path: root/drivers/net/lib82596.c
2007-10-23[NETDRVR] lib82596, netxen: delete pointless tests from irq handlerJeff Garzik
Remove always-false tests in irq handler. Also a few other minor cleanups. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET] drivers/net: statistics cleanup #1 -- save memory and shrink codeJeff Garzik
We now have struct net_device_stats embedded in struct net_device, and the default ->get_stats() hook does the obvious thing for us. Run through drivers/net/* and remove the driver-local storage of statistics, and driver-local ->get_stats() hook where applicable. This was just the low-hanging fruit in drivers/net; plenty more drivers remain to be updated. [ Resolved conflicts with napi_struct changes and fix sunqe build regression... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-08Extract chip specific code out of lasi_82596.cThomas Bogendoerfer
Changes to last version: - use netdev_alloc_skb - make init_rx_bufs just fail and not panic, if skb alloc fails - don/t free_irq, if request_irq failed Thomas. Extracted chip specific code out of lasi_82596.c and placed into a lib82596.c to make it usable for other 82596 drivers Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
