path: root/drivers/net/natsemi.c
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18drivers/net: request_irq - Remove unnecessary leading & from second argJoe Perches
Not as fancy as coccinelle. Checkpatch errors ignored. Compile tested allyesconfig x86, not all files compiled. grep -rPl --include=*.[ch] "\brequest_irq\s*\([^,\)]+,\s*\&" drivers/net | while read file ; do \ perl -i -e 'local $/; while (<>) { s@(\brequest_irq\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\ done Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-03netdev: Remove redundant checks for CAP_NET_ADMIN in MDIO implementationsBen Hutchings
dev_ioctl() already checks capable(CAP_NET_ADMIN) before calling the driver's implementation of MDIO ioctls. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-03netdev: Remove SIOCDEVPRIVATE aliases for MDIO ioctlsBen Hutchings
The standard MDIO ioctl numbers are well-established and these should no longer be needed. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: arch/microblaze/include/asm/socket.h
2009-07-08Remove multiple KERN_ prefixes from printk formatsJoe Perches
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up handling of log-levels and newlines") changed printk semantics. printk lines with multiple KERN_<level> prefixes are no longer emitted as before the patch. <level> is now included in the output on each additional use. Remove all uses of multiple KERN_<level>s in formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26natsemi: fix non-constant printk warningsStephen Hemminger
2009-01-21net: Remove redundant NAPI functionsBen Hutchings
Following the removal of the unused struct net_device * parameter from the NAPI functions named *netif_rx_* in commit 908a7a1, they are exactly equivalent to the corresponding *napi_* functions and are therefore redundant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-07natsemi: update to net_device_opsStephen Hemminger
2008-12-22net: Remove unused netdev arg from some NAPI interfaces.Neil Horman
When the napi api was changed to separate its 1:1 binding to the net_device struct, the netif_rx_[prep|schedule|complete] api failed to remove the now vestigual net_device structure parameter. This patch cleans up that api by properly removing it.. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08netdev: uniquify the tx_timeout nameArjan van de Ven
there's several drivers that have use "tx_timeout" for the .. tx timeout function. All fine with that, they're static, however for doing stats on how often which driver hits the timeout it's a tad unfortunate. The patch below gives the ones I found in the kerneloops.org database unique names. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-13[netdrvr] Trim trailing whitespace for several driversJeff Garzik
2008-04-17natsemi: fix MMIO for PPC 44x platformsSergei Shtylyov
The driver stores the PCI resource address into 'unsigned long' variable before calling ioremap() on it. This warrants a kernel oops when the registers are accessed on PPC 44x platforms which (being 32-bit) have PCI memory space mapped beyond 4 GB. The arch/ppc/ kernel has a fixup in ioremap() that creates an illusion of the PCI memory resources are mapped below 4 GB, but arch/powerpc/ code got rid of this trick, having instead CONFIG_RESOURCES_64BIT enabled. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-03-26misc drivers/net annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-09natsemi: section fixAndrew Morton
gcc-3.4.4 on powerpc: drivers/net/natsemi.c:245: error: natsemi_pci_info causes a section type conflict Cc: Jeff Garzik <jeff@garzik.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-03natsemi: Update locking documentationMark Brown
The documentation regarding synchronisation at the head of the natsemi driver was badly bitrotted so replace it with a general statement about the techniques used which is less likely to bitrot. Also remove the note saying these chips are uncommon - it makes little difference but they were used in a number of laptops and at least one mass market PCI ethernet card. Signed-off-by: Mark Brown <broonie@sirena.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-08[NET]: Do not check netif_running() and carrier state in ->poll()David S. Miller
Drivers do this to try to break out of the ->poll()'ing loop when the device is being brought administratively down. Now that we have a napi_disable() "pending" state we are going to solve that problem generically. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-25natsemi: fix oops, link back netdevice from private-structIngo Molnar
* Andrew Nelless <andrew@nelless.net> wrote: > Hi, > > I booted up 2.6.24-rc1 this morning [Real early over a brew ;-)] and > was having a problems with multiple ~5 second hangs on SATA/drive init > (Something to do with "EH" something-or-other and resets but I'll > email in separately about it later unless its fixed by the time I get > the chance). > > Anyway, I went to fire up netconsole to get a decent log dump and hit > across the following nasty. Netconsole works fine in 2.6.23.1 with a > similar config and the same kernel parameters. > > A shot of the screen is the only method I could come up with to > capture the log, I hope that is OK, it is pretty readable. > > > The nasty: > http://andotnet.nfshost.com/linux/2.6.24-rc1-netconsole-nullderef.jpg the NULL dereference is here: (gdb) list *0xffffffff804a9504 0xffffffff804a9504 is in natsemi_poll (drivers/net/natsemi.c:717). 712 return count; 713 } 714 715 static inline void __iomem *ns_ioaddr(struct net_device *dev) 716 { 717 return (void __iomem *) dev->base_addr; 718 } 719 which is this code from natsemi.c: 2227 struct net_device *dev = np->dev; 2228 void __iomem * ioaddr = ns_ioaddr(dev); 2229 int work_done = 0; seems like the NAPI changes in -rc1 added an np->dev field but forgot to initialize it ... does the patch below fix the oops for you? Ingo --------------------> Subject: natsemi: fix oops, link back netdevice from private-struct From: Ingo Molnar <mingo@elte.hu> this commit: commit bea3348eef27e6044b6161fd04c3152215f96411 Author: Stephen Hemminger <shemminger@linux-foundation.org> Date: Wed Oct 3 16:41:36 2007 -0700 [NET]: Make NAPI polling independent of struct net_device objects. added np->dev to drivers/net/natsemi.c's struct netdev_private, but forgot to initialize that new field upon driver init. The result was a predictable NULL dereference oops the first time the hardware generated an interrupt. Reported-by: Andrew Nelless <andrew@nelless.net> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-20Typo: depricated -> deprecatedRolf Eike Beer
Typo: depricated -> deprecated Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-15natsemi: Check return value for pci_enable_device()Mark Brown
pci_enable_device() is __must_check so do that in natsemi_resume(). Signed-off-by: Mark Brown <broonie@sirena.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-15natsemi: Use round_jiffies() for slow timersMark Brown
Unless we have failed to fill the RX ring the timer used by the natsemi driver is not particularly urgent and can use round_jiffies() to allow grouping with other timers. Signed-off-by: Mark Brown <broonie@sirena.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10natsemi: Use NATSEMI_TIMER_FREQ consistentlyMark Brown
The natsemi driver has a define NATSEMI_TIMER_FREQ which looks like it controls the normal frequency of the chip poll timer but in fact only takes effect for the first run of the timer. Adjust the value of the define to match that used by the timer and use the define consistently. Signed-off-by: Mark Brown <broonie@sirena.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10network drivers: sparse warning fixesStephen Hemminger
Fix some of the easy warnings in network device drivers. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make NAPI polling independent of struct net_device objects.Stephen Hemminger
Several devices have multiple independant RX queues per net device, and some have a single interrupt doorbell for several queues. In either case, it's easier to support layouts like that if the structure representing the poll is independant from the net device itself. The signature of the ->poll() call back goes from: int foo_poll(struct net_device *dev, int *budget) to int foo_poll(struct napi_struct *napi, int budget) The caller is returned the number of RX packets processed (or the number of "NAPI credits" consumed if you want to get abstract). The callee no longer messes around bumping dev->quota, *budget, etc. because that is all handled in the caller upon return. The napi_struct is to be embedded in the device driver private data structures. Furthermore, it is the driver's responsibility to disable all NAPI instances in it's ->stop() device close handler. Since the napi_struct is privatized into the driver's private data structures, only the driver knows how to get at all of the napi_struct instances it may have per-device. With lots of help and suggestions from Rusty Russell, Roland Dreier, Michael Chan, Jeff Garzik, and Jamal Hadi Salim. Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra, Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan. [ Ported to current tree and all drivers converted. Integrated Stephen's follow-on kerneldoc additions, and restored poll_list handling to the old style to fix mutual exclusion issues. -DaveM ] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-14natsemi: fix netdev error acountingAndrew Morton
When a detailed netdev error is counted, we also must account for it in the aggregated error count. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=8106 Cc: Tim Hockin <thockin@hockin.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Chongfeng Hu <loveminix@yahoo.com.cn> Cc: Natalie Protasevich <protasnb@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17[netdrvr] natsemi: Fix device removal bugJeff Garzik
This episode illustrates how an overused warning can train people to ignore that warning, which winds up hiding bugs. The warning drivers/net/natsemi.c: In function ‘natsemi_remove1’: drivers/net/natsemi.c:3222: warning: ignoring return value of ‘device_create_file’, declared with attribute warn_unused_result is oft-ignored, even though at close inspection one notices this occurs in the /remove/ function, not normally where creation occurs. A quick s/create/remove/ and we are fixed, with the warning gone. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-10[NET]: Kill eth_copy_and_sum().David S. Miller
It hasn't "summed" anything in over 7 years, and it's just a straight mempcy ala skb_copy_to_linear_data() so just get rid of it. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-20natsemi irq flagsGregory Haskins
The spinlock irq flags should be a unsigned long to properly support 64 bit Signed-off-by: Gregory Haskins <ghaskins@novell.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-09remove broken URLs from net drivers' outputMarkus Dahms
Remove broken URLs (www.scyld.com) from network drivers' logging output. URLs in comments and other strings are left intact. Signed-off-by: Markus Dahms <dahms@fh-brandenburg.de> Acked-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Alan Cox <alan@redhat.com> igned-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08Subject: natsemi: Allow users to disable workaround for DspCfg resetMark Brown
The natsemi driver contains a workaround for broken hardware which can partially reset the chip at unpredictable times, detected by checking for spontaneous changes in the DspCfg register. The effects of the hardware bug appear to be variable and can range from minor problems like small numbers of corrupted packets to major ones such as the chip becoming non-functional. In the case of minor problems the chip reconfiguration required to work around the hardware can cause more problems than the bug itself. Since we have no way of automatically determining how badly the problem manifests on any given system provide an option in sysfs allowing users to disable the workaround at runtime and provides a module option to set the default. Signed-Off-By: Mark Brown <broonie@sirena.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08natsemi: Improve diagnostics for DspCfg workaroundMark Brown
The natsemi driver has a workaround for broken hardware which resets itself from time to time. There is a diagnostic message for this workaround but it is not printed by default, making the driver behavior more obscure than it needs to be. Make the message be displayed by default. Signed-Off-By: Mark Brown <broonie@sirena.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-15natsemi: Avoid IntrStatus lossage if RX state machine resets.broonie@sirena.org.uk
This patch fixes the poll routine for the natsemi driver so that if the driver detects an RX state machine lockup then no interrupts will be lost while the driver recovers from that. Signed-Off-By: Mark Brown <broonie@sirena.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-03-15natsemi: Fix NAPI for interrupt sharingbroonie@sirena.org.uk
The interrupt status register for the natsemi chips is clear on read and was read unconditionally from both the interrupt and from the NAPI poll routine, meaning that if the interrupt service routine was called (for example, due to a shared interrupt) while a NAPI poll was scheduled interrupts could be missed. This patch fixes that by ensuring that the interrupt status register is only read by the interrupt handler when interrupts are enabled from the chip. It also reverts a workaround for this problem from the netpoll hook and improves the trace for interrupt events. Thanks to Sergei Shtylyov <sshtylyov@ru.mvista.com> for spotting the issue, Mark Huth <mhuth@mvista.com> for a simpler method and Simon Blake <simon@citylink.co.nz> for testing resources. Signed-Off-By: Mark Brown <broonie@sirena.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-03-15natsemi: Consistently use interrupt enable/disable functionsbroonie@sirena.org.uk
The natsemi drivers include functions for enabling and disabling interrupts from the chip but these are not used in all code paths. This patch changes the code paths that touch the interrupt enable register to use the functions. In all cases this adds an extra PCI read to post the operation but since none of these are in fast paths this shouldn't be too much of a problem. Signed-Off-By: Mark Brown <broonie@sirena.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-03-06natsemi: netpoll fixesSergei Shtylyov
Fix two issues in this driver's netpoll path: one usual, with spin_unlock_irq() enabling interrupts which nobody asks it to do (that has been fixed recently in a number of drivers) and one unusual, with poll_controller() method possibly causing loss of interrupts due to the interrupt status register being cleared by a simple read and the interrpupt handler simply storing it, not accumulating. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27natsemi: Fix detection of vanilla natsemi cardsMark Brown
Bob Tracy <rct@gherkin.frus.com> reported that the addition of support for Aculab E1/T1 cPCI carrier cards broke detection of vanilla natsemi cards. This patch fixes that: the problem is that the driver-specific ta in the PCI device table is an index into a second table and this had not been updated for the vanilla cards. This patch fixes the problem minimally. Signed-Off-By: Mark Brown <broonie@sirena.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-20natsemi: Support Aculab E1/T1 PMXc cPCI carrier cardsMark Brown
Aculab E1/T1 PMXc cPCI carrier card cards present a natsemi on the cPCI bus with an oversized EEPROM using a direct MII<->MII connection with no PHY. This patch adds a new device table entry supporting these cards. Signed-Off-By: Mark Brown <broonie@sirena.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-20natsemi: Add support for using MII port with no PHYMark Brown
This patch provides code paths which allow the natsemi driver to use the external MII port on the chip but ignore any PHYs that may be attached to it. The link state will be left as it was when the driver started and can be configured via ethtool. Any PHYs that are present can be accessed via the MII ioctl()s. This is useful for systems where the device is connected without a PHY or where either information or actions outside the scope of the driver are required in order to use the PHYs. Signed-Off-By: Mark Brown <broonie@sirena.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-09-12Merge branch 'tmp' into upstreamJeff Garzik
2006-09-12[PATCH] Remove more unnecessary driver printk'sAndy Gospodarek
As I promised last week, here is the first pass at removing all unnecessary printk's that exist in network device drivers currently in promiscuous mode. The duplicate messages are not needed so they have been removed. Some of these drivers are quite old and might not need an update, but I did them all anyway. I am currently auditing the remaining conditional printk's and will send out a patch for those soon. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
