path: root/drivers/net/s2io.c
2005-11-09Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07Merge git://git.tuxdriver.com/git/netdev-jwlJeff Garzik
2005-11-07[PATCH] drivers/net/s2io.c: make functions staticAdrian Bunk
This patch makes needlessly global functions static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2005-11-05[netdrvr s2io] warning fixesJeff Garzik
From Andrew Morton.
2005-11-05[PATCH] S2io: Multi buffer mode supportAnanda Raju
Hi, This patch provides dynamic two buffer-mode and 3 buffer-mode options. Previously 2 buffer-mode was compilation option. Now with this patch applied one can load driver in 2 buffer-mode with module-load parameter ie. #insmod s2io.ko rx_ring_mode=2 This patch also provides 3 buffer-mode which provides header separation functionality. In 3 buffer-mode skb->data will have L2/L3/L4 headers and "skb_shinfo(skb)->frag_list->data" will have have L4 payload. one can load driver in 3 buffer-mode with same above module-load parameter ie. #insmod s2io.ko rx_ring_mode=3 Please review the patch. Signed-off-by: Ananda Raju <ananda.raju@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-29[PATCH] s2io iomem annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28drivers/net: Remove pointless checks for NULL prior to calling kfree()Jesper Juhl
2005-10-18[PATCH] s2io build fixAndrew Morton
Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-18[PATCH] S2io: Offline diagnostics fixesravinandan.arakali@neterion.com
This patch fixes the following bugs with offline diagnostics code(run with "ethtool -t"). 1. After running offline diagnostics, adapter would report corrupted packets on receive. This was because of adapter not being brought out of "RLDRAM test mode". 2. Current EEPROM test works only for Xframe I. Since Xframe II uses different interface(SPI), support for this interface has been added. Also, since SPI supports write access to all areas of EEPROM, negative testing is done only for Xframe I. 3. Return values from subfunctions of offline diagnostics have been corrected. 4. In register test, expected value from rx_queue_cfg register is made to depend on adapter type. 5. After the test, need to restore values at EEPROM offsets 0x4F0 and 0x7F0. These locations were modified as part of test. 6. Use macro SPECIAL_REG_WRITE for write access to mc_rldram_test_ctrl register. Also, couple of unnecessary writes to mc_rldram_test_ctrl have been removed. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-04[netdrvr s2io] Add a MODULE_VERSION entryJohn Linville
2005-10-04[PATCH] s2io: change strncpy length arg to use size of targetJohn W. Linville
Use the size of the target array for the length argument to strncpy instead of the size of the source or a magic number. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-04[PATCH] S2io: MSI/MSI-X support (runtime configurable)Ravinandan Arakali
This patch adds support for MSI/MSI-X feature to the driver. It is a runtime parameter(for now, loadable parameter). Default is INTA. Patch has been tested on IA64 platform with Xframe II adapter, both of which support MSI-X feature. An improvement of about 7% in throughput(both Tx and Rx) was observed and a reduction by 7% in CPU utilization during Tx test. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-14[PATCH] s2io warning fixesAndrew Morton
drivers/net/s2io.c: In function `init_shared_mem': drivers/net/s2io.c:431: warning: cast from pointer to integer of different size drivers/net/s2io.c: In function `free_shared_mem': drivers/net/s2io.c:662: warning: cast from pointer to integer of different size Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-07Merge branch 'upstream' of ↵Linus Torvalds
2005-09-07[PATCH] s2io u64 use for uintptr_tviro@zenIV.linux.org.uk
u64 is not uintptr_t; unsigned long is... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-06[PATCH] S2io: Hardware and miscellaneous fixesravinandan.arakali@neterion.com
Hi, This patch contains the following hardware related fixes and other miscellaneous bug fixes. 1. Updated the definition of single and double-bit ECC errors 2. Earlier we were allocating Transmit descriptors equal to MAX_SKB_FRAGS. This was causing a boundary condition failure. Need to allocate MAX_SKB_FRAGS+1 descriptors. 3. On some platforms(like PPC), pci_alloc_consistent() can return a zero DMA address. Since the NIC cannot handle zero-addresses, a workaround has been provided. Basically, we don't use such that page. We reallocate. 4. If list_info allocation failed during driver load, check for it during driver exit and return instead of trying to dereference NULL pointer. 5. Increase the debug level of few non-critical debug messages. 6. Reset the card on critical ECC double errors only in case of XframeI since XframeII can recover from such errors. 7. Print copyright message on driver load. 8. Bumped up the driver version no. to 2.0.8.1 Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-05[PATCH] (3/7) iomem annotations (s2io)viro@ftp.linux.org.uk
Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-19[PATCH] S2io: Hardware fixes for Xframe II adapterravinandan.arakali@neterion.com
Hi, Patch Description: This patch incorporates the following hardware fixes required for Xframe II adapter. 1. New values to program the dtx_control register. 2. Disable memory controller interrupts(MC_INTR) since these are now monitored thru' a poll routine. 3. Don't reset an XframeII card on an ECC double-bit error(It can recover). 4. Save/restore PCI config space before/after a reset irrespective of Xframe I or II card. 5. Bumped up the driver version no. to 2.0.3.1 Please review the patch and apply the same if it looks ok. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: Errors found during reviewraghavendra.koushik@neterion.com
Hi, This is a patch to incorporate comments from earlier 12 patches. It also fixes a few issues we found during this time. Following is a list of changes in this patch. Item 1 incorporates earlier comments. Issues addressed in items 2 to 4 were discovered recently. 1. wmb() call in s2io_xmit() replaced with mmiowb(). 2. The dtx_control register was earlier programmed incorrectly for Xframe II adapter. 3. As suggested by hardware team, after a reset, in case of Xframe II adapter, we clear certain spurious errors by clearing PCI-X ECC status register, "detected parity error" bit in PCI_STATUS register and PCI_STATUS bit in txpic_int register. 4. On IBM PPC platforms, we found that in the Rx buffer replenish function, two memory writes(one to the the descriptor length and another to the ownership) were getting reordered. This was causing the adapter to see the ownership transfered to it before the length was updated. One solution was to add a wmb() but since this would turnout expensive on some platforms if called for every descriptor, we set the ownership bit and other fields of '2' to 'N' Rx descriptors followed by a wmb() and then set the ownership of first descriptor ('1'). Here the value 'N' is configurable by making it a module loadable parameter (rxsync_frequency). (NOTE: This parameter is a power of 2). 5. Bumped up the driver version no. to 2.0.2.1 Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: Miscellaneous fixesraghavendra.koushik@neterion.com
Hi, The last patch in this series fixes the following issues found during testing. 1. Ensure we don't pass zero sized buffers to the card(which can lockup) 2. Restore the PCI-X parameters(in case of Xframe I adapter) after a reset. 3. Make sure total size of all FIFOs does not exceed 8192. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: New link handling scheme for Xframe IIraghavendra.koushik@neterion.com
Hi, The below patch implements a new "Link state change handling" scheme supported by the Xframe II adapter. It also bumps up the driver version to 2.0.2.0. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: Support for bimodal interruptsraghavendra.koushik@neterion.com
Hi, This is a patch to provide bimodal interrupt moderation support for Xframe II adapter. Basically, in this moderation scheme, the adapter raises a traffic interrupt if the no. of packets transmitted and/or received reaches a programmable threshold. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: Support for Xframe II NICraghavendra.koushik@neterion.com
Hi, This patch provides basic support for the Xframe II adapter. Includes the following changes: 1. New values to program XAUI interface. 2. Print the PCI/PCI-X mode(bus frequency, width). 3. Remove EOI from reset during intialization. 4. Enable all 8 PCCs if Xframe II adapter. 5. Programs the RLDRAM size depending on the device. (Note: RLDRAM size on XFARME-I is 64Mb whereas on XFRAME-II it's 32 Mb). 6. Enable extended(64-bit) statistics counters. 7. Program timer interrupt duration based on PCI/PCI-X clock speed. 8. Not required to save/restore PCI config space before/after reset. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: VLAN supportraghavendra.koushik@neterion.com
Hi, Patch below adds VLAN support to the driver. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: Timer based slowpath handlingraghavendra.koushik@neterion.com
Hi, This patch implements the slow-path handling functions(link state change, hardware errors) as a timer. It is not handled in interrupt handler as was done previously. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: Support for runtime MTU changeraghavendra.koushik@neterion.com
Hi, Patch below supports MTU change on-the-fly(without bringing interface down) Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: Performance improvementsraghavendra.koushik@neterion.com
Hi, This patch relates to mostly performance related changes. 1. Fixed incorrect computation of PANIC level in rx_buffer_level(). 2. Removed unnecessary PIOs(read/write of tx_traffic_int and rx_traffic_int) from interrupt handler and removed read of general_int_status register from xmit routine. 3. Enable two-buffer mode(for Rx path) automatically for SGI systems. This improves Rx performance dramatically on SGI systems. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: Removed memory leaksraghavendra.koushik@neterion.com
Hi, This patch fixes certain memory leaks discovered in free_tx_buffers() and rx_osm_handler() Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: Software fixesraghavendra.koushik@neterion.com
Hi, Below patch includes fixes for few purely software bugs identified since last release. 1. Keep track and display(as part of ethtool command output) the no. of single-bit and double-bit ECC errors. 2. Handle race condition between intr handler and "interface down" routine. 3. Initial link state setting modified so that the link state displayed after "interface Up" is correct. 4. Fix for "Incorrect Tx packet count when TSO is enabled". 5. Disable periodic DMA of statistics and schedule one-shot DMA only when required. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: Hardware fixesraghavendra.koushik@neterion.com
Hi, Below patch addresses few h/w specific issues. 1. Check for additional ownership bit on Rx path before starting Rx processing. 2. Enable only 4 PCCs(Per Context Controller) for Xframe I revisions less than 4. 3. Program Rx and Tx round robin registers depending on no. of rings/FIFOs. 4. Tx continous interrupts is now a loadable parameter. 5. Reset the card if we get double-bit ECC errors. 6. A soft reset of XGXS being done to force a link state change has been eliminated. 7. After a reset, clear "parity error detected" bit, PCI-X ECC status register, and PCI_STATUS bit in tx_pic_int register. 8. The error in the disabling allmulticast implementation has been rectified. 9. Leave the PCI-X parameters MMRBC, OST etc. at their BIOS/system defaults. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: Code cleanupraghavendra.koushik@neterion.com
Hi, We are submitting a series of 13 patches to support our Xframe I and Xframe II line of products. The patches can be categorized as follows: Patches 1-8 : Changes applicable to both Xframe I and II Patches 9-11: Xframe II specific features Patch 12: Addresses issues found during testing cycle. Patch 13: Incorpoates mostly the review comments from community and some last moment bug fixes. Please review the patches and let us know your comments. Starting with patch 1 below. This patch involves cosmetic changes(tabs and indentation, regrouping of transmit and receive data structures, typecasting, code cleanup). Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-28[NET]: Remove gratuitous use of skb->tail in network drivers.David S. Miller
Many drivers use skb->tail unnecessarily. In these situations, the code roughly looks like: dev = dev_alloc_skb(...); [optional] skb_reserve(skb, ...); ... skb->tail ... But even if the skb_reserve() happens, skb->data equals skb->tail. So it doesn't make any sense to use anything other than skb->data in these cases. Another case was the s2io.c driver directly mucking with the skb->data and skb->tail pointers. It really just wanted to do an skb_reserve(), so that's what the code was changed to do instead. Another reason I'm making this change as it allows some SKB cleanups I have planned simpler to merge. In those cleanups, skb->head, skb->tail, and skb->end pointers are removed, and replaced with skb->head_room and skb->tail_room integers. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-26drivers/net/: Use the DMA_{64,32}BIT_MASK constantsDomen Puncer
Use the DMA_{64,32}BIT_MASK constants from dma-mapping.h when calling pci_set_dma_mask() or pci_set_consistent_dma_mask() This patch includes dma-mapping.h explicitly because it caused errors on some architectures otherwise. See http://marc.theaimsgroup.com/?t=108001993000001&r=1&w=2 for details Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Domen Puncer <domen@coderock.org>
