path: root/drivers/net/pppoe.c
2006-03-20[NET]: Replace skb_pull/skb_postpull_rcsum with skb_pull_rcsumHerbert Xu
We're now starting to have quite a number of places that do skb_pull followed immediately by an skb_postpull_rcsum. We can merge these two operations into one function with skb_pull_rcsum. This makes sense since most pull operations on receive skb's need to update the checksum. I've decided to make this out-of-line since it is fairly big and the fast path where hardware checksums are enabled need to call csum_partial anyway. Since this is a brand new function we get to add an extra check on the len argument. As it is most callers of skb_pull ignore its return value which essentially means that there is no check on the len argument. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[PPPOX]: Fix assignment into const proto_ops.David S. Miller
And actually, with this, the whole pppox layer can basically be removed and subsumed into pppoe.c, no other pppox sub-protocol implementation exists and we've had this thing for at least 4 years. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[SOCK]: Introduce sk_receive_skbArnaldo Carvalho de Melo
Its common enough to to justify that, TCP still can't use it as it has the prequeueing stuff, still to be made generic in the not so distant future :-) Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-29[PATCH] proc_mkdir() should be used to create procfs directoriesAl Viro
A bunch of create_proc_dir_entry() calls creating directories had crept in since the last sweep; converted to proc_mkdir(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-29[NET]: Kill skb->real_devDavid S. Miller
Bonding just wants the device before the skb_bond() decapsulation occurs, so simply pass that original device into packet_type->func() as an argument. It remains to be seen whether we can use this same exact thing to get rid of skb->input_dev as well. Signed-off-by: David S. Miller <davem@davemloft.net>
