path: root/drivers/net/lp486e.c
2008-08-07[netdrvr] Drivers should not set IFF_* flag themselvesWang Chen
Some hardware set promisc when they are requested to set IFF_ALLMULTI flag. It's ok, but if drivers set IFF_PROMISC flag when they set promisc, it will broken upper layer handle for promisc and allmulti. In addition, drivers can use their own hardware programming to make it. So do not allow drivers to set IFF_* flags. This is a general driver fix, so I didn't split it to pieces and send to specific driver maintainers. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-28[netdrvr] checkpatch cleanupsJeff Garzik
2008-01-28[netdrvr] irq handler minor cleanups in several driversJeff Garzik
* use irq_handler_t where appropriate * no need to use 'irq' function arg, its already stored in a data struct * rename irq handler 'irq' argument to 'dummy', where the function has been analyzed and proven not to use its first argument. * remove always-false "dev_id == NULL" test from irq handlers * remove pointless casts from void* * declance: irq argument is not const * add KERN_xxx printk prefix * fix minor whitespace weirdness Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-10[NET] drivers/net: statistics cleanup #1 -- save memory and shrink codeJeff Garzik
We now have struct net_device_stats embedded in struct net_device, and the default ->get_stats() hook does the obvious thing for us. Run through drivers/net/* and remove the driver-local storage of statistics, and driver-local ->get_stats() hook where applicable. This was just the low-hanging fruit in drivers/net; plenty more drivers remain to be updated. [ Resolved conflicts with napi_struct changes and fix sunqe build regression... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10drivers/net/: all drivers/net/ cleanup with ARRAY_SIZEDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-21Merge branch 'upstream-fixes' into upstreamJeff Garzik
2006-09-21[netdrvr] lp486e: fix typoJeff Garzik
inside #if 0'd code, but it bugged me. Really, we should probably just delete the driver. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[NET]: Avoid allocating skb in skb_padHerbert Xu
First of all it is unnecessary to allocate a new skb in skb_pad since the existing one is not shared. More importantly, our hard_start_xmit interface does not allow a new skb to be allocated since that breaks requeueing. This patch uses pskb_expand_head to expand the existing skb and linearize it if needed. Actually, someone should sift through every instance of skb_pad on a non-linear skb as they do not fit the reasons why this was originally created. Incidentally, this fixes a minor bug when the skb is cloned (tcpdump, TCP, etc.). As it is skb_pad will simply write over a cloned skb. Because of the position of the write it is unlikely to cause problems but still it's best if we don't do it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-01[PATCH] lp486e: remove SLOW_DOWN_IOAlexey Dobriyan
It's not used. Fix the following on alpha-eb66 as a side effect: In file included from drivers/net/lp486e.c:75: include/asm/io.h:20:1: warning: "SLOW_DOWN_IO" redefined drivers/net/lp486e.c:59:1: warning: this is the location of the previous definition Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
