path: root/drivers/net/plip.c
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-03Massive net driver const-ification.Arjan van de Ven
2006-01-06[PATCH] parport: include fixesMarko Kohtala
Small cleanup of includes meant for older implementation. Signed-off-by: Marko Kohtala <marko.kohtala@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[NET]: __be'ify *_type_trans()Alexey Dobriyan
tr_type_trans(), hippi_type_trans() left as-is. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
