Small optimization to the code which checks to see if we'd cross
a 4K boundary when stocking RX ring.
Signed-off-by: Brice Goglin <brice@myri.com>
Signed-off-by: Andrew Gallatin <gallatin@myri.com>
Signed-off-by: Guillaume Morin <guillaume@morinfr.org>
removed some needless checks and also corrected bug in lp486e (dmi was passed
instead of dmi->dmi_addr)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Add #define pr_fmt(fmt)
Convert logging messages to pr_<level> and netdev_<level>
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section
in every case.
Use a more effective rss hash by default (src + dst, rather than just
src).
Only files where David Miller is the primary git-signer.
wireless, wimax, ixgbe, etc are not modified.
Compile tested x86 allyesconfig only
Not all files compiled (not x86 compatible)
Added a few > 80 column lines, which I ignored.
Existing checkpatch complaints ignored.
drivers/net/sh_eth.c
Improve the reporting of myri10ge port type in ethtool,
and update for new boards.
Since net_device has an instance of net_device_stats,
we can remove the instance of this from the private myri10ge_priv structure.
Signed-off-by: Ajit Khaparde <ajitk@serverengines.com>
In a couple of cases collapse some extra code like:
int retval = NETDEV_TX_OK;
return retval;
into
return NETDEV_TX_OK;
Improve myri10ge parity error detection and recovery:
1) Don't restore PCI config space to a rebooted NIC until AFTER the
host is quiescent.
2) Let myri10ge_close() know the NIC is dead, so it won't waste time
waiting for a dead nic to respond to MXGEFW_CMD_ETHERNET_DOWN
3) When the NIC is quiet (link down, or otherwise idle link) use
a pci config space read to detect a rebooted NIC. Otherwise
we might never notice that a NIC rebooted
This patch converts the remaining occurences of raw return values to their
symbolic counterparts in ndo_start_xmit() functions that were missed by the
previous automatic conversion.
Additionally code that assumed the symbolic value of NETDEV_TX_OK to be zero
is changed to explicitly use NETDEV_TX_OK.
This patch is the result of an automatic spatch transformation to convert
all ndo_start_xmit() return values of 0 to NETDEV_TX_OK.
Some occurences are missed by the automatic conversion, those will be
handled in a seperate patch.
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively.
0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases
where its in direct proximity to one of the other values.
Followup of commits 9d21493b4beb8f918ba248032fefa393074a5e2b
and 08baf561083bc27a953aa087dd8a664bb2b88e8e
(net: tx scalability works : trans_start)
(net: txq_trans_update() helper)
Now that core network takes care of trans_start updates, dont do it
in drivers themselves, if possible. Multi queue drivers can
avoid one cache miss (on dev->trans_start) in their start_xmit()
handler.
Exceptions are NETIF_F_LLTX drivers (vxge & tehuti)
Add support for netdev->vlan_features in the myri10ge driver.
Drop the myri10ge_lro module parameter now that we have ethtool
to enable/disable LRO in the myri10ge driver.
Fix the way we check whether lro_flush_all should be called
Update myri10ge driver version to 1.5.0-1.415.
Allow myri10ge LRO to be enabled/disabled via ethtool
(and by the stack for packet forwarding).
A compilation error snuck into
2d90b0aa3bc484189940444bcddcbe0ebbb53af5
due to an over-zealous indent script removing spaces around array
initialization ellipsis. The attached patch fixes the myri10ge
compilation in net-next.
Fix tx ring size reported via ethtool -g.
Add MODULE_DEVICE_TABLE so that modinfo reports pci device id aliases.
Add myri10ge_fw_names to override the default firmware
on a per-board basis.
Force a statistics update when our ethtool gstats routine
is called. Otherwise, ethtool will continue to read stale
stats until something forces an update by reading /proc/net/dev
This requires putting a lock around the stats update to guard
against 2 threads (one via ethtool, and one via procfs)
updating the stats at once.
Add LRO alignment initially committed in
621544eb8c3beaa859c75850f816dd9b056a00a3 ("[LRO]: fix lro_gen_skb()
alignment") and removed in 0dcffac1a329be69bab0ac604bf7283737108e68
("myri10ge: add multislices support") during conversion to
multi-slice.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)
Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com>
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)
Following the removal of the unused struct net_device * parameter from
the NAPI functions named *netif_rx_* in commit 908a7a1, they are
exactly equivalent to the corresponding *napi_* functions and are
therefore redundant.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Don't forget to call pci_disable_device() in myri10ge_remove()
and when myri10ge_probe() fails.
By the way, update the copyright years.
To help board identification and diagnosis, print the MAC
and serial number on probe failure if they are available.
When we removed the network device argument from several
NAPI interfaces in 908a7a16b852ffd618a9127be8d62432182d81b4
("net: Remove unused netdev arg from some NAPI interfaces.")
several drivers now started getting unused variable warnings.
This fixes those up.
Update myri10ge driver version to 1.4.4-1.395.
When the napi api was changed to separate its 1:1 binding to the net_device
struct, the netif_rx_[prep|schedule|complete] api failed to remove the now
vestigual net_device structure parameter. This patch cleans up that api by
properly removing it..
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Add a fragmentation check to myri10ge's LRO get_frag_header() callback.
Update DCA sections closing comments.
Convert driver to new net_device_ops. Compile tested only.
Removes the use of a hardcoded sram_size, determine string_spec
location from the MCP header instead.
Properly attribute transmit and receive drops by incrementing the
per-slice counter.
drivers/isdn/i4l/isdn_net.c
fs/cifs/connect.c
The doorbell writes may be seen out of order by the firmware if they
are in WC memory since the tx spin(un)lock does not flush WC writes.
Hence if the "stop" is written on a different CPU than the "go", it
is possible that the stop will arrive after the go unless we add an
explicit memory barrier (and mmiowb() is not enough).
It fixes transmit hangs in multi tx queue mode.
The generic packet receive code takes care of setting
netdev->last_rx when necessary, for the sake of the
bonding ARP monitor.
Drivers need not do it any more.
Some cases had to be skipped over because the drivers
were making use of the ->last_rx value themselves.
drivers/net/wireless/p54/p54common.c
Use mmiowb() to ensure "stop" and "go" commands are sent in order on ia64.
This converts pretty much everything to print_mac. There were
a few things that had conflicts which I have just dropped for
now, no harm done.
I've built an allyesconfig with this and looked at the files
that weren't built very carefully, but it's a huge patch.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Disable NAPI if a failure occurs when setting up the interface. Leaving
it enabled could cause a BUG the next time an ifconfig up is issued.
We cannot select INTEL_IOATDMA in Kconfig as soon as MYRI10GE or IXGBE
is enabled since the former is not available on all architectures.
Just use a Kconfig bool {IXGBE,MYRI10GE}_DCA set to =y when DCA
support can actually be built.
[myri10ge portion written and signed-off-by] Brice Goglin <brice@myri.com>
Update myri10ge driver version number to 1.4.3-1.369.
