path: root/drivers/net/isa-skeleton.c
2008-12-03netdev: remove pathetic compile-command linesAlexey Dobriyan
-m486, -O6 are partircularly amusing. Remove some other useless lines near as well. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2005-05-12[netdrvr] Fix register_netdev() races in older ISA net drivers
