path: root/drivers/net/hamradio/bpqether.c
2013-05-28net: pass info struct via netdevice notifierJiri Pirko
So far, only net_device * could be passed along with netdevice notifier event. This patch provides a possibility to pass custom structure able to provide info that event listener needs to know. Signed-off-by: Jiri Pirko <jiri@resnulli.us> v2->v3: fix typo on simeth shortened dev_getter shortened notifier_info struct name v1->v2: fix notifier_call parameter in call_netdevice_notifier() Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-18net: proc: change proc_net_remove to remove_proc_entryGao feng
proc_net_remove is only used to remove proc entries that under /proc/net,it's not a general function for removing proc entries of netns. if we want to remove some proc entries which under /proc/net/stat/, we still need to call remove_proc_entry. this patch use remove_proc_entry to replace proc_net_remove. we can remove proc_net_remove after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-18net: proc: change proc_net_fops_create to proc_createGao feng
Right now, some modules such as bonding use proc_create to create proc entries under /proc/net/, and other modules such as ipv4 use proc_net_fops_create. It looks a little chaos.this patch changes all of proc_net_fops_create to proc_create. we can remove proc_net_fops_create after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-06sections: fix section conflicts in drivers/net/hamradioAndi Kleen
Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2011-05-05net: call dev_alloc_name from register_netdeviceJiri Pirko
Force dev_alloc_name() to be called from register_netdevice() by dev_get_valid_name(). That allows to remove multiple explicit dev_alloc_name() calls. The possibility to call dev_alloc_name in advance remains. This also fixes veth creation regresion caused by 84c49d8c3e4abefb0a41a77b25aa37ebe8d6b743 Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-27drivers/net: remove some rcu sparse warningsEric Dumazet
Add missing __rcu annotations and helpers. minor : Fix some rcu_dereference() calls in macvtap Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-26drivers/net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-03hamradio: avoid null deref v3Dan Carpenter
This should address the problems in version 1 (lazy) and version 2 (ugly). Bump the stats on orig_dev not on the newly assigned NULL dev variable. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-25net: use net_eq to compare netsOctavian Purdila
Generated with the following semantic patch @@ struct net *n1; struct net *n2; @@ - n1 == n2 + net_eq(n1, n2) @@ struct net *n1; struct net *n2; @@ - n1 != n2 + !net_eq(n1, n2) applied over {include,net,drivers/net}. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02NET: Fix possible corruption in bpqether driverRalf Baechle
The bpq ether driver is modifying the data art of the skb by first dropping the KISS byte (a command byte for the radio) then prepending the length + 4 of the remaining AX.25 packet to be transmitted as a little endian 16-bit number. If the high byte of the length has a different value than the dropped KISS byte users of clones of the skb may observe this as corruption. This was observed with by running listen(8) -a which uses a packet socket which clones transmit packets. The corruption will then typically be displayed for as a KISS "TX Delay" command for AX.25 packets in the range of 252..508 bytes or any other KISS command for yet larger packets. Fixed by using skb_cow to create a private copy should the skb be cloned. Using skb_cow also allows us to cleanup the old logic to ensure sufficient headroom in the skb. While at it, replace a return of 0 from bpq_xmit with the proper constant NETDEV_TX_OK which is now being used everywhere else in this function. Affected: all 2.2, 2.4 and 2.6 kernels. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Reported-by: Jann Traschewski <jann@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01convert hamradio drivers to netdev_txreturnt_tStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-17net: fix network drivers ndo_start_xmit() return valuesPatrick McHardy
Fix up remaining drivers returning a magic or an errno value from their ndo_start_xmit() functions that were missed in the first pass: - isdn_net: missed conversion - bpqether: missed conversion: skb is freed, so return NETDEV_TX_OK - hp100: intention appears to be to resubmit skb once resources are available, but due to no queue handling it is dropped for now. - lapbether: skb is freed, so return NETDEV_TX_OK Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13net: fix network drivers ndo_start_xmit() return values (part 6)Patrick McHardy
Fix up hamradio drivers that return an errno value to dev_queue_xmit(), causing it to print a warning an free the skb. - bpqether: skb is freed: use after free Compile tested only. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-10net: convert usage of packet_type to read_mostlyStephen Hemminger
Protocols that use packet_type can be __read_mostly section for better locality. Elminate any unnecessary initializations of NULL. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-17drivers/net/hamradio: fix sparse warning: context imbalanceHannes Eder
Impact: Attribute functions with __acquires(...) resp. __releases(...). Fix this sparse warnings: drivers/net/hamradio/bpqether.c:387:13: warning: context imbalance in 'bpq_seq_start' - wrong count at exit drivers/net/hamradio/bpqether.c:419:13: warning: context imbalance in 'bpq_seq_stop' - unexpected unlock Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-17drivers/net/hamradio: fix warning: format not a string literal and no ...Hannes Eder
Impact: Use 'static const char[]' instead of 'static char[]' and while being at it fix an issue in 'mkiss_init_driver', where in case of an error the status code was not passed to printk. Fix this warnings: drivers/net/hamradio/6pack.c: In function 'sixpack_init_driver': drivers/net/hamradio/6pack.c:802: warning: format not a string literal and no format arguments drivers/net/hamradio/bpqether.c: In function 'bpq_init_driver': drivers/net/hamradio/bpqether.c:609: warning: format not a string literal and no format arguments drivers/net/hamradio/mkiss.c: In function 'mkiss_init_driver': drivers/net/hamradio/mkiss.c:988: warning: format not a string literal and no format arguments drivers/net/hamradio/mkiss.c:991: warning: format not a string literal and no format arguments drivers/net/hamradio/scc.c: In function 'scc_init_driver': drivers/net/hamradio/scc.c:2109: warning: format not a string literal and no format arguments drivers/net/hamradio/yam.c: In function 'yam_init_driver': drivers/net/hamradio/yam.c:1094: warning: format not a string literal and no format arguments Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21net: constify VFTsJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21bpqether: convert to net_device_opsStephen Hemminger
2009-01-21bpqether: convert to internal net_device_statsStephen Hemminger
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-22netdev: Handle ->addr_list_lock just like ->_xmit_lock for lockdep.David S. Miller
The new address list lock needs to handle the same device layering issues that the _xmit_lock one does. This integrates work done by Patrick McHardy. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdev: Allocate multiple queues for TX.David S. Miller
alloc_netdev_mq() now allocates an array of netdev_queue structures for TX, based upon the queue_count argument. Furthermore, all accesses to the TX queues are now vectored through the netdev_get_tx_queue() and netdev_for_each_tx_queue() interfaces. This makes it easy to grep the tree for all things that want to get to a TX queue of a net device. Problem spots which are not really multiqueue aware yet, and only work with one queue, can easily be spotted by grepping for all netdev_get_tx_queue() calls that pass in a zero index. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08netdev: Move _xmit_lock and xmit_lock_owner into netdev_queue.David S. Miller
Accesses are mostly structured such that when there are multiple TX queues the code transformations will be a little bit simpler. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2007-10-10[NET]: Move hardware header operations out of netdevice.Stephen Hemminger
Since hardware header operations are part of the protocol class not the device instance, make them into a separate object and save memory. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Wrap netdevice hardware header creation.Stephen Hemminger
Add inline for common usage of hardware header creation, and fix bug in IPV6 mcast where the assumption about negative return is an errno. Negative return from hard_header means not enough space was available,(ie -N bytes). Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make device event notification network namespace safeEric W. Biederman
Every user of the network device notifiers is either a protocol stack or a pseudo device. If a protocol stack that does not have support for multiple network namespaces receives an event for a device that is not in the initial network namespace it quite possibly can get confused and do the wrong thing. To avoid problems until all of the protocol stacks are converted this patch modifies all netdev event handlers to ignore events on devices that are not in the initial network namespace. As the rest of the code is made network namespace aware these checks can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make packet reception network namespace safeEric W. Biederman
This patch modifies every packet receive function registered with dev_add_pack() to drop packets if they are not from the initial network namespace. This should ensure that the various network stacks do not receive packets in a anything but the initial network namespace until the code has been converted and is ready for them. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31bpqether: fix rcu usagePaul E. McKenney
The rcu_dereference() primitive needs to be applied to an l-value in order to ensure that compiler writers don't get an opportunity to apply reordering optimizations that could result in multiple fetches or in other misbehavior. This patch pulls the rcu_dereference() calls in bpq_seq_next() up to the point at which the fetched pointers are still l-values, rather than after list_entry() has transformed them into r-values. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-25[SK_BUFF]: Introduce skb_reset_network_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[PATCH] mark struct file_operations const 5Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[AX.25]: Fix default address and broadcast address initialization.Ralf Baechle
Only the callsign but not the SSID part of an AX.25 address is ASCII based but Linux by initializes the SSID which should be just a 4-bit number from ASCII anyway. Fix that and convert the code to use a shared constant for both default addresses. While at it, use the same style for null_ax25_address also. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-10[BPQ] lockdep: fix false positiveRalf Baechle
Bpqether is encapsulating AX.25 frames into ethernet frames. There is a virtual bpqether device paired with each ethernet devices, so it's normal to pass through dev_queue_xmit twice for each frame which triggers the locking detector. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-18[PATCH] rcu in bpqether driver.Ralf Baechle
From Suzanne Wood <suzannew@cs.pdx.edu>: Clarify RCU implementation in bpqether.c. Because bpq_new_device() calls list_add_rcu() and bpq_free_device() calls list_del_rcu(), substitute list_for_each_entry_rcu() for list_for_each_entry() in bpq_get_ax25_dev() and in bpq_seq_start(). Add rcu dereference protection in bpq_seq_next(). The rcu_read_lock()/unlock() in bpq_device_event() are removed because netdev event handlers are called with RTNL locking in place. FYI: bpq_free_device() calls list_del_rcu() which, per list.h, requires synchronize_rcu() which can block or call_rcu() or call_rcu_bh() which cannot block. Herbert Xu notes that synchronization is done here by unregister_netdevice(). This calls synchronize_net() which in turn uses synchronize_rcu(). Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-12[AX.25]: Rename ax25_encapsulate to ax25_hard_headerRalf Baechle
Rename ax25_encapsulate to ax25_hard_header which these days more accurately describes what the function is supposed to do. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->real_devDavid S. Miller
Bonding just wants the device before the skb_bond() decapsulation occurs, so simply pass that original device into packet_type->func() as an argument. It remains to be seen whether we can use this same exact thing to get rid of skb->input_dev as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-24[AX25] Introduce ax25_type_transArnaldo Carvalho de Melo
Replacing the open coded equivalents and making ax25 look more like a linux network protocol, i.e. more similar to inet. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
