path: root/drivers/net/hyperv/netvsc.c
2014-04-30hyperv: Enable sendbuf mechanism on the send pathKY Srinivasan
We send packets using a copy-free mechanism (this is the Guest to Host transport via VMBUS). While this is obviously optimal for large packets, it may not be optimal for small packets. Hyper-V host supports a second mechanism for sending packets that is "copy based". We implement that mechanism in this patch. In this version of the patch I have addressed a comment from David Miller. With this patch (and all of the other offload and VRSS patches), we are now able to almost saturate a 10G interface between Linux VMs on Hyper-V on different hosts - close to 9 Gbps as measured via iperf. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-23hyperv: Simplify the send_completion variablesHaiyang Zhang
The union contains only one member now, so we use the variables in it directly. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-23hyperv: Remove recv_pkt_list and lockHaiyang Zhang
Removed recv_pkt_list and lock, and updated related code, so that the locking overhead is reduced especially when multiple channels are in use. The recv_pkt_list isn't actually necessary because the packets are processed sequentially in each channel. It has been replaced by a local variable, and the related lock for this list is also removed. The is_data_pkt field is not used in receive path, so its assignment is cleaned up. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-21hyperv: Add support for virtual Receive Side Scaling (vRSS)Haiyang Zhang
This feature allows multiple channels to be used by each virtual NIC. It is available on Hyper-V host 2012 R2. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-11Drivers: net: hyperv: Negotiate suitable ndis version for offload supportKY Srinivasan
Ws2008R2 supports ndis_version 6.1 and 6.1 is the minimal version required for various offloads. Negotiate ndis_version 6.1 when on ws2008r2. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-10hyperv: Change the receive buffer size for legacy hostsHaiyang Zhang
Due to a bug in the Hyper-V host verion 2008R2, we need to use a slightly smaller receive buffer size, otherwise the buffer will not be accepted by the legacy hosts. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-19hyperv: Add latest NetVSP versions to auto negotiationHaiyang Zhang
It auto negotiates the highest NetVSP version supported by both guest and host. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-17Drivers: net: hyperv: Cleanup the netvsc receive callback functioKY Srinivasan
Get rid of the buffer allocation in the receive path for normal packets. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-17Drivers: net: hyperv: Cleanup the receive pathKY Srinivasan
Make the receive path a little more efficient by parameterizing the required state rather than re-establishing that state. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-27hyperv: Add support for physically discontinuous receive bufferHaiyang Zhang
This will allow us to use bigger receive buffer, and prevent allocation failure due to fragmented memory. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-06drivers/net/*: Fix FSF address in file headersJeff Kirsher
Several files refer to an old address for the Free Software Foundation in the file header comment. Resolve by replacing the address with the URL <http://www.gnu.org/licenses/> so that we do not have to keep updating the header comments anytime the address changes. CC: Jay Vosburgh <fubar@us.ibm.com> CC: Veaceslav Falico <vfalico@redhat.com> CC: Andy Gospodarek <andy@greyhouse.net> CC: Haiyang Zhang <haiyangz@microsoft.com> CC: "K. Y. Srinivasan" <kys@microsoft.com> CC: Paul Mackerras <paulus@samba.org> CC: Ian Campbell <ian.campbell@citrix.com> CC: Wei Liu <wei.liu2@citrix.com> CC: Rusty Russell <rusty@rustcorp.com.au> CC: "Michael S. Tsirkin" <mst@redhat.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Wei Liu <wei.liu2@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-29hyperv: Fix a compiler warning in netvsc_send()Haiyang Zhang
Fixed: warning: cast from pointer to integer of different size The Hyper-V hosts always use 64 bit request id. The guests can have 32 or 64 bit pointers which equal to the ulong type size. So we cast it to ulong type. And, assigning 32bit integer to 64 bit variable works fine. The VMBus returns the same id in the completion packet. But the value has no effect on the host side. Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-08hyperv: Fix RNDIS send_completion code pathHaiyang Zhang
In some cases, the VM_PKT_COMP message can arrive later than RNDIS completion message, which will free the packet memory. This may cause panic due to access to freed memory in netvsc_send_completion(). This patch fixes this problem by removing rndis_filter_send_request_completion() from the code path. The function was a no-op. Reported-by: Long Li <longli@microsoft.com> Tested-by: Long Li <longli@microsoft.com> Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-02hyperv: Report actual status in receive completion packetHaiyang Zhang
The existing code always reports NVSP_STAT_SUCCESS. This patch adds the mechanism to report failure when it happens. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-02hyperv: Remove extra allocated space for recv_pkt_list elementsHaiyang Zhang
The receive code path doesn't use the page buffer, so remove the extra allocated space here. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-03hyperv: Move wait completion msg code into rndis_filter_halt_device()Haiyang Zhang
We need to wait for send_completion msg before put_rndis_request() at the end of rndis_filter_halt_device(). Otherwise, netvsc_send_completion() may reference freed memory which is overwritten, and cause panic. Reported-by: Long Li <longli@microsoft.com> Reported-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-06-06drivers: net: Remove casts to same typeJoe Perches
Adding casts of objects to the same type is unnecessary and confusing for a human reader. For example, this cast: int y; int *p = (int *)&y; I used the coccinelle script below to find and remove these unnecessary casts. I manually removed the conversions this script produces of casts with __force, __iomem and __user. @@ type T; T *p; @@ - (T *)p + p Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-04net/hyperv: Use wait_event on outstanding sends during device removalHaiyang Zhang
Change the busy-waiting/udelay to wait_event on outstanding sends. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-03net/hyperv: Add flow control based on hi/low watermarkHaiyang Zhang
In the existing code, we only stop queue when the ringbuffer is full, so the current packet has to be dropped or retried from upper layer. This patch stops the tx queue when available ringbuffer is below the low watermark. So the ringbuffer still has small amount of space available for the current packet. This will reduce the overhead of retries on sending. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-12net/hyperv: Add support for vlan trunking from guestsHaiyang Zhang
With this feature, a Linux guest can now configure multiple vlans through a single synthetic NIC on Win8 Hyper-V host. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-04net/hyperv: Add support for jumbo frame up to 64KBHaiyang Zhang
Allow the user set the MTU up to 65536 for Linux guests running on Hyper-V 2008 R2 or later. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-04net/hyperv: Add NETVSP protocol version negotiationHaiyang Zhang
Automatically negotiate the highest protocol version mutually recognized by both host and guest. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-04net/hyperv: Remove unnecessary kmap_atomic in netvsc driverHaiyang Zhang
__get_free_pages() doesn't return HI memory, so the memory is always mapped. kmap_atomic() is not necessary here. This patch removes the kmap_atomic() calls and related code for locking and page manipulation. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09net/hyperv: Fix the stop/wake queue mechanismHaiyang Zhang
The ring buffer is only used to pass meta data for outbound packets. The actual payload is accessed by DMA from the host. So the stop/wake queue mechanism based on counting and comparing number of pages sent v.s. number of pages in the ring buffer is wrong. Also, there is a race condition in the stop/wake queue calls, which can stop xmit queue forever. The new stop/wake queue mechanism is based on the actual bytes used by outbound packets in the ring buffer. The check for number of outstanding sends after stop queue prevents the race condition that can cause wake queue happening earlier than stop queue. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reported-by: Long Li <longli@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-01net/hyperv: Fix long lines in netvsc.cHaiyang Zhang
2011-11-29staging: hv: move hv_netvsc out of staging areaHaiyang Zhang
hv_netvsc has been reviewed on netdev mailing list on 6/09/2011. All recommended changes have been made. We are requesting to move it out of staging area. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: KY Srinivasan <kys@microsoft.com> Signed-off-by: Mike Sterling <Mike.Sterling@microsoft.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
