path: root/drivers/net/myri10ge/myri10ge.c
2010-06-30ethtool: Change ethtool_op_set_flags to validate flagsBen Hutchings
ethtool_op_set_flags() does not check for unsupported flags, and has no way of doing so. This means it is not suitable for use as a default implementation of ethtool_ops::set_flags. Add a 'supported' parameter specifying the flags that the driver and hardware support, validate the requested flags against this, and change all current callers to pass this parameter. Change some other trivial implementations of ethtool_ops::set_flags to call ethtool_op_set_flags(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-14drivers: net: use skb_headlen()Eric Dumazet
replaces (skb->len - skb->data_len) occurrences by skb_headlen(skb) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13myri10ge: use the DMA state API instead of the pci equivalentsFUJITA Tomonori
This replace the PCI DMA state API (include/linux/pci-dma.h) with the DMA equivalents since the PCI DMA state API will be obsolete. No functional change. For further information about the background: http://marc.info/?l=linux-netdev&m=127037540020276&w=2 Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Andrew Gallatin <gallatin@myri.com> Cc: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-11Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2010-04-07myri10ge: fix rx_pause in myri10ge_set_pauseparamBrice Goglin
Fix rx_pause management in myri10ge_set_pauseparam(). Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-15myri: remove dead codeDan Carpenter
We can never reach the return statement. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26myri10ge: optimize 4k-boundary check when stocking rx pagesBrice Goglin
Small optimization to the code which checks to see if we'd cross a 4K boundary when stocking RX ring. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: Guillaume Morin <guillaume@morinfr.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26net: convert multiple drivers to use netdev_for_each_mc_addr, part5 V2Jiri Pirko
removed some needless checks and also corrected bug in lp486e (dmi was passed instead of dmi->dmi_addr) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26drivers/net/myri10ge: Use pr_<level> and netdev_<level>Joe Perches
Add #define pr_fmt(fmt) Convert logging messages to pr_<level> and netdev_<level> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-08myri10ge: use src+dst for rss hashingBrice Goglin
Use a more effective rss hash by default (src + dst, rather than just src). Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-10myri10ge: declare MODULE_FIRMWAREBen Hutchings
Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sh_eth.c
2009-10-22myri10ge: improve port type reporting in ethtoolBrice Goglin
Improve the reporting of myri10ge port type in ethtool, and update for new boards. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07myri10ge: Use the instance of net_device_stats from net_device.Ajit Khaparde
Since net_device has an instance of net_device_stats, we can remove the instance of this from the private myri10ge_priv structure. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12myri10ge: improve parity error detection and recoveryBrice Goglin
Improve myri10ge parity error detection and recovery: 1) Don't restore PCI config space to a rebooted NIC until AFTER the host is quiescent. 2) Let myri10ge_close() know the NIC is dead, so it won't waste time waiting for a dead nic to respond to MXGEFW_CMD_ETHERNET_DOWN 3) When the NIC is quiet (link down, or otherwise idle link) use a pci config space read to detect a rebooted NIC. Otherwise we might never notice that a NIC rebooted Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: convert remaining non-symbolic return values in ndo_start_xmit() functionsPatrick McHardy
This patch converts the remaining occurences of raw return values to their symbolic counterparts in ndo_start_xmit() functions that were missed by the previous automatic conversion. Additionally code that assumed the symbolic value of NETDEV_TX_OK to be zero is changed to explicitly use NETDEV_TX_OK. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13net: use symbolic values for ndo_start_xmit() return codesPatrick McHardy
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively. 0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases where its in direct proximity to one of the other values. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: dont update dev->trans_start in 10GB driversEric Dumazet
Followup of commits 9d21493b4beb8f918ba248032fefa393074a5e2b and 08baf561083bc27a953aa087dd8a664bb2b88e8e (net: tx scalability works : trans_start) (net: txq_trans_update() helper) Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Multi queue drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers (vxge & tehuti) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-25myri10ge: Add support for vlan_featuresBrice Goglin
Add support for netdev->vlan_features in the myri10ge driver. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-25myri10ge: drop myri10ge_lro module parameterBrice Goglin
Drop the myri10ge_lro module parameter now that we have ethtool to enable/disable LRO in the myri10ge driver. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-25myri10ge: fix the invokation of lro_flush_allBrice Goglin
Fix the way we check whether lro_flush_all should be called in the myri10ge driver. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-19myri10ge: update version to 1.5.0-1.415Brice Goglin
Update myri10ge driver version to 1.5.0-1.415. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-19myri10ge: allow LRO to be enabled via ethtoolBrice Goglin
Allow myri10ge LRO to be enabled/disabled via ethtool (and by the stack for packet forwarding). Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-17myri10ge: fix compile errorAndrew Gallatin
A compilation error snuck into 2d90b0aa3bc484189940444bcddcbe0ebbb53af5 due to an over-zealous indent script removing spaces around array initialization ellipsis. The attached patch fixes the myri10ge compilation in net-next. Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-16myri10ge: fix tx ring size in ethtool -gBrice Goglin
Fix tx ring size reported via ethtool -g. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-16myri10ge: add MODULE_DEVICE_TABLEBrice Goglin
Add MODULE_DEVICE_TABLE so that modinfo reports pci device id aliases. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-16myri10ge: allow per-board firmware overridingBrice Goglin
Add myri10ge_fw_names to override the default firmware on a per-board basis. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-16myri10ge: force stats update in ethtool gstatsBrice Goglin
Force a statistics update when our ethtool gstats routine is called. Otherwise, ethtool will continue to read stale stats until something forces an update by reading /proc/net/dev This requires putting a lock around the stats update to guard against 2 threads (one via ethtool, and one via procfs) updating the stats at once. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-15myr10ge: again fix lro_gen_skb() alignmentStanislaw Gruszka
Add LRO alignment initially committed in 621544eb8c3beaa859c75850f816dd9b056a00a3 ("[LRO]: fix lro_gen_skb() alignment") and removed in 0dcffac1a329be69bab0ac604bf7283737108e68 ("myri10ge: add multislices support") during conversion to multi-slice. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)Yang Hongyang
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-27net: Add skb_record_rx_queue() calls to multiqueue capable drivers.David S. Miller
2009-01-21net: Remove redundant NAPI functionsBen Hutchings
Following the removal of the unused struct net_device * parameter from the NAPI functions named *netif_rx_* in commit 908a7a1, they are exactly equivalent to the corresponding *napi_* functions and are therefore redundant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-20myri10ge: don't forget pci_disable_device()Brice Goglin
Don't forget to call pci_disable_device() in myri10ge_remove() and when myri10ge_probe() fails. By the way, update the copyright years. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-05myri10ge: print MAC and serial number on probe failureBrice Goglin
To help board identification and diagnosis, print the MAC and serial number on probe failure if they are available. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-26net: Fix warning fallout from recent NAPI interface changes.David S. Miller
When we removed the network device argument from several NAPI interfaces in 908a7a16b852ffd618a9127be8d62432182d81b4 ("net: Remove unused netdev arg from some NAPI interfaces.") several drivers now started getting unused variable warnings. This fixes those up. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-25myri10ge: update driver version to 1.4.4-1.395Brice Goglin
Update myri10ge driver version to 1.4.4-1.395. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-22net: Remove unused netdev arg from some NAPI interfaces.Neil Horman
When the napi api was changed to separate its 1:1 binding to the net_device struct, the netif_rx_[prep|schedule|complete] api failed to remove the now vestigual net_device structure parameter. This patch cleans up that api by properly removing it.. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-09myri10ge: check fragmentation in LRO get_frag_header()Brice Goglin
Add a fragmentation check to myri10ge's LRO get_frag_header() callback. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-23myri10ge: update DCA commentsBrice Goglin
Update DCA sections closing comments. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21myri10ge: convert to net_device_opsStephen Hemminger
Convert driver to new net_device_ops. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20myri10ge: remove hardcoded sram_sizeBrice Goglin
Removes the use of a hardcoded sram_size, determine string_spec location from the MCP header instead. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20myri10ge: fix per-slice rx/tx_dropped countersBrice Goglin
Properly attribute transmit and receive drops by incrementing the per-slice counter. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
