path: root/drivers/net/sc92031.c
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-30sc92031: remove bogus unlikely()Cesar Eduardo Barros
Commit 5a0a92e67b5009a71e011658da04fb92dad8961f mentions len < ETH_ZLEN is true for ARP packets. This obviously is not unlikely. Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-22[SC92031] Using padto turned driver into an IPv6-only interfaceGerrit Renker
IPv4 would work with this driver only with static arp table entries, the patch reverts a padto introduced in commit 26a17b7bbb36a8552d531bc1ad08472fb5aa3007 sc92031: start transmit return value bugfix The padto does not work because the driver code evaluates `len' later on and there are cases where skb->len is not updated accordingly. This was observed with ARP frames (skb->len = 42 bytes, !skb_cloned(), skb_tailroom = 84 bytes). Then in skb_pad(), the first condition is true, where skb->len is not updated. As a consequence, the driver uses 42 bytes instead of the 60 bytes, and the ARP frame never makes it onto the wire. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16sc92031: use netdev_alloc_skbStephen Hemminger
Use netdev_alloc_skb since it handles any NUMA node memory localtion issues and sets skb->dev. Since device driver was not setting skb->dev, I bet filter rules based on device would not work. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16sc92031: start transmit return value bugfixStephen Hemminger
Any negative return value from start_xmit is interpreted as NETDEV_TX_LOCK which is not what this driver wants. It should return 0 (NETDEV_TX_OK) when it consumes a packet. Also, use skb_padto() as the generic way to pad small frames. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16sc92031: use net_device statsStephen Hemminger
Statistics structure is available for use in net_device structure. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-12sc92031: sysfs link missingStephen Hemminger
Add missing sysfs device association. Compile tested only -ENOHW. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=10380 Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Cc: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: <tom@sharkbay.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-10[netdrvr] Stop using legacy hooks ->self_test_count, ->get_stats_countJeff Garzik
These have been superceded by the new ->get_sset_count() hook. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[ETHTOOL] Provide default behaviors for a few ethtool sub-ioctlsJeff Garzik
For the operations get-tx-csum get-sg get-tso get-ufo the default ethtool_op_xxx behavior is fine for all drivers, so we permit op==NULL to imply the default behavior. This provides a more uniform behavior across all drivers, eliminating ethtool(8) "ioctl not supported" errors on older drivers that had not been updated for the latest sub-ioctls. The ethtool_op_xxx() functions are left exported, in case anyone wishes to call them directly from a driver-private implementation -- a not-uncommon case. Should an ethtool_op_xxx() helper remain unused for a while, except by net/core/ethtool.c, we can un-export it at a later date. [ Resolved conflicts with set/get value ethtool patch... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[NET]: ethtool_perm_addr only has one implementationMatthew Wilcox
All drivers implement ethtool get_perm_addr the same way -- by calling the generic function. So we can inline the generic function into the caller and avoid going through the drivers. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-09[SC92031]: Fix priv->lock contextHerbert Xu
The spin_lock calls made in dev->open and dev->close must disable BH since open/close are made in process context. Conversely, the call in dev->hard_start_xmit does not need to disable BH since it is already executing with BH disabled. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixups 2Thomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users in -mm. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-05driver for Silan SC92031 netdevCesar Eduardo Barros
This is a driver for the Silan SC92031/Rsltek 8139D NIC chip. This chip is found on at least one counterfeit Encore ENL832-TX-RENT NIC [1], which came with a mini-CD with the 2.4 driver. A slightly older version of the driver was found at [2]. The main difference between them is that the newer one has a small bugfix in the RX path, a lot of gratuitous renaming of functions, all the printable strings changed to show as a "Rsltek 8139D" [sic], and a PCI ID of 8139 instead of 2031. The driver on this patch is a rewrite of the vendor drivers (based mostly on the older one). Changes from the previous patch sent to netdev: - Use MMIO instead of PIO - Changed TX bounce buffers allocation - Use skb_copy_and_csum_dev - Several small bug fixes - Tested for more than just a few minutes each time [1] See http://www.encore-usa.com/faq.php under ENL832-TX-RENT for more information [2] Look for SL_LINUX.ZIP (which is really a .tar.gz) at http://broadbandforum.in/dataone_Intex_LAN_cardlinux-t4207-s15.html [3] To compile on 2.6.17, simply add back the last argument to the interrupt handler in two places, and copy the boolean declarations from 2.6.19 [akpm@osdl.org: build fixes] Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
