path: root/drivers/net/niu.c
2010-09-26drivers/net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15ethtool: Remove unimplemented flow specification typesBen Hutchings
struct ethtool_rawip4_spec and struct ethtool_ether_spec are neither commented nor used by any driver, so remove them. Adjust padding in the user-visible unions that included these structures. Fix references to struct ethtool_rawip4_spec in ethtool_get_rx_ntuple(), which should use struct ethtool_usrip4_spec. struct ethtool_usrip4_spec cannot hold IPv6 host addresses and there is no separate structure that can, so remove ETH_RX_NFC_IP6 and the reference to it in niu. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/main.c
2010-09-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2010-09-08niu: Fix kernel buffer overflow for ETHTOOL_GRXCLSRLALLBen Hutchings
niu_get_ethtool_tcam_all() assumes that its output buffer is the right size, and warns before returning if it is not. However, the output buffer size is under user control and ETHTOOL_GRXCLSRLALL is an unprivileged ethtool command. Therefore this is at least a local denial-of-service vulnerability. Change it to check before writing each entry and to return an error if the buffer is already full. Compile-tested only. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-02drivers/net: avoid some skb->ip_summed initializationsEric Dumazet
fresh skbs have ip_summed set to CHECKSUM_NONE (0) We can avoid setting again skb->ip_summed to CHECKSUM_NONE in drivers. Introduce skb_checksum_none_assert() helper so that we keep this assertion documented in driver sources. Change most occurrences of : skb->ip_summed = CHECKSUM_NONE; by : skb_checksum_none_assert(skb); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-17drivers/net: Convert unbounded kzalloc calls to kcallocJoe Perches
These changes may be slightly safer in some instances. There are other kzalloc calls with a multiply, but those calls are typically "small fixed #" * sizeof(some pointer)" and those are not converted. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Luciano Coelho <luciano.coelho@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-08-05Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: (63 commits) of/platform: Register of_platform_drivers with an "of:" prefix of/address: Clean up function declarations of/spi: call of_register_spi_devices() from spi core code of: Provide default of_node_to_nid() implementation. of/device: Make of_device_make_bus_id() usable by other code. of/irq: Fix endian issues in parsing interrupt specifiers of: Fix phandle endian issues of/flattree: fix of_flat_dt_is_compatible() to match the full compatible string of: remove of_default_bus_ids of: make of_find_device_by_node generic microblaze: remove references to of_device and to_of_device sparc: remove references to of_device and to_of_device powerpc: remove references to of_device and to_of_device of/device: Replace of_device with platform_device in includes and core code of/device: Protect against binding of_platform_drivers to non-OF devices of: remove asm/of_device.h of: remove asm/of_platform.h of/platform: remove all of_bus_type and of_platform_bus_type references of: Merge of_platform_bus_type with platform_bus_type drivercore/of: Add OF style matching to platform bus ... Fix up trivial conflicts in arch/microblaze/kernel/Makefile due to just some obj-y removals by the devicetree branch, while the microblaze updates added a new file.
2010-07-24of/platform: remove all of_bus_type and of_platform_bus_type referencesGrant Likely
Both of_bus_type and of_platform_bus_type are just #define aliases for the platform bus. This patch removes all references to them and switches to the of_register_platform_driver()/of_unregister_platform_driver() API for registering. Subsequent patches will convert each user of of_register_platform_driver() into plain platform_drivers without the of_platform_driver shim. At which point the of_register_platform_driver()/of_unregister_platform_driver() functions can be removed. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net>
2010-07-07niu: BUG on inability to find page in rx page hashes.David S. Miller
2010-07-05niu: always include of_device.hRandy Dunlap
The niu driver uses struct of_device when built on any arch, not only SPARC64, so always #include <linux/of_device.h>. drivers/net/niu.c:9700: warning: 'struct of_device' declared inside parameter list drivers/net/niu.c:9700: warning: its scope is only this definition or declaration, which is probably not what you want drivers/net/niu.c:9716: warning: assignment from incompatible pointer type Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Dave S. Miller <davem@davemloft.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-06-30ethtool: Change ethtool_op_set_flags to validate flagsBen Hutchings
ethtool_op_set_flags() does not check for unsupported flags, and has no way of doing so. This means it is not suitable for use as a default implementation of ethtool_ops::set_flags. Add a 'supported' parameter specifying the flags that the driver and hardware support, validate the requested flags against this, and change all current callers to pass this parameter. Change some other trivial implementations of ethtool_ops::set_flags to call ethtool_op_set_flags(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-28sparc/of: Move of_device fields into struct pdev_archdataGrant Likely
This patch moves SPARC architecture specific data members out of struct of_device and into the pdev_archdata structure. The reason for this change is to unify the struct of_device definition amongst all the architectures. It also remvoes the .sysdata, .slot, .portid and .clock_freq properties because they aren't actually used by anything. A subsequent patch will replace struct of_device entirely with struct platform_device and the of_platform support code will share common routines with the platform bus (but the bus instances themselves can remain separate). This patch also adds 'struct resources *resource' and num_resources to match the fields defined in struct platform_device. After this change, 'struct platform_device' can be used as a drop-in replacement for 'struct of_platform'. This change is in preparation for merging the of_platform_bus_type with the platform_bus_type. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au>
2010-05-22Merge remote branch 'origin' into secretlab/next-devicetreeGrant Likely
Merging in current state of Linus' tree to deal with merge conflicts and build failures in vio.c after merge. Conflicts: drivers/i2c/busses/i2c-cpm.c drivers/i2c/busses/i2c-mpc.c drivers/net/gianfar.c Also fixed up one line in arch/powerpc/kernel/vio.c to use the correct node pointer. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-04-22niu: Add skb->rxhash support.David S. Miller
2010-04-20niu: Enable GRO by default.David S. Miller
This was merely an oversight when I added the napi_gro_receive() calls. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-26net: convert multiple drivers to use netdev_for_each_mc_addr, part5 V2Jiri Pirko
removed some needless checks and also corrected bug in lp486e (dmi was passed instead of dmi->dmi_addr) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-15niu: Refinements to kernel logging.David S. Miller
Fix unconditional empty kerne log message every interrupt. Kill some informational log messages that are superfluous and anyways occur before the netdev is registered. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-14niu: Use pr_<level>, netdev_<level> and netif_<level> macrosJoe Perches
Remove #define PFX Add pr_fmt(fmt) KBUILD_MODNAME ": " fmt Convert printks to pr_<level> Convert printks without levels to pr_cont Convert pr_<level> with np->dev to netdev_<level> Convert dev_<level> to netdev_<level> Convert niudbg to netif_printk Convert niuinfo, niuwarn macros to netif_<level>(priv, type, dev... Coalesce long formats Convert embedded function names to "%s", __func__ Always use "%s()..." when __func__ is printed Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-25net: use helpers to access uc list V2Jiri Pirko
This patch introduces three macros to work with uc list from net drivers. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-10Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/benet/be_cmds.h include/linux/sysctl.h
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-03niu: timeout ignored in tcam_wait_bit()roel kluin
With `while (--limit > 0)' i reaches 0 after the loop, so upon timeout the error was not returned. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-13niu.c: Use correct length in strncmpJoe Perches
Untested, no hardware Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-10niu: Use DMA_BIT_MASK(44) instead of deprecated DMA_44BIT_MASKMarin Mitov
Use DMA_BIT_MASK(44) instead of deprecated DMA_44BIT_MASK Signed-off-by: Marin Mitov <mitov@issp.bas.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sh_eth.c
2009-10-21niu: VLAN_ETH_HLEN should be used to make sure that the whole MAC header was ↵Joyce Yu
copied to the head buffer in the Vlan packets case Signed-off-by: Joyce Yu <joyce.yu@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-05net: Convert ethtool {get_stats, self_test}_count() ops to get_sset_count()Ben Hutchings
These string query operations were supposed to be replaced by the generic get_sset_count() starting in 2007. Convert the remaining implementations. Also remove calls to these operations to initialise drvinfo->n_stats. The ethtool core code already does that. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-23BUILD_BUG_ON(): fix it and a couple of bogus uses of itJan Beulich
gcc permitting variable length arrays makes the current construct used for BUILD_BUG_ON() useless, as that doesn't produce any diagnostic if the controlling expression isn't really constant. Instead, this patch makes it so that a bit field gets used here. Consequently, those uses where the condition isn't really constant now also need fixing. Note that in the gfp.h, kmemcheck.h, and virtio_config.h cases MAYBE_BUILD_BUG_ON() really just serves documentation purposes - even if the expression is compile time constant (__builtin_constant_p() yields true), the array is still deemed of variable length by gcc, and hence the whole expression doesn't have the intended effect. [akpm@linux-foundation.org: make arch/sparc/include/asm/vio.h compile] [akpm@linux-foundation.org: more nonsensical assertions in tpm.c..] Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: Mimi Zohar <zohar@us.ibm.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-09niu: Use resource_size instead of private functionTobias Klauser
The function res_size in drivers/net/niu.c is a copy of resource_size in linux/ioport.h. Remove the function and use resource_size instead. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12drivres/net: Change constant nameJulia Lawall
In this series of tests the constants have the form XRXMAC_STATUS, except in this one case. The values of XRXMAC_STAT_MSK_RXOCTET_CNT_EXP and XRXMAC_STATUS_RXOCTET_CNT_EXP are furthermore the same. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: group address list and its countJiri Pirko
This patch is inspired by patch recently posted by Johannes Berg. Basically what my patch does is to group list and a count of addresses into newly introduced structure netdev_hw_addr_list. This brings us two benefits: 1) struct net_device becames a bit nicer. 2) in the future there will be a possibility to operate with lists independently on netdevices (with exporting right functions). I wanted to introduce this patch before I'll post a multicast lists conversion. Signed-off-by: Jiri Pirko <jpirko@redhat.com> drivers/net/bnx2.c | 4 +- drivers/net/e1000/e1000_main.c | 4 +- drivers/net/ixgbe/ixgbe_main.c | 6 +- drivers/net/mv643xx_eth.c | 2 +- drivers/net/niu.c | 4 +- drivers/net/virtio_net.c | 10 ++-- drivers/s390/net/qeth_l2_main.c | 2 +- include/linux/netdevice.h | 17 +++-- net/core/dev.c | 130 ++++++++++++++++++-------------------- 9 files changed, 89 insertions(+), 90 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: convert unicast addr listJiri Pirko
This patch converts unicast address list to standard list_head using previously introduced struct netdev_hw_addr. It also relaxes the locking. Original spinlock (still used for multicast addresses) is not needed and is no longer used for a protection of this list. All reading and writing takes place under rtnl (with no changes). I also removed a possibility to specify the length of the address while adding or deleting unicast address. It's always dev->addr_len. The convertion touched especially e1000 and ixgbe codes when the change is not so trivial. Signed-off-by: Jiri Pirko <jpirko@redhat.com> drivers/net/bnx2.c | 13 +-- drivers/net/e1000/e1000_main.c | 24 +++-- drivers/net/ixgbe/ixgbe_common.c | 14 ++-- drivers/net/ixgbe/ixgbe_common.h | 4 +- drivers/net/ixgbe/ixgbe_main.c | 6 +- drivers/net/ixgbe/ixgbe_type.h | 4 +- drivers/net/macvlan.c | 11 +- drivers/net/mv643xx_eth.c | 11 +- drivers/net/niu.c | 7 +- drivers/net/virtio_net.c | 7 +- drivers/s390/net/qeth_l2_main.c | 6 +- drivers/scsi/fcoe/fcoe.c | 16 ++-- include/linux/netdevice.h | 18 ++-- net/8021q/vlan.c | 4 +- net/8021q/vlan_dev.c | 10 +- net/core/dev.c | 195 +++++++++++++++++++++++++++----------- net/dsa/slave.c | 10 +- net/packet/af_packet.c | 4 +- 18 files changed, 227 insertions(+), 137 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: dont update dev->trans_startEric Dumazet
Second round of drivers for Gb cards (and NIU one I forgot in the 10GB round) Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-26niu: Add support for C10NEMTanli Chang
This patch is for supporting C10NEM. C10NEM is a switch module, which has back-to-back XAUI link connected to blades. Signed-off-by: Tanli Chang <tanli.chang@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-08niu: Fix unused variable warning.David S. Miller
Don't strain gcc's tiny mind. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-08niu: Fix error handlingDan Carpenter
platform_device_register_simple() returns ERR_PTR(), not NULL, if an error occurs. Found by smatch (http://repo.or.cz/w/smatch.git). Compile tested. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-29niu: Add GRO support.David S. Miller
2009-02-20niu: Add TCAM classification configurationSantwona Behera
Signed-off-by: Santwona Behera <santwona.behera@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-18niu: improve ethtool support for gigabit copper cardsConstantin Baranov
Introduced support for link speed and duplex setting (ethtool -s), link advertising parameters and autonegotiation (ethtool -r): - struct niu_link_config: split advertising and autoneg fields into active and target values (similar to speed and duplex fields) - mii_init_common(): rewrite function to actually apply requested niu_link_config parameters instead of providing default initialization - link_status_1g(): move parsing of MII registers into new link_status_mii() function (link_status_1g_rgmii() could possibly use this new implementation too) - introduce simple nway_reset method - fix incorrect XMAC_CONFIG_MODE selection for 10Mbps case Signed-off-by: Constantin Baranov <baranov@mercdev.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-18niu: fix PHY template choice for 10G copperConstantin Baranov
Fixed a typo in niu_determine_phy_disposition() which resulted in phy_template_1g_copper being selected for 10G/copper configuration. Signed-off-by: Constantin Baranov <baranov@mercdev.com> Signed-off-by: David S. Miller <davem@davemloft.net>
