path: root/drivers/net/gianfar_ethtool.c
2009-02-01gianfar: Implement proper, per netdevice wakeup managementAnton Vorontsov
This patch implements wakeup management for the gianfar driver. The driver should set wakeup enable if WOL is enabled, so that phylib won't power off an attached PHY. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-17gianfar: Add Scatter Gather supportDai Haruki
Scatter Gather support in gianfar driver to handle fragmented frames on the transmit side. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Dai Haruki <dai.haruki@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-16gianfar: Fix eTSEC configuration procedureDai Haruki
Fix some bugs in the ethtool configuration functions: * gfar_clean_rx_ring should not be called with interrupts disabled. * Update last transmission time to avoid tx timeout. * Delete redundant NETIF_F_IP_CSUM check in gfar_start_xmit * Use netif_tx_lock_bh when reconfiguring the tx csum Signed-off-by: Dai Haruki <dai.haruki@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-16gianfar: Optimize interrupt coalescing configurationDai Haruki
Store the interrupt coalescing values in the form in which they will be written to the interrupt coalescing registers. This puts a little overhead into the ethtool configuration, and takes it out of the interrupt handler Signed-off-by: Dai Haruki <dai.haruki@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-16gianfar: Convert gianfar to an of_platform_driverAndy Fleming
Does the same for the accompanying MDIO driver, and then modifies the TBI configuration method. The old way used fields in einfo, which no longer exists. The new way is to create an MDIO device-tree node for each instance of gianfar, and create a tbi-handle property to associate ethernet controllers with the TBI PHYs they are connected to. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16gianfar: Add magic packet and suspend/resume support.Scott Wood
Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-10[netdrvr] Stop using legacy hooks ->self_test_count, ->get_stats_countJeff Garzik
These have been superceded by the new ->get_sset_count() hook. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10Clean up duplicate includes in drivers/net/Jesper Juhl
This patch cleans up duplicate includes in drivers/net/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-07[POWERPC] Add "is_power_of_2" checking to log2.h.Robert P. J. Day
Add the inline function "is_power_of_2()" to log2.h, where the value zero is *not* considered to be a power of two. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-04-20[PATCH] Fix locking in gianfarAndy Fleming
This patch fixes several bugs in the gianfar driver, including a major one where spinlocks were horribly broken: * Split gianfar locks into two types: TX and RX * Made it so gfar_start() now clears RHALT * Fixed a bug where calling gfar_start_xmit() with interrupts off would corrupt the interrupt state * Fixed a bug where a frame could potentially arrive, and never be handled (if no more frames arrived * Fixed a bug where the rx_work_limit would never be observed by the rx completion code * Fixed a bug where the interrupt handlers were not actually protected by their spinlocks Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-02-07[PATCH] gianfar: Fix sparse warningsKumar Gala
Fixed sparse warnings mainly due to lack of __iomem. Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-18[PATCH] Gianfar update and sysfs supportAndy Fleming
This seems to have gotten lost, so I'll resend. Signed-off-by: Andy Fleming <afleming@freescale.com> * Added sysfs support to gianfar for modifying FIFO and stashing parameters * Updated driver to support 10 Mbit, full duplex operation * Improved comments throughout * Cleaned up and optimized offloading code * Fixed a bug where rx buffers were being improperly mapped and unmapped * (only manifested if cache-coherency was off) * Added support for using the eTSEC exact-match MAC registers * Bumped the version to 1.3 * Added support for distinguishing between reduced 100 and 10 Mbit modes * Modified default coalescing values to lower latency * Added documentation Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-13[PATCH] Update email address for KumarKumar Gala
Changed jobs and the Freescale address is no longer valid. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-23[netdrvr gianfar] use new phy layerAndy Fleming
Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-27[PATCH] gianfar: Add support enhanced TSEC features on the MPC 8548Kumar Gala
Jeff, Just incase this got lost in the recent netdev mailing list transition here is a nicer version of Andy's patch for gianfar. - kumar * TCP/IP/UDP checksumming and verification * VLAN tag insertion/extraction * Larger multicast hash-table * Padding to align IP headers Also added: * msg lvl support * Some whitespace cleanup Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com>
