path: root/drivers/net/r8169.c
2006-07-05[netdrvr] use dev_xxx() printk helpers, rather than dev_printk(KERN_xxx, ...Jeff Garzik
Suggested by Jiri Slaby. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[netdrvr] Use dev_printk() when ethernet interface isn't availableJeff Garzik
For messages prior to register_netdev(), prefer dev_printk() because that prints out both our driver name and our [PCI | whatever] bus id. Updates: 8139{cp,too}, b44, bnx2, cassini, {eepro,epic}100, fealnx, hamachi, ne2k-pci, ns83820, pci-skeleton, r8169. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[NET]: Merge TSO/UFO fields in sk_buffHerbert Xu
Having separate fields in sk_buff for TSO/UFO (tso_size/ufo_size) is not going to scale if we add any more segmentation methods (e.g., DCCP). So let's merge them. They were used to tell the protocol of a packet. This function has been subsumed by the new gso_type field. This is essentially a set of netdev feature bits (shifted by 16 bits) that are required to process a specific skb. As such it's easy to tell whether a given device can process a GSO skb: you just have to and the gso_type field and the netdev's features field. I've made gso_type a conjunction. The idea is that you have a base type (e.g., SKB_GSO_TCPV4) that can be modified further to support new features. For example, if we add a hardware TSO type that supports ECN, they would declare NETIF_F_TSO | NETIF_F_TSO_ECN. All TSO packets with CWR set would have a gso_type of SKB_GSO_TCPV4 | SKB_GSO_TCPV4_ECN while all other TSO packets would be SKB_GSO_TCPV4. This means that only the CWR packets need to be emulated in software. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-23[NET]: Avoid allocating skb in skb_padHerbert Xu
First of all it is unnecessary to allocate a new skb in skb_pad since the existing one is not shared. More importantly, our hard_start_xmit interface does not allow a new skb to be allocated since that breaks requeueing. This patch uses pskb_expand_head to expand the existing skb and linearize it if needed. Actually, someone should sift through every instance of skb_pad on a non-linear skb as they do not fit the reasons why this was originally created. Incidentally, this fixes a minor bug when the skb is cloned (tcpdump, TCP, etc.). As it is skb_pad will simply write over a cloned skb. Because of the position of the write it is unlikely to cause problems but still it's best if we don't do it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-26[PATCH] r8169: add new PCI IDYoichi Yuasa
Hi, This patch add new PCI ID for r8169 driver. RTL8110SBL has this PCI ID. Please aply. Yoichi Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-03Massive net driver const-ification.Arjan van de Ven
2006-02-23r8169: enable wake on lanFrancois Romieu
Similar to 8139cp code but more inspired/lucky. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2006-02-23r8169: fix broken ring index handling in suspend/resumeFrancois Romieu
rtl8169_hw_start() requires that the descriptor ring indexes be set to zero. Let a deferred invocation of rtl8169_reset_task() handle it. Enabling a few power management bits will not hurt either. suspend/resume is issued with irq on: the spinlock do not need to save the irq flag. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2006-01-31r8169: fix forced-mode link settingsAndy Gospodarek
Allow the r8169 driver to set devices to be full-duplex only when auto-negotiate is disabled. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2006-01-29r8169: prevent excessive busy-waitingFrancois Romieu
The MII registers read/write function blindly busy waits for an amount of 1000 us (1 ms), then up to 200 ms. These functions are called from irq disabled context. Depending on the clock management, it triggers lost ticks events. Since the value is way above the standard delay required for mii register access, it strangely looks like a bandaid against posted writes. Fixes http://bugzilla.kernel.org/show_bug.cgi?id=5947 Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2006-01-10[PATCH] turn "const static" into "static const"Jesper Juhl
ICC likes to complain about storage class not being first, GCC doesn't care much (except for cases like "inline static"). have a hard time seeing how it could break anything. Thanks to Gabriel A. Devenyi for pointing out http://linuxicc.sourceforge.net/ which is what made me create this patch. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-16r8169: do not abort when the power management capabilities are disabledFrancois Romieu
The capabilities of the 8169 can be disabled but it is hardly a reason to prevent the use the device. The (so far) unusual behavior has been reported on a MIPS platform by Yoichi Yuasa. Spotted-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-11-16r8169: fix printk_ratelimit in the interrupt handlerFrancois Romieu
I keep on getting "printk: N messages suppressed" messages. We need to test netif_msg_intr() _before_ running printk_ratelimit(), because the latter updates state. Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-10-03Merge branch 'upstream-fixes'Jeff Garzik
2005-09-30[PATCH] r8169: tone down the r8169 driverFrancois Romieu
Tone down the r8169 driver As an alternative, people can use the boot time 'debug' option and/or use 'ethtool -s ethX msglvl xyz'. The different messages are listed at: http://www.zoreil.com/~romieu/r8169/doc/msglvl.txt Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22Merge /spare/repo/linux-2.6/Jeff Garzik
2005-09-21[PATCH] r8169: call proper VLAN receive functionTommy Christensen
vlan_hwaccel_rx should be used when in interrupt context. Fixes bug http://bugzilla.kernel.org/show_bug.cgi?id=5284 Signed-off-by: Tommy S. Christensen <tommy.christensen@tpack.net> Cc: Francois Romieu <romieu@fr.zoreil.com> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-14[PATCH] r8169: support ETHTOOL_GPERMADDRJohn W. Linville
Add support for ETHTOOL_GPERMADDR to r8169. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-27[PATCH] r8169: avoid conflict between revisions 2 and 3 of the Linksys EG1032Francois Romieu
Both revisions share the same PCI device ID and vendor ID but revision 2 of the device uses SysKonnect's chipset whereas revision 3 of the device uses Realtek's 8169 chipset. Credit goes to Christiaan Lutzer <mythtv.lutzer@gmail.com> for reporting the issue and giving the actual value for the different revisions. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-19[PATCH] r8169: PCI ID for the Linksys EG1032Francois Romieu
The Linksys EG1032 uses Realtek's 8169 chipset. Credit goes to Bob Wilson <bwilson4web@hotmail.com> for the report. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-28[NET]: Remove gratuitous use of skb->tail in network drivers.David S. Miller
Many drivers use skb->tail unnecessarily. In these situations, the code roughly looks like: dev = dev_alloc_skb(...); [optional] skb_reserve(skb, ...); ... skb->tail ... But even if the skb_reserve() happens, skb->data equals skb->tail. So it doesn't make any sense to use anything other than skb->data in these cases. Another case was the s2io.c driver directly mucking with the skb->data and skb->tail pointers. It really just wanted to do an skb_reserve(), so that's what the code was changed to do instead. Another reason I'm making this change as it allows some SKB cleanups I have planned simpler to merge. In those cleanups, skb->head, skb->tail, and skb->end pointers are removed, and replaced with skb->head_room and skb->tail_room integers. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-18Manual merge of ↵Linus Torvalds
rsync://rsync.kernel.org/pub/scm/linux/kernel/git/jgarzik/netdev-2.6.git This is a fixed-up version of the broken "upstream-2.6.13" branch, where I re-did the manual merge of drivers/net/r8169.c by hand, and made sure the history is all good.
2005-06-13[NET]: Move the netdev list to vger.kernel.org.Ralf Baechle
From: Ralf Baechle <ralf@linux-mips.org> There are archives of the old list at http://oss.sgi.com/archives/netdev Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-27[PATCH] r8169: minor cleanupRichard Dawe
- more consistent prototypes; - rtl8169_rx_interrupt() o the error condition should be rare; o goto removal. Signed-off-by: Richard Dawe <rich@phekda.gotadsl.co.uk> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-05-27[PATCH] r8169: add ethtool support for dumping the chip statisticsStephen Hemminger
There aren't lots of statistics available, but this is what is available according to the RealTek documentation. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-05-27[PATCH] r8169: ethtool message level control supportStephen Hemminger
Also: - ratelimit the too much work at interrupt message, so if under massive packet load the console doesn't get flooded; - removal of a few PFX used in contexts where dev->name is available; - s/->slot_name/pci_name/; - printed_version is redundant with the debug option. Remove it and let the user decide. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-05-27[PATCH] r8169: add module parameter (media)Francois Romieu
Add module parameter description for the media option. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-05-27[PATCH] r8169: add module parameter (copybreak)Stephen Hemminger
Add module parameter description for copybreak. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-05-27[PATCH] r8169: identify the napi versionStephen Hemminger
To tell if driver is configured for NAPI or not, put -NAPI on driver version. Remove the NAPI printk since the complete version information is displayed once in the pci probe routine or returned via ethtool. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-05-27[PATCH] r8169: de-obfuscate supported PCI IDFrancois Romieu
De-obfuscate supported PCI ID Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-05-27[PATCH] r8169: new PCI idFrancois Romieu
The USR 997902 is based on the 8169 chipset. The value has been extracted from the sources of the driver which comes with the manufacturer's cdrom. Heads-up and test by TommyDrum <mycooc@yahoo.it>. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-05-12 [PATCH] r8169: incoming frame length checkFrancois Romieu
The size of the incoming frame is not correctly checked. The RxMaxSize register (0xDA) does not work as expected and incoming frames whose size exceeds the MTU actually end spanning multiple descriptors. The first Rx descriptor contains the size of the whole frame (or some garbage in its place). The driver does not expect something above the space allocated to the current skb and crashes loudly when it issues a skb_put. The fix contains two parts: - disable hardware Rx size filtering: so far it only proved to be able to trigger some new fancy errors; - drop multi-descriptors frame: as the driver allocates MTU sized Rx buffers, it provides an adequate filtering. As a bonus, wrong descriptors were not returned to the asic after their processing. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-05-01[PATCH] Change synchronize_kernel to _rcu and _schedPaul E. McKenney
This patch changes calls to synchronize_kernel(), deprecated in the earlier "Deprecate synchronize_kernel, GPL replacement" patch to instead call the new synchronize_rcu() and synchronize_sched() APIs. Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] u32 vs. pm_message_t fixes for drivers/netPavel Machek
This fixes remaining u32s in drivers/ net. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
