Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il>
en_params.c file now only handles Ethtool functionality
For each debug message, the message will show interface name in case
that the net device was registered, and PCI bus ID with port number
if we were not registered yet. Messages that are not port/netdev specific
stayed in the old format
Now using Ethtool to determine ring sizes, removed the module parameters
that controlled those values.
Modifying ring size requires restart of the interface.
Removed module parameter specifying number of RX rings
They are controlled through Ethtool interface.
They are controlled through Ethtool interface, no need to have two
ways to modify them.
Before the change the driver reported the same pause parameters
for all the ports, even only one of them was modified.
The Mellanox ConnectX can operate as an InfiniBand adapter, as an
Ethernet NIC, or as a Fibre Channel (FC) HBA. The kernel has a
low-level driver, mlx4_core, which handles multiplexing access to the
device, and there is also already an InfiniBad driver, mlx4_ib.
This patch adds a new driver, mlx4_en, which implements a standard
Ethernet NIC driver.
Signed-off-by: Liran Liss <liranl@mellanox.co.il>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
