path: root/drivers/net/macb.c
2008-07-02macb: Basic suspend/resume supportHaavard Skinnemoen
This implements suspend and resume callbacks for the macb driver. We may have to do some more to gracefully shut the MAC down, but this at least prevents the macb from waking the system when hooked up to a busy network. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Patrice Vilchez <patrice.vilchez@rfo.atmel.com> Cc: Nicolas FERRE <nicolas.ferre@rfo.atmel.com>
2008-04-25net drivers: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable network platform drivers, to re-enable auto loading. NOTE: didn't change drivers/net/fs_enet/fs_enet-main.c "old binding" support. That looks problematic in the first place (it even uses the ancient "struct device_driver" binding scheme for platform_bus!) and I suspect it will vanish soonish when arch/powerpc rules the world. Also, drivers/net/ne.c would have needed more thought to sort out. [akpm@linux-foundation.org: fix sgiseeq.c] [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Scott Wood <scottwood@freescale.com> Cc: Vitaly Bordug <vitb@kernel.crashing.org> Cc: Dale Farnsworth <dale@farnsworth.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Andrew Victor <andrew@sanpeople.com> Cc: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16phy: Change mii_bus id field to a stringAndy Fleming
Having the id field be an int was making more complex bus topologies excessively difficult. For now, just convert it to a string, and change all instances of "bus->id = val" to snprintf(id, MII_BUS_ID_LEN, "%x", val). Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-12macb: Use semicolon instead of comma for statementAtsushi Nemoto
It seems no good reason to use comma here. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-12macb: Call phy_disconnect on removingAtsushi Nemoto
Call phy_disconnect() on remove routine. Otherwise the phy timer causes a kernel crash when unloading. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-24macb: Fix speed settingAtsushi Nemoto
Fix NCFGR.SPD setting on 10Mbps. This bug was introduced by conversion to generic PHY layer in kernel 2.6.23. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-03macb: Fix section mismatch and shrink runtime footprintHaavard Skinnemoen
macb devices are only found integrated on SoCs, so they can't be hotplugged. Thus, the probe() and exit() functions can be __init and __exit, respectively. By using platform_driver_probe() instead of platform_driver_register(), there won't be any references to the discarded probe() function after the driver has loaded. This also fixes a section mismatch due to macb_probe(), defined as __devinit, calling macb_get_hwaddr, defined as __init. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-22MACB: clear transmit buffers properly on transmit underrunGregory CLEMENT
Initially transmit buffer pointers were only reset. But buffer descriptors were possibly still set as ready, and buffer in upper layer was not freed. This caused driver hang under big load. Now reset clean properly the buffer descriptor and freed upper layer. Signed-off-by: Gregory CLEMENT <gclement00@gmail.com> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make NAPI polling independent of struct net_device objects.Stephen Hemminger
Several devices have multiple independant RX queues per net device, and some have a single interrupt doorbell for several queues. In either case, it's easier to support layouts like that if the structure representing the poll is independant from the net device itself. The signature of the ->poll() call back goes from: int foo_poll(struct net_device *dev, int *budget) to int foo_poll(struct napi_struct *napi, int budget) The caller is returned the number of RX packets processed (or the number of "NAPI credits" consumed if you want to get abstract). The callee no longer messes around bumping dev->quota, *budget, etc. because that is all handled in the caller upon return. The napi_struct is to be embedded in the device driver private data structures. Furthermore, it is the driver's responsibility to disable all NAPI instances in it's ->stop() device close handler. Since the napi_struct is privatized into the driver's private data structures, only the driver knows how to get at all of the napi_struct instances it may have per-device. With lots of help and suggestions from Rusty Russell, Roland Dreier, Michael Chan, Jeff Garzik, and Jamal Hadi Salim. Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra, Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan. [ Ported to current tree and all drivers converted. Integrated Stephen's follow-on kerneldoc additions, and restored poll_list handling to the old style to fix mutual exclusion issues. -DaveM ] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-16macb: Add multicast capabilityPatrice Vilchez
Add multicast capability to Atmel ethernet macb driver. Signed-off-by: Patrice Vilchez <patrice.vilchez@rfo.atmel.com> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-16macb: Use generic PHY layerfrederic RODO
Convert the macb driver to use the generic PHY layer in drivers/net/phy. Signed-off-by: Frederic RODO <f.rodo@til-technologies.fr> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-25[SK_BUFF]: Introduce skb_copy_to_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying to linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-04-25[SK_BUFF]: Convert skb->end to sk_buff_data_tArnaldo Carvalho de Melo
Now to convert the last one, skb->data, that will allow many simplifications and removal of some of the offset helpers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-17macb: Remove inappropriate spinlocks around mii callsHaavard Skinnemoen
Remove spin_lock_irqsave() around mii_ethtool_gset, mii_ethtool_sset and generic_mii_ioctl. These are unnecessary and harmful because the mii calls may call back into the mdio functions, which may sleep. Pointed out by David Brownell. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-07Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6: (28 commits) sysfs: Shadow directory support Driver Core: Increase the default timeout value of the firmware subsystem Driver core: allow to delay the uevent at device creation time Driver core: add device_type to struct device Driver core: add uevent vars for devices of a class SYSFS: Fix missing include of list.h in sysfs.h HOWTO: Add a reference to Harbison and Steele sysfs: error handling in sysfs, fill_read_buffer() kobject: kobject_put cleanup sysfs: kobject_put cleanup sysfs: suppress lockdep warnings Driver core: fix race in sysfs between sysfs_remove_file() and read()/write() driver core: Change function call order in device_bind_driver(). driver core: Don't stop probing on ->probe errors. driver core fixes: device_register() retval check in platform.c driver core fixes: make_class_name() retval checks /sys/modules/*/holders USB: add the sysfs driver name to all modules SERIO: add the sysfs driver name to all modules PCI: add the sysfs driver name to all modules ...
2007-02-07AT91: MACB supportAndrew Victor
The Atmel MACB Ethernet peripheral is also integrated in the AT91SAM9260 and AT91SAM9263 processors. The differences from the AVR32 version are: * Single peripheral clock. * MII/RMII selection bit is inverted. * Clock enable bit. Original patch from Patrice Vilchez. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-07Network: convert network devices to use struct device instead of class_deviceGreg Kroah-Hartman
This lets the network core have the ability to handle suspend/resume issues, if it wants to. Thanks to Frederik Deweerdt <frederik.deweerdt@gmail.com> for the arm driver fixes. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-11[PATCH] MACB: Use __raw register accessHaavard Skinnemoen
Since macb is a chip-internal device, use __raw_readl and __raw_writel instead of readl/writel. This will perform native-endian accesses, which is the right thing to do on both AVR32 and ARM devices. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-11[PATCH] MACB: Use struct delayed_work instead of struct work_structHaavard Skinnemoen
The macb driver calls schedule_delayed_work() and friends, so we need to use a struct delayed_work along with it. The conversion was explained by David Howells on lkml Dec 5 2006: http://lkml.org/lkml/2006/12/5/269 Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-02[PATCH] Atmel MACB ethernet driverHaavard Skinnemoen
Driver for the Atmel MACB on-chip ethernet module. Tested on AVR32/AT32AP7000/ATSTK1000. I've heard rumours that it works with AT91SAM9260 as well, and it may be possible to share some code with the at91_ether driver for AT91RM9200. Hardware documentation can be found in the AT32AP7000 data sheet, which can be downloaded from http://www.atmel.com/dyn/products/datasheets.asp?family_id=682 Changes since previous version: * Probe for PHY ID instead of depending on it being provided through platform_data. * Grab initial ethernet address from the MACB registers instead of depending on platform_data. * Set MII/RMII mode correctly. These changes are mostly about making the driver more compatible with the at91 infrastructure. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
