path: root/drivers/net/pci-skeleton.c
2010-01-078139too: make PCI device ids constantMárton Németh
The id_table field of the struct pci_driver is constant in <linux/pci.h> so it is worth to make pci_device_id also constant. The semantic match that finds this kind of pattern is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ identifier I1, I2, x; @@ struct I1 { ... const struct I2 *x; ... }; @s@ identifier r.I1, y; identifier r.x, E; @@ struct I1 y = { .x = E, }; @c@ identifier r.I2; identifier s.E; @@ const struct I2 E[] = ... ; @depends on !c@ identifier r.I2; identifier s.E; @@ + const struct I2 E[] = ...; // </smpl> Signed-off-by: Márton Németh <nm127@freemail.hu> Cc: Julia Lawall <julia@diku.dk> Cc: cocci@diku.dk Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-03netdev: Remove redundant checks for CAP_NET_ADMIN in MDIO implementationsBen Hutchings
dev_ioctl() already checks capable(CAP_NET_ADMIN) before calling the driver's implementation of MDIO ioctls. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: arch/microblaze/include/asm/socket.h
2009-07-08Remove multiple KERN_ prefixes from printk formatsJoe Perches
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up handling of log-levels and newlines") changed printk semantics. printk lines with multiple KERN_<level> prefixes are no longer emitted as before the patch. <level> is now included in the output on each additional use. Remove all uses of multiple KERN_<level>s in formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-16pci-skeleton: convert to net_device_opsAlexander Beregalov
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-08netdevice: Kill netdev->privWang Chen
This is the last shoot of this series. After I removing all directly reference of netdev->priv, I am killing "priv" of "struct net_device" and fixing relative comments/docs. Anyone will not be allowed to reference netdev->priv directly. If you want to reference the memory of private data, use netdev_priv() instead. If the private data is not allocted when alloc_netdev(), use netdev->ml_priv to point that memory after you creating that private data. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-24drivers/net: replace __FUNCTION__ with __func__Harvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-28[netdrvr] kill sync_irq-before-freq_irq patternJeff Garzik
synchronize_irq() is superfluous when free_irq() call immediately follows it, because free_irq() also does a synchronize_irq() call of its own. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-03pci-skeleton: Misc fixes to build neatlyJike Song
The pci-skeleton.c has several problems with compilation, such as missing args when calling synchronize_irq(). Fix it. Signed-off-by: Jike Song <albcamus@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET] drivers/net: statistics cleanup #1 -- save memory and shrink codeJeff Garzik
We now have struct net_device_stats embedded in struct net_device, and the default ->get_stats() hook does the obvious thing for us. Run through drivers/net/* and remove the driver-local storage of statistics, and driver-local ->get_stats() hook where applicable. This was just the low-hanging fruit in drivers/net; plenty more drivers remain to be updated. [ Resolved conflicts with napi_struct changes and fix sunqe build regression... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET]: Kill eth_copy_and_sum().David S. Miller
It hasn't "summed" anything in over 7 years, and it's just a straight mempcy ala skb_copy_to_linear_data() so just get rid of it. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-23Fix return code in pci-skeleton.cAnton Blanchard
We assign the return value of register_netdev to i, but return rc later on. Fix it. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-09-12Merge branch 'tmp' into upstreamJeff Garzik
2006-09-12[PATCH] Remove more unnecessary driver printk'sAndy Gospodarek
As I promised last week, here is the first pass at removing all unnecessary printk's that exist in network device drivers currently in promiscuous mode. The duplicate messages are not needed so they have been removed. Some of these drivers are quite old and might not need an update, but I did them all anyway. I am currently auditing the remaining conditional printk's and will send out a patch for those soon. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-19drivers/net: Remove deprecated use of pci_module_init()Jeff Garzik
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[netdrvr] use dev_xxx() printk helpers, rather than dev_printk(KERN_xxx, ...Jeff Garzik
Suggested by Jiri Slaby. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[netdrvr] Use dev_printk() when ethernet interface isn't availableJeff Garzik
For messages prior to register_netdev(), prefer dev_printk() because that prints out both our driver name and our [PCI | whatever] bus id. Updates: 8139{cp,too}, b44, bnx2, cassini, {eepro,epic}100, fealnx, hamachi, ne2k-pci, ns83820, pci-skeleton, r8169. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] turn "const static" into "static const"Jesper Juhl
ICC likes to complain about storage class not being first, GCC doesn't care much (except for cases like "inline static"). have a hard time seeing how it could break anything. Thanks to Gabriel A. Devenyi for pointing out http://linuxicc.sourceforge.net/ which is what made me create this patch. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-31[PATCH] drivers/net/pci-skeleton.c: MODULE_PARM -> module_paramVictor Fusco
Use module_param() instead of the old MODULE_PARM() Signed-off-by: Victor Fusco <victor@cetuc.puc-rio.br> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-04-16[PATCH] u32 vs. pm_message_t fixes for drivers/netPavel Machek
This fixes remaining u32s in drivers/ net. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
