path: root/drivers/net/netconsole.c
2013-07-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "This is a re-do of the net-next pull request for the current merge window. The only difference from the one I made the other day is that this has Eliezer's interface renames and the timeout handling changes made based upon your feedback, as well as a few bug fixes that have trickeled in. Highlights: 1) Low latency device polling, eliminating the cost of interrupt handling and context switches. Allows direct polling of a network device from socket operations, such as recvmsg() and poll(). Currently ixgbe, mlx4, and bnx2x support this feature. Full high level description, performance numbers, and design in commit 0a4db187a999 ("Merge branch 'll_poll'") From Eliezer Tamir. 2) With the routing cache removed, ip_check_mc_rcu() gets exercised more than ever before in the case where we have lots of multicast addresses. Use a hash table instead of a simple linked list, from Eric Dumazet. 3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski, Marek Puzyniak, Michal Kazior, and Sujith Manoharan. 4) Support reporting the TUN device persist flag to userspace, from Pavel Emelyanov. 5) Allow controlling network device VF link state using netlink, from Rony Efraim. 6) Support GRE tunneling in openvswitch, from Pravin B Shelar. 7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from Daniel Borkmann and Eric Dumazet. 8) Allow controlling of TCP quickack behavior on a per-route basis, from Cong Wang. 9) Several bug fixes and improvements to vxlan from Stephen Hemminger, Pravin B Shelar, and Mike Rapoport. In particular, support receiving on multiple UDP ports. 10) Major cleanups, particular in the area of debugging and cookie lifetime handline, to the SCTP protocol code. From Daniel Borkmann. 11) Allow packets to cross network namespaces when traversing tunnel devices. From Nicolas Dichtel. 12) Allow monitoring netlink traffic via AF_PACKET sockets, in a manner akin to how we monitor real network traffic via ptype_all. From Daniel Borkmann. 13) Several bug fixes and improvements for the new alx device driver, from Johannes Berg. 14) Fix scalability issues in the netem packet scheduler's time queue, by using an rbtree. From Eric Dumazet. 15) Several bug fixes in TCP loss recovery handling, from Yuchung Cheng. 16) Add support for GSO segmentation of MPLS packets, from Simon Horman. 17) Make network notifiers have a real data type for the opaque pointer that's passed into them. Use this to properly handle network device flag changes in arp_netdev_event(). From Jiri Pirko and Timo Teräs. 18) Convert several drivers over to module_pci_driver(), from Peter Huewe. 19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a O(1) calculation instead. From Eric Dumazet. 20) Support setting of explicit tunnel peer addresses in ipv6, just like ipv4. From Nicolas Dichtel. 21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet. 22) Prevent a single high rate flow from overruning an individual cpu during RX packet processing via selective flow shedding. From Willem de Bruijn. 23) Don't use spinlocks in TCP md5 signing fast paths, from Eric Dumazet. 24) Don't just drop GSO packets which are above the TBF scheduler's burst limit, chop them up so they are in-bounds instead. Also from Eric Dumazet. 25) VLAN offloads are missed when configured on top of a bridge, fix from Vlad Yasevich. 26) Support IPV6 in ping sockets. From Lorenzo Colitti. 27) Receive flow steering targets should be updated at poll() time too, from David Majnemer. 28) Fix several corner case regressions in PMTU/redirect handling due to the routing cache removal, from Timo Teräs. 29) We have to be mindful of ipv4 mapped ipv6 sockets in upd_v6_push_pending_frames(). From Hannes Frederic Sowa. 30) Fix L2TP sequence number handling bugs, from James Chapman." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits) drivers/net: caif: fix wrong rtnl_is_locked() usage drivers/net: enic: release rtnl_lock on error-path vhost-net: fix use-after-free in vhost_net_flush net: mv643xx_eth: do not use port number as platform device id net: sctp: confirm route during forward progress virtio_net: fix race in RX VQ processing virtio: support unlocked queue poll net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit Documentation: Fix references to defunct linux-net@vger.kernel.org net/fs: change busy poll time accounting net: rename low latency sockets functions to busy poll bridge: fix some kernel warning in multicast timer sfc: Fix memory leak when discarding scattered packets sit: fix tunnel update via netlink dt:net:stmmac: Add dt specific phy reset callback support. dt:net:stmmac: Add support to dwmac version 3.610 and 3.710 dt:net:stmmac: Allocate platform data only if its NULL. net:stmmac: fix memleak in the open method ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available net: ipv6: fix wrong ping_v6_sendmsg return value ...
2013-06-05net: core: move mac_pton() to lib/net_utils.cAndy Shevchenko
Since we have at least one user of this function outside of CONFIG_NET scope, we have to provide this function independently. The proposed solution is to move it under lib/net_utils.c with corresponding configuration variable and select wherever it is needed. Signed-off-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reported-by: Arnd Bergmann <arnd@arndb.de> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-28net: pass info struct via netdevice notifierJiri Pirko
So far, only net_device * could be passed along with netdevice notifier event. This patch provides a possibility to pass custom structure able to provide info that event listener needs to know. Signed-off-by: Jiri Pirko <jiri@resnulli.us> v2->v3: fix typo on simeth shortened dev_getter shortened notifier_info struct name v1->v2: fix notifier_call parameter in call_netdevice_notifier() Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-12netconsole: don't call __netpoll_cleanup() while atomicVeaceslav Falico
__netpoll_cleanup() is called in netconsole_netdev_event() while holding a spinlock. Release/acquire the spinlock before/after it and restart the loop. Also, disable the netconsole completely, because we won't have chance after the restart of the loop, and might end up in a situation where nt->enabled == 1 and nt->np.dev == NULL. Signed-off-by: Veaceslav Falico <vfalico@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-08netpoll: add IPv6 supportCong Wang
Currently, netpoll only supports IPv4. This patch adds IPv6 support to netpoll so that we can run netconsole over IPv6 network. Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-08netpoll: prepare for ipv6Cong Wang
This patch adjusts some struct and functions, to prepare for supporting IPv6. Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-08netconsole: add oops_only module optionAmerigo Wang
Some people wants to log only oops messages via netconsole, (this is also why netoops was invented) so add a module option for netconsole. This can be tuned via /sys/module/netconsole/parameters/oops_only at run time as well. Cc: David Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-20netconsole: remove a redundant netconsole_target_put()Amerigo Wang
This netconsole_target_put() is obviously redundant, and it causes a kernel segfault when removing a bridge device which has netconsole running on it. This is caused by: commit 8d8fc29d02a33e4bd5f4fa47823c1fd386346093 Author: Amerigo Wang <amwang@redhat.com> Date: Thu May 19 21:39:10 2011 +0000 netpoll: disable netpoll when enslave a device Cc: David Miller <davem@davemloft.net> (for all 3.x stable releases) Cc: stable@vger.kernel.org Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14netconsole: do not release spin_lock when calling __netpoll_cleanupAmerigo Wang
With the previous patch applied, __netpoll_cleanup() is non-block now, so we don't need to release the spin_lock before calling it. Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-31drivers/net: Remove unnecessary k.alloc/v.alloc OOM messagesJoe Perches
alloc failures use dump_stack so emitting an additional out-of-memory message is an unnecessary duplication. Remove the allocation failure messages. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-18netconsole: enable netconsole can make net_device refcnt incorrentGao feng
There is no check if netconsole is enabled current. so when exec echo 1 > enabled; the reference of net_device will increment always. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Acked-by: Flavio Leitner <fbl@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-20netconsole: switch init_netconsole() to late_initcallLin Ming
Commit 88491d8(drivers/net: Kconfig & Makefile cleanup) causes a regression that netconsole does not work if netconsole and network device driver are build into kernel, because netconsole is linked before network device driver. Andrew Morton suggested to fix this with initcall ordering. Fixes it by switching init_netconsole() to late_initcall. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22net: rename NETDEV_BONDING_DESLAVE to NETDEV_RELEASEAmerigo Wang
s/NETDEV_BONDING_DESLAVE/NETDEV_RELEASE/ as Andy suggested. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Andy Gospodarek <andy@greyhouse.net> Cc: Neil Horman <nhorman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22netpoll: disable netpoll when enslave a deviceAmerigo Wang
V3: rename NETDEV_ENSLAVE to NETDEV_JOIN Currently we do nothing when we enslave a net device which is running netconsole. Neil pointed out that we may get weird results in such case, so let's disable netpoll on the device being enslaved. I think it is too harsh to prevent the device being ensalved if it is running netconsole. By the way, this patch also removes the NETDEV_GOING_DOWN from netconsole netdev notifier, because netpoll will check if the device is running or not and we don't handle NETDEV_PRE_UP neither. This patch is based on net-next-2.6. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Neil Horman <nhorman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-09net: add mac_pton() for parsing MAC addressAlexey Dobriyan
mac_pton() parses MAC address in form XX:XX:XX:XX:XX:XX and only in that form. mac_pton() doesn't dirty result until it's sure string representation is valid. mac_pton() doesn't care about characters _after_ last octet, it's up to caller to deal with it. mac_pton() diverges from 0/-E return value convention. Target usage: if (!mac_pton(str, whatever->mac)) return -EINVAL; /* ->mac being u8 [ETH_ALEN] is filled at this point. */ /* optionally check str[3 * ETH_ALEN - 1] for termination */ Use mac_pton() in pktgen and netconsole for start. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-09netconsole: switch to kstrto*() functionsAlexey Dobriyan
2011-04-22netconsole: fix deadlock when removing net driver that netconsole is using (v2)Neil Horman
A deadlock was reported to me recently that occured when netconsole was being used in a virtual guest. If the virtio_net driver was removed while netconsole was setup to use an interface that was driven by that driver, the guest deadlocked. No backtrace was provided because netconsole was the only console configured, but it became clear pretty quickly what the problem was. In netconsole_netdev_event, if we get an unregister event, we call __netpoll_cleanup with the target_list_lock held and irqs disabled. __netpoll_cleanup can, if pending netpoll packets are waiting call cancel_delayed_work_sync, which is a sleeping path. the might_sleep call in that path gets triggered, causing a console warning to be issued. The netconsole write handler of course tries to take the target_list_lock again, which we already hold, causing deadlock. The fix is pretty striaghtforward. Simply drop the target_list_lock and re-enable irqs prior to calling __netpoll_cleanup, the re-acquire the lock, and restart the loop. Confirmed by myself to fix the problem reported. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-06netconsole: clarify stopping messageFerenc Wagner
Signed-off-by: Ferenc Wagner <wferi@niif.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-06netconsole: don't announce stopping if nothing happenedFerenc Wagner
2010-10-18bonding: Fix netconsole to not deadlock on rmmodNeil Horman
Netconsole calls netpoll_cleanup on receipt of a NETDEVICE_UNREGISTER event. The notifier subsystem calls these event handlers with rtnl_lock held, which netpoll_cleanup also takes, resulting in deadlock. Fix this by calling the __netpoll_cleanup interior function instead, and fixing up the additional pointers. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-06netpoll: add generic support for bridge and bonding devicesWANG Cong
This whole patchset is for adding netpoll support to bridge and bonding devices. I already tested it for bridge, bonding, bridge over bonding, and bonding over bridge. It looks fine now. To make bridge and bonding support netpoll, we need to adjust some netpoll generic code. This patch does the following things: 1) introduce two new priv_flags for struct net_device: IFF_IN_NETPOLL which identifies we are processing a netpoll; IFF_DISABLE_NETPOLL is used to disable netpoll support for a device at run-time; 2) introduce one new method for netdev_ops: ->ndo_netpoll_cleanup() is used to clean up netpoll when a device is removed. 3) introduce netpoll_poll_dev() which takes a struct net_device * parameter; export netpoll_send_skb() and netpoll_poll_dev() which will be used later; 4) hide a pointer to struct netpoll in struct netpoll_info, ditto. 5) introduce ->real_dev for struct netpoll. 6) introduce a new status NETDEV_BONDING_DESLAE, which is used to disable netconsole before releasing a slave, to avoid deadlocks. Cc: David Miller <davem@davemloft.net> Cc: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-05-01netconsole: take care of NETDEV_UNREGISTER eventBruno Prémont
When netconsole is loaded and a network interface fades away (e.g. on rmmod $interface_driver_module) the rmmod remains stuck and some locks are taken that prevent any additional module loading/unloading as well as interface up/down changes. In addition kernel logs (and console) get flooded at 10s interval with [ 122.464065] unregister_netdevice: waiting for eth0 to become free. Usage count = 1 [ 132.704059] unregister_netdevice: waiting for eth0 to become free. Usage count = 1 This patch lets netconsole take NETDEV_UNREGISTER event into account and release the affected interface if it was in use. Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-28netpoll: store local and remote ip in net-endianHarvey Harrison
Allows for the removal of byteswapping in some places and the removal of HIPQUAD (replaced by %pI4). Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-01Remove newline from the description of module parametersNiels de Vos
Some module parameters with only one line have the '\n' at the end of the description. This is not needed nor wanted as after the description the type (i.e. int) is followed by a newline. Some modules contain a multi-line description, these are not affected by this patch. Signed-off-by: Niels de Vos <niels.devos@wincor-nixdorf.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: John W. Linville <linville@tuxdriver.com> Cc: Ed L. Cashin <ecashin@coraid.com> Cc: Dave Airlie <airlied@linux.ie> Cc: Roland Dreier <rolandd@cisco.com> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-17configfs: Allow ->make_item() and ->make_group() to return detailed errors.Joel Becker
The configfs operations ->make_item() and ->make_group() currently return a new item/group. A return of NULL signifies an error. Because of this, -ENOMEM is the only return code bubbled up the stack. Multiple folks have requested the ability to return specific error codes when these operations fail. This patch adds that ability by changing the ->make_item/group() ops to return ERR_PTR() values. These errors are bubbled up appropriately. NULL returns are changed to -ENOMEM for compatibility. Also updated are the in-kernel users of configfs. This is a rework of reverted commit 11c3b79218390a139f2d474ee1e983a672d5839a. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2008-07-17Revert "configfs: Allow ->make_item() and ->make_group() to return detailed ↵Joel Becker
errors." This reverts commit 11c3b79218390a139f2d474ee1e983a672d5839a. The code will move to PTR_ERR(). Signed-off-by: Joel Becker <joel.becker@oracle.com>
2008-07-14configfs: Allow ->make_item() and ->make_group() to return detailed errors.Joel Becker
The configfs operations ->make_item() and ->make_group() currently return a new item/group. A return of NULL signifies an error. Because of this, -ENOMEM is the only return code bubbled up the stack. Multiple folks have requested the ability to return specific error codes when these operations fail. This patch adds that ability by changing the ->make_item/group() ops to return an int. Also updated are the in-kernel users of configfs. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2008-04-15netconsole: only set CON_PRINTBUFFER if the user specifies a netconsoleMichael Ellerman
Since 0bcc1816188e570bde1d56a208996660f2633ae0 (netconsole: Support dynamic reconfiguration using configfs), the netconsole is always registered, regardless of whether the user actually specified a netconsole configuration on the command line. However because netconsole has CON_PRINTBUFFER set, when it is registered it causes the printk buffer to be replayed to all consoles. When there is no netconsole configured this is a) pointless, and b) somewhat annoying for the user of the existing console. So instead we should only set CON_PRINTBUFFER if there is a netconsole configuration found on the command line. This retains the existing behaviour if a netconsole is setup by the user, and avoids spamming other consoles when we're only registering for the dynamic netconsole case. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-15netconsole: avoid null pointer dereference at show_local_mac()Keiichi KII
This patch avoids a null pointer dereference when we read local_mac for netconsole in configfs and shows default local mac address value. A null pointer dereference occurs when we call show_local_mac() via local_mac entry in configfs before we setup the content of netpoll using netpoll_setup(). Signed-off-by: Keiichi KII <k-keiichi@bx.jp.nec.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETPOLL]: no need to store local_macStephen Hemminger
The local_mac is managed by the network device, no need to keep a spare copy and all the management problems that could cause. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET] netconsole: Support dynamic reconfiguration using configfsSatyam Sharma
Based upon initial work by Keiichi Kii <k-keiichi@bx.jp.nec.com>. This patch introduces support for dynamic reconfiguration (adding, removing and/or modifying parameters of netconsole targets at runtime) using a userspace interface exported via configfs. Documentation is also updated accordingly. Issues and brief design overview: (1) Kernel-initiated creation / destruction of kernel objects is not possible with configfs -- the lifetimes of the "config items" is managed exclusively from userspace. But netconsole must support boot/module params too, and these are parsed in kernel and hence netpolls must be setup from the kernel. Joel Becker suggested to separately manage the lifetimes of the two kinds of netconsole_target objects -- those created via configfs mkdir(2) from userspace and those specified from the boot/module option string. This adds complexity and some redundancy here and also means that boot/module param-created targets are not exposed through the configfs namespace (and hence cannot be updated / destroyed dynamically). However, this saves us from locking / refcounting complexities that would need to be introduced in configfs to support kernel-initiated item creation / destroy there. (2) In configfs, item creation takes place in the call chain of the mkdir(2) syscall in the driver subsystem. If we used an ioctl(2) to create / destroy objects from userspace, the special userspace program is able to fill out the structure to be passed into the ioctl and hence specify attributes such as local interface that are required at the time we set up the netpoll. For configfs, this information is not available at the time of mkdir(2). So, we keep all newly-created targets (via configfs) disabled by default. The user is expected to set various attributes appropriately (including the local network interface if required) and then write(2) "1" to the "enabled" attribute. Thus, netpoll_setup() is then called on the set parameters in the context of _this_ write(2) on the "enabled" attribute itself. This design enables the user to reconfigure existing netconsole targets at runtime to be attached to newly-come-up interfaces that may not have existed when netconsole was loaded or when the targets were actually created. All this effectively enables us to get rid of custom ioctls. (3) Ultra-paranoid configfs attribute show() and store() operations, with sanity and input range checking, using only safe string primitives, and compliant with the recommendations in Documentation/filesystems/sysfs.txt. (4) A new function netpoll_print_options() is created in the netpoll API, that just prints out the configured parameters for a netpoll structure. netpoll_parse_options() is modified to use that and it is also exported to be used from netconsole. Signed-off-by: Satyam Sharma <satyam@infradead.org> Acked-by: Keiichi Kii <k-keiichi@bx.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET] netconsole: Support multiple logging targetsSatyam Sharma
Based upon initial work by Keiichi Kii <k-keiichi@bx.jp.nec.com>. This patch introduces support for multiple targets, independent of CONFIG_NETCONSOLE_DYNAMIC -- this is useful even in the default case and (including the infrastructure introduced in previous patches) doesn't really add too many bytes to module text. All the complexity (and size) comes with the dynamic reconfigurability / userspace interface patch, and so it's plausible users may want to keep this enabled but that disabled (say to avoid a dependency on CONFIG_CONFIGFS_FS too). Also update documentation to mention the use of ";" separator to specify multiple logging targets in the boot/module option string. Brief overview: We maintain a target_list (and corresponding lock). Get rid of the static "default_target" and introduce allocation and release functions for our netconsole_target objects (but keeping sure to preserve previous behaviour such as default values). During init_netconsole(), ";" is used as the separator to identify multiple target specifications in the boot/module option string. The target specifications are parsed and netpolls setup. During exit, the target_list is torn down and all items released. Signed-off-by: Satyam Sharma <satyam@infradead.org> Signed-off-by: Keiichi Kii <k-keiichi@bx.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET] netconsole: Introduce netconsole_netdev_notifierSatyam Sharma
Based upon initial work by Keiichi Kii <k-keiichi@bx.jp.nec.com>. To update fields of underlying netpoll structure at runtime on corresponding NETDEV_CHANGEADDR or NETDEV_CHANGENAME notifications. ioctl(SIOCSIFHWADDR or SIOCSIFNAME) could be used to change the hardware/MAC address or name of the local interface that our netpoll is attached to. Whenever this happens, netdev notifier chain is called out with the NETDEV_CHANGEADDR or NETDEV_CHANGENAME event message. We respond to that and update the local_mac or dev_name field of the struct netpoll. This makes sense anyway, but is especially required for dynamic netconsole because the netpoll structure's internal members become user visible files when either sysfs or configfs are used. So this helps us to keep up with the MAC address/name changes and keep values in struct netpoll uptodate. [ Note that ioctl(SIOCSIFADDR) to change IP address of interface at runtime is not handled (to update local_ip of netpoll) on purpose -- some setups may set the local_ip to a private address, not necessary the actual IP address of the sender host, as presently allowed. ] Signed-off-by: Satyam Sharma <satyam@infradead.org> Signed-off-by: Keiichi Kii <k-keiichi@bx.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET] netconsole: Introduce netconsole_targetSatyam Sharma
Based upon initial work by Keiichi Kii <k-keiichi@bx.jp.nec.com>. Introduce a wrapper structure over netpoll to represent logging targets configured in netconsole. This will get extended with other members in further patches. This is done independent of the (to-be-introduced) NETCONSOLE_DYNAMIC config option so that we're able to drastically cut down on the #ifdef complexity of final netconsole.c. Also, struct netconsole_target would be required for multiple targets support also, and not just dynamic reconfigurability. Signed-off-by: Satyam Sharma <satyam@infradead.org> Signed-off-by: Keiichi Kii <k-keiichi@bx.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET] netconsole: Use netif_running() in write_msg()Satyam Sharma
Based upon initial work by Keiichi Kii <k-keiichi@bx.jp.nec.com>. Avoid unnecessarily disabling interrupts and calling netpoll_send_udp() if the corresponding local interface is not up. Signed-off-by: Satyam Sharma <satyam@infradead.org> Acked-by: Keiichi Kii <k-keiichi@bx.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET] netconsole: Simplify boot/module option setup logicSatyam Sharma
Based upon initial work by Keiichi Kii <k-keiichi@bx.jp.nec.com>. Presently, boot/module parameters are set up quite differently for the case of built-in netconsole (__setup() -> obsolete_checksetup() -> netpoll_parse_options() -> strlen(config) == 0 in init_netconsole()) vs modular netconsole (module_param_string() -> string copied to the config variable -> strlen(config) != 0 init_netconsole() -> netpoll_parse_options()). This patch makes both of them similar by doing exactly the equivalent of a module_param_string() in option_setup() also -- just copying the param string passed from the kernel command line into "config" variable. So, strlen(config) != 0 in both cases, and netpoll_parse_options() is always called from init_netconsole(), thus making the setup logic for both cases similar. Now, option_setup() is only ever called / used for the built-in case, so we put it inside a #ifndef MODULE, otherwise gcc will complain about option_setup() being "defined but not used". Also, the "configured" variable is redundant with this patch and hence removed. Signed-off-by: Satyam Sharma <satyam@infradead.org> Signed-off-by: Keiichi Kii <k-keiichi@bx.jp.nec.com> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET] netconsole: Remove bogus checkSatyam Sharma
Based upon initial work by Keiichi Kii <k-keiichi@bx.jp.nec.com>. The (!np.dev) check in write_msg() is bogus (always false), because: np.dev is set by netpoll_setup(), which is called by init_netconsole() before register_console(), so write_msg() cannot be triggered unless netpoll_setup() successfully set np.dev. Also np.dev cannot go away from under us, because netpoll_setup() grabs us reference on it. So let's remove the bogus check. Signed-off-by: Satyam Sharma <satyam@infradead.org> Acked-by: Keiichi Kii <k-keiichi@bx.jp.nec.com> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET] netconsole: Cleanups, codingstyle, prettyficationSatyam Sharma
Based upon initial work by Keiichi Kii <k-keiichi@bx.jp.nec.com>. (1) Remove unwanted headers. (2) Mark __init and __exit as appropriate. (3) Various trivial codingstyle and prettification stuff. Signed-off-by: Satyam Sharma <satyam@infradead.org> Signed-off-by: Keiichi Kii <k-keiichi@bx.jp.nec.com> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02netpoll queue cleanupStephen Hemminger
The beast had a long and not very happy history. At one point, a friend (netdump) had asked that he open up a little. Well, the friend was long gone now, and the beast had this dangling piece hanging (netpoll_queue). It wasn't hard to stitch the netpoll_queue back in where it belonged and make everything tidy. Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
2006-12-02netpoll setup error handlingStephen Hemminger
The beast was not always healthy. When it was sick, it tended to be laconic and not tell anyone the real problem. A few small changes had it telling the world about its problems, if they really wanted to hear. Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
2006-06-05[NETCONSOLE]: Clean up initcall warning.Matt Mackall
From: Matt Mackall <mpm@selenic.com> netconsole is being wrong here. If it wasn't enabled there's no error. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NET] netconsole: set .name in struct consoleRandy Dunlap
Set .name in netconsole's struct console to identify the struct's owner. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-31[PATCH] Don't pass boot parameters to argv_init[]OGAWA Hirofumi
The boot cmdline is parsed in parse_early_param() and parse_args(,unknown_bootoption). And __setup() is used in obsolete_checksetup(). start_kernel() -> parse_args() -> unknown_bootoption() -> obsolete_checksetup() If __setup()'s callback (->setup_func()) returns 1 in obsolete_checksetup(), obsolete_checksetup() thinks a parameter was handled. If ->setup_func() returns 0, obsolete_checksetup() tries other ->setup_func(). If all ->setup_func() that matched a parameter returns 0, a parameter is seted to argv_init[]. Then, when runing /sbin/init or init=app, argv_init[] is passed to the app. If the app doesn't ignore those arguments, it will warning and exit. This patch fixes a wrong usage of it, however fixes obvious one only. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
