overflow the receive ring, since we can now resurrect n receive buffers in a row. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02sfc: Remove efx_rx_queue::add_lockSteve Hodgson
Ensure that efx_fast_push_rx_descriptors() must only run from efx_process_channel() [NAPI], or when napi_disable() has been executed. Reimplement the slow fill by sending an event to the channel, so that NAPI runs, and hanging the subsequent fast fill off the event handler. Replace the sfc_refill workqueue and delayed work items with a timer. We do not need to stop this timer in efx_flush_all() because it's safe to send the event always; receiving it will be delayed until NAPI is restarted. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02sfc: Workaround flush failures on Falcon B0Steve Hodgson
Under certain conditions a PHY may backpressure Falcon B0 in such a way that flushes timeout. In normal circumstances the phy poller would fix the PHY, and the flush could complete. But efx_nic_flush_queues() is always called after efx_stop_all(), so the poller has been stopped. Even if this weren't the case, how long would we have to wait for the poller to fix this? And several callers of efx_nic_flush_queues() are about to reset the device anyway - so we don't need to do anything. Work around this bug by scheduling a reset. Ensure that the MAC is never rewired back into the datapath before the reset runs (we already ignore all rx events anyway). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02sfc: Reschedule any resets scheduled inside efx_pm_freeze()Steve Hodgson
efx_pm_freeze() sets efx->state = STATE_FINI, which means efx_reset_work() will abort any scheduled resets. efx_pm_thaw() should reschedule efx_reset_work() again, since a freeze/thaw will not have reset the hardware. This bug was spotted by inspection - there is no real world example of this happening. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-02Merge branch 'master' of ↵David S. Miller
2010-04-28sfc: Create multiple TX queuesBen Hutchings
Create a core TX queue and 2 hardware TX queues for each channel. If separate_tx_channels is set, create equal numbers of RX and TX channels instead. Rewrite the channel and queue iteration macros accordingly. Eliminate efx_channel::used_flags as redundant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28sfc: Break NAPI processing after one ring-full of TX completionsBen Hutchings
Currently TX completions do not count towards the NAPI budget. This means a continuous stream of TX completions can cause the polling function to loop indefinitely with scheduling disabled. To avoid this, follow the common practice of reporting the budget spent after processing one ring-full of TX completions. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28sfc: Always close net device at the end of a disabling resetBen Hutchings
This fixes a regression introduced by commit eb9f6744cbfa97674c13263802259b5aa0034594 "sfc: Implement ethtool reset operation". Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-18net: convert multiple drivers to use netdev_for_each_mc_addr, part2Jiri Pirko
2010-02-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/rate.c
2010-02-12sfc: Fix SFE4002 initialisationSteve Hodgson
From: Steve Hodgson <shodgson@solarflare.com> Commit 357d46a17e54c9a87e0e6ef3930ff4ab2d232b81 "sfc: QT202x: Remove unreliable MMD check at initialisation" broke initialisation of the SFE4002. efx_mdio_reset_mmd() returns a positive value rather than 0 on success. The above commit causes this value to be propagated up by qt202x_reset_phy(), which is treated as a failure by its callers. Change qt202x_reset_phy() to return 0 if successful. The PCI layer treats >0 as "fail, but please call remove() anyway", which means that unloading the driver would cause a crash. Add a WARN_ON() on the failure path of efx_pci_probe() to provide early warning if there are any other cases where we do this. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
