path: root/drivers/net/irda/smsc-ircc2.c
2010-07-21drivers/net/irda: use for_each_pci_dev()Kulikov Vasiliy
Use for_each_pci_dev() to simplify the code. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-04comment typo fix: sybsystem -> subsystemJean Delvare
Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-01irda: convert to netdev_tx_tStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: convert remaining non-symbolic return values in ndo_start_xmit() functionsPatrick McHardy
This patch converts the remaining occurences of raw return values to their symbolic counterparts in ndo_start_xmit() functions that were missed by the previous automatic conversion. Additionally code that assumed the symbolic value of NETDEV_TX_OK to be zero is changed to explicitly use NETDEV_TX_OK. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13irda: smsc wait count reaches -1Roel Kluin
The sir retries count reaches -1 rather than 0. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2009-03-21irda: convert smsc driver to net_device_opsStephen Hemminger
2009-01-06irda: convert to internal statsStephen Hemminger
Convert IRDA drivers to use already existing net_device_stats structure in network device. This is a pre-cursor to conversion to net_device ops. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-26drivers/net/irda: fix sparse warnings: make symbols staticHannes Eder
Fix this sparse warnings: drivers/net/irda/ma600-sir.c:239:5: warning: symbol 'ma600_reset' was not declared. Should it be static? drivers/net/irda/smsc-ircc2.c:875:5: warning: symbol 'smsc_ircc_hard_xmit_sir' was not declared. Should it be static? drivers/net/irda/smsc-ircc2.c:1131:6: warning: symbol 'smsc_ircc_set_sir_speed' was not declared. Should it be static? drivers/net/irda/smsc-ircc2.c:1897:6: warning: symbol 'smsc_ircc_sir_start' was not declared. Should it be static? drivers/net/irda/w83977af_ir.c:150:5: warning: symbol 'w83977af_open' was not declared. Should it be static? drivers/net/irda/w83977af_ir.c:313:5: warning: symbol 'w83977af_probe' was not declared. Should it be static? drivers/net/irda/w83977af_ir.c:412:6: warning: symbol 'w83977af_change_speed' was not declared. Should it be static? drivers/net/irda/w83977af_ir.c:492:5: warning: symbol 'w83977af_hard_xmit' was not declared. Should it be static? drivers/net/irda/w83977af_ir.c:734:5: warning: symbol 'w83977af_dma_receive' was not declared. Should it be static? drivers/net/irda/w83977af_ir.c:806:5: warning: symbol 'w83977af_dma_receive_complete' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-30irda: replace __FUNCTION__ with __func__Harvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11irda: remove CVS keywordsAdrian Bunk
This patch removes CVS keyword that weren't updated for a long time. One of them was printed as part of a printk, which also doesn't make much sense for a 5 year old and no longer updated keyword. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-05irda: fix !PNP support for drivers/net/irda/smsc-ircc2.cIngo Molnar
x86.git testing found this build bug on v2.6.26-rc1: ERROR: "pnp_get_resource" [drivers/net/irda/smsc-ircc2.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 the driver did not anticipate the case of !CONFIG_PNP which is rare but still possible. Instead of restricting the driver to PNP-only in the Kconfig space, add the (trivial) dummy struct pnp_driver - this is that other drivers use in the !PNP case too. The driver itself can in theory be initialized on !PNP too in certain cases, via smsc_ircc_legacy_probe(). Patch only minimally build tested, i dont have this hardware. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[netdrvr] irq handler minor cleanups in several driversJeff Garzik
* use irq_handler_t where appropriate * no need to use 'irq' function arg, its already stored in a data struct * rename irq handler 'irq' argument to 'dummy', where the function has been analyzed and proven not to use its first argument. * remove always-false "dev_id == NULL" test from irq handlers * remove pointless casts from void* * declance: irq argument is not const * add KERN_xxx printk prefix * fix minor whitespace weirdness Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-10[IRDA]: Document the fact that smsc-ircc2 will not use PNP by defaultJonathan Bastien-Filiatrault
This avoids user confusion when they see that their device is not detected. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-01smsc-ircc2: bypass PNP detection until we get the quirks worked outBjorn Helgaas
Don't use PNP detection by default yet. We have some PNP and BIOS issues to work out first. Sample problem on a Toshiba Portege 4000: the SMCf010 device is handed off disabled. We assign I/O ports originally assigned to the SMCf010 to a PCMCIA device instead. We enable the SMCf010, configuring it to use disjoint ports, but _SRS doesn't work correctly, so the device doesn't work. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Andrey Borzenkov <arvidjaar@mail.ru> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-28smsc-ircc2: skip preconfiguration for PNP devicesBjorn Helgaas
If we rely on the device resources from PNPBIOS, we also have to rely on the BIOS to configure any bridges on the way to the device. Using the PNPBIOS resources but changing the configuration of a bridge behind the back of the firmware is likely to make things inconsistent. This patch addresses part of the 2.6.22 regression: "no irda0 interface (2.6.21 was OK), smsc does not find chip" It fixes smsc-ircc2 PNP device detection on HP nx5000 laptops. Other laptops, including HP nc6000, HP nc8000, HP nw8000, and Toshiba Portege 4000, still need PNP quirks to make this work. With "smsc-ircc2.nopnp", we do the legacy device probe, including manual bridge preconfiguration, as before. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Samuel Ortiz <samuel@sortiz.org> Acked-by: "Linus Walleij (LD/EAB)" <linus.walleij@ericsson.com> Cc: Andrey Borzenkov <arvidjaar@mail.ru> Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08smsc-ircc2: add PNP supportBjorn Helgaas
Claim devices using PNP, unless the user explicitly specified device addresses. This can be disabled with the "smsc-ircc2.nopnp" option. This removes the need for probing legacy addresses and helps untangle IR devices from serial8250 devices. Sometimes the SMC device is at a legacy COM port address but does not use the legacy COM IRQ. In this case, claiming the device using PNP rather than 8250 legacy probe means we can automatically use the correct IRQ rather than forcing the user to use "setserial" to set the IRQ manually. If the PNP claim doesn't work, make sure you don't have a setserial init script, e.g., /etc/init.d/setserial, configured to poke in legacy COM port resources for the IRDA device. That causes the serial driver to claim resources needed by this driver. Based on this patch by Ville Syrjälä: http://www.hpl.hp.com/personal/Jean_Tourrilhes/IrDA/ir260_smsc_pnp.diff Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Keith Owens <kaos@ocs.com.au> Cc: Len Brown <lenb@kernel.org> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Matthieu CASTET <castet.matthieu@free.fr> Cc: Jean Tourrilhes <jt@hpl.hp.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Ville Syrjala <syrjala@sci.fi> Cc: Russell King <rmk+serial@arm.linux.org.uk> Acked-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08smsc-ircc2: tidy up module parameter checkingBjorn Helgaas
To determine whether the user specified a module parameter, use some #defines instead of checking for bare magic numbers. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Keith Owens <kaos@ocs.com.au> Cc: Len Brown <lenb@kernel.org> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Matthieu CASTET <castet.matthieu@free.fr> Cc: Jean Tourrilhes <jt@hpl.hp.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Ville Syrjala <syrjala@sci.fi> Cc: Russell King <rmk+serial@arm.linux.org.uk> Cc: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[IrDA]: SMC SuperIO Chip LPC47N227 not identified properlyPeter Kovar
SMC SuperIO Chip LPC47N227 used for IrDA is not detected because its device identification byte can be 0x7A instead of 0x5A. Patch from Peter Kovar <peter.kovar@gmail.com> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_mac_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->mac.raw = skb->data' operation, so that we can later turn skb->mac.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-28[IrDA] smsc-ircc: More laptops detectedLinus Walleij (LD/EAB
This patch detects the smsc-ircc chipset on the nx1000 (including nx7000 and nx7010) and the nx5000 HP/Compaq laptop series. Patch from "Linus Walleij (LD/EAB)" <linus.walleij@ericsson.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-12[PATCH] smsc-ircc2: fix section reference mismatchesDmitry Torokhov
subsystem_configurations array is only used by an __init function, therefore it should be marked __initdata, not __devinitdata. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-05-09[IRDA]: smsc-ircc: Minimal hotplug support.David Brownell
Minimal PNP hotplug support for the smsc-ircc2 driver. A modular driver will be modprobed via hotplug, but still bypasses driver model probing. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Samuel Ortiz <samuel.ortiz@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-14[IRDA]: smsc-ircc2, smcinit support for ALi ISA bridgesLinus Walleij
From: Linus Walleij <triad@df.lth.se> This patch enables support for ALi ISA bridges when we run the smcinit code. It is needed to properly configure some Toshiba laptops. Signed-off-by: Samuel Ortiz <samuel.ortiz@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[IRDA]: smcinit merged into smsc-ircc driverLinus Walleij
This patch integrates the smcinit code into the smsc-ircc driver. Some laptops have their smsc-ircc chip not properly configured by the BIOS and needs some preconfiguration. Currently, this can be done from userspace with smcinit, a utility that comes with the irda-utils package. It messes with ioports and PCI settings, from userspace. Now with this patch, if we happen to be on one of the known to be faulty laptops, we preconfigure the chip from the driver. Patch from Linus Walleij <triad@df.lth.se> Signed-off-by: Samuel Ortiz <samuel.ortiz@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-31Merge master.kernel.org:/home/rmk/linux-2.6-drvmodelLinus Torvalds
Manual #include fixups for clashes - there may be some unnecessary
2005-10-30[PATCH] smsc-ircc2: PM cleanup - do not close device when suspendingDmitry Torokhov
smsc-ircc2 - avoid closing network device when suspending; just release interrupt and disable DMA ourselves. Also make sure to reset chip when resuming. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Tourrilhes <jt@bougret.hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-07[PATCH] Fix smsc_ircc_init return valueBrice Goglin
I noticed a strange return value in smsc_ircc_init in drivers/net/irda/smsc_ircc2.c in rc4-mm1. When reaching the line "if (ircc_fir > 0 && ircc_sir > 0)", ret is 0. So I don't see the point of setting it to 0 in the "else" case. >From what I see in 2.6.12 it should probably be set to -ENODEV at the begining of the "else" case. The attached patch does this. Note that I didn't actually see any breakage caused by this. Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org> Cc: Dmitry Torokhov <dtor_core@ameritech.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] smsc-ircc2: dont use void * where specific type will doDmitry Torokhov
IRDA: smsc-ircc2 - do not over-use void * pointers, use specific types wherever possible. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] smsc-ircc2: use netdev_priv()Dmitry Torokhov
IRDA: smsc-ircc2 - use netdev_priv() instead of accessing pointer directly. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] smsc-ircc2: add to sysfs as platform device, new PMDmitry Torokhov
IRDA: smsc-ircc2 - add sysfs support (platform device and driver) and switch power management to the new scheme. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] smsc-ircc2: dont pass iobase aroundDmitry Torokhov
IRDA: smsc-ircc2 - cleanup - do not pass around iobase, it can be retrieved from smsc_ircc_cb structure. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] smsc-ircc2: remove typedefsDmitry Torokhov
IRDA: smsc-ircc2 - remove excessive typedefs. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] smsc-ircc2: drop DIM macro in favor of ARRAY_SIZEDmitry Torokhov
IRDA: smsc-ircc2 - remove home-grown DIM macro, use ARRAY_SIZE intead. Also fix out-of-bound array access. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] smsc-ircc2: formatting fixesDmitry Torokhov
IRDA: smsc-ircc2 - some formatting changes for better readability. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] smsc-ircc2: whitespace fixesDmitry Torokhov
IRDA: smsc-ircc2 - whitespace fixes. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
