path: root/drivers/net/irda/irda-usb.c
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-27USB: Dealias -110 code (more complete)Pete Zaitcev
The purpose of this patch is to split off the case when a device does not reply on the lower level (which is reported by HC hardware), and a case when the device accepted the request, but does not reply at upper level. This redefinition allows to diagnose issues easier, without asking the user if the -110 happened "immediately". The usbmon splits such cases already thanks to its timestamp, but it's not always available. I adjusted all drivers which I found affected (by searching for "urb"). Out of tree drivers may suffer a little bit, but I do not expect much breakage. At worst they may print a few messages. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-25[PATCH] irda-usb printk fixAndrew Morton
drivers/net/irda/irda-usb.c: In function 'stir421x_patch_device': drivers/net/irda/irda-usb.c:1108: warning: format '%u' expects type 'unsigned int', but argument 4 has type 'size_t' Cc: Greg KH <greg@kroah.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-17[IRDA]: irda-usb.c: STIR421x cleanupsNick Fedchik
This cleans the STIR421x part of the irda-usb code. We also no longer try to load all existing firmwares but only the matching one (according to the USB id we get from the dongle). Signed-off-by: Nick Fedchik <nfedchik@atlantic-link.com.ua> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-06[IRDA] irda-usb: use NULL instead of 0Randy Dunlap
Use NULL instead of 0 for a null pointer value (sparse warning): drivers/net/irda/irda-usb.c:1781:30: warning: Using plain integer as NULL pointer Also, correct timeout argument to use milliseconds instead of jiffies. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-14[IRDA]: irda-usb, unregister netdev when patch upload failsSamuel Ortiz
In the STIR421x case, when the firmware upload fails, we need to unregister_netdev. Otherwise we hit a BUG on free_netdev(), if sysfs is enabled. Signed-off-by: Samuel Ortiz <samuel.ortiz@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[IRDA]: Support for Sigmatel STIR421x chipSamuel Ortiz
This patch enables support for the Sigmatel's STIR421x IrDA chip. Once patched with Sigmatel's firmware, this chip "almost" follows the USB-IrDA spec. Thus this patch is against irda-usb.[ch]. The code has been tested by Nick Fedchik on an STIR4210 chipset based dongle. Signed-off-by: Samuel Ortiz <samuel.ortiz@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[PATCH] USB: Fix irda-usb use after useEugene Teo
Don't read from free'd memory after calling netif_rx(). docopy is used as a boolean (0 and 1) so unsigned int is sufficient. Coverity bug #928 Signed-off-by: Eugene Teo <eugene.teo@eugeneteo.net> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-19[IRDA]: irda-usb bug fixesJean Tourrilhes
This patch fixes 2 bugs in the USB-IrDA code. The first one is a buffer overrun in the RX path. We are now using IRDA_SKB_MAX_MTU when initializing the Rx URB. The second one is a potential stack recursion when unplugging the USB dongle. It seems that first we get the Rx URB with a generic error code, and after a while the Rx URB comes again with a "disconnect" error code. Since we are resubmitting the Rx URB immediately after receiving the first error one, we might enter an endless loop. When getting an error Rx URB, the patch defers the Rx URB resubmitting so that it gives us a chance to catch the disconnect one, in case the dongle has juts been unplugged. Tested against 2.6.16-rc2. Patch from Jean Tourrilhes Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Samuel Ortiz <samuel.ortiz@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28drivers/net: Remove pointless checks for NULL prior to calling kfree()Jesper Juhl
2005-09-08[PATCH] USB: URB_ASYNC_UNLINK flag removed from the kernelAlan Stern
29 July 2005, Cambridge, MA: This afternoon Alan Stern submitted a patch to remove the URB_ASYNC_UNLINK flag from the Linux kernel. Mr. Stern explained, "This flag is a relic from an earlier, less-well-designed system. For over a year it hasn't been used for anything other than printing warning messages." An anonymous spokesman for the Linux kernel development community commented, "This is exactly the sort of thing we see happening all the time. As the kernel evolves, support for old techniques and old code can be jettisoned and replaced by newer, better approaches. Proprietary operating systems do not have the freedom or flexibility to change so quickly." Mr. Stern, a staff member at Harvard University's Rowland Institute who works on Linux only as a hobby, noted that the patch (labelled as548) did not update two files, keyspan.c and option.c, in the USB drivers' "serial" subdirectory. "Those files need more extensive changes," he remarked. "They examine the status field of several URBs at times when they're not supposed to. That will need to be fixed before the URB_ASYNC_UNLINK flag is removed." Greg Kroah-Hartman, the kernel maintainer responsible for overseeing all of Linux's USB drivers, did not respond to our inquiries or return our calls. His only comment was "Applied, thanks." Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
