path: root/drivers/net/fec.c
2009-04-16Merge branch 'master' of ↵David S. Miller
2009-04-16fec: call fec_restart() in fec_open()Sascha Hauer
We called fec_stop() in fec_enet_close(), thus we have to call fec_restart() in fec_enet_open(). Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-16FEC Buffer reworkSascha Hauer
Allocate buffers in fec_open and free them again in fec_close. This makes it possible to use this driver as a module. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-16fec: switch to net_device_opsSascha Hauer
2009-04-16fec: remove debugging printksSascha Hauer
These printks in fec_timeout do not give useful information in a production kernel. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-16fec: align receive packetsSascha Hauer
Otherwise we get a lot of alignment errors Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-16fec: refactor init functionSascha Hauer
fec_enet_init() does the hardware initialisation and then calls fec_restart() which does the same initialisation again, so we can safely remove the initialisation from fec_enet_init(). Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-16fec: refactor set_multicast_list() to make it more readableSascha Hauer
2009-04-16fec: Codingstyle cleanupsSascha Hauer
2009-04-16fec: remove unnecessary castSascha Hauer
2009-04-16fec: do not typedef struct typesSascha Hauer
2009-04-16fec: switch to writel/readlSascha Hauer
2009-04-08FEC driver: add missing #endifSascha Hauer
2009-02-26m68knommu: remove ColdFire specific setup code from FEC driverGreg Ungerer
Remove the ColdFire CPU specific setup from here. The ColdFire CPU platform code now sets up all this. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/Kconfig
2009-02-01FEC: Turn FEC driver into platform device driverSascha Hauer
This turns the fec driver into a platform device driver for new platforms. Old platforms are still supported through a FEC_LEGACY define till they are also ported. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01fec: Add support for Freescale MX27Sascha Hauer
2009-02-01fec: replace flush_dcache_range with dma_sync_singleSascha Hauer
flush_dcache_range is not portable across architectures. Use dma_sync_single instead. Also, the memory must be synchronised in the receive path aswell. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01fec: Fix KS8721BL_ICSR phy register offsetSascha Hauer
According to the datasheet the ICSR register is at offset 27, not 22. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01fec: use dma_alloc_coherent for descriptor ringSascha Hauer
2009-02-01fec: do not use memcpy on physical addressesSascha Hauer
2009-02-01fec: use linux/*.h instead of asm/*.hSascha Hauer
2009-02-01fec: remove empty functionsSascha Hauer
There are some architecture specific functions which are all empty. Remove them. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01fec: remove unused #else branchesSascha Hauer
The #else branches throughout this driver belong to a PowerPC 8xx for which this driver is not used. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-27m68knommu: correct the mii calculations for 532x ColdFire FECMatt Waddel
Signed-off-by: Matt Waddel <Matt.Waddel@freescale.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2008-11-12netdevice: safe convert to netdev_priv() #part-2Wang Chen
We have some reasons to kill netdev->priv: 1. netdev->priv is equal to netdev_priv(). 2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously netdev_priv() is more flexible than netdev->priv. But we cann't kill netdev->priv, because so many drivers reference to it directly. This patch is a safe convert for netdev->priv to netdev_priv(netdev). Since all of the netdev->priv is only for read. But it is too big to be sent in one mail. I split it to 4 parts and make every part smaller than 100,000 bytes, which is max size allowed by vger. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-23m68knommu: remove last use of CONFIG_FADS and CONFIG_RPXCLASSICGreg Ungerer
They have never been used in this port of the driver. It is has only ever been used on the ColdFire SoC ethernet core. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2008-07-23m68knommu: remove RPXCLASSIC from the m68k treeSebastian Siewior
This ifdefs are leftovers from the time as the driver was running on a ppc. Signed-off-by: Sebastian Siewior <bigeasy@linutronix.de> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2008-07-23m68knommu: fec: remove FADSSebastian Siewior
I found config FADS only in ppc/Kconfig. Bye bye relic. Signed-off-by: Sebastian Siewior <bigeasy@linutronix.de> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2008-05-01m68knommu: fix FEC driver lockingSebastian Siewior
It's easy: grab locks before talking to hardware and realease them afterwards. The one big lock has been splitted into a hw_lock and mii_lock. Signed-off-by: Sebastian Siewior <bigeasy@linutronix.de> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01m68knommu: kill warnings in FEC driverSebastian Siewior
linux-2.6-mk68/drivers/net/fec.c: In function 'fec_enet_module_init': linux-2.6-mk68/drivers/net/fec.c:2627: warning: unused variable 'j' linux-2.6-mk68/drivers/net/fec.c: At top level: linux-2.6-mk68/drivers/net/fec.c:2136: warning: 'mii_link_interrupt' defined but not used Signed-off-by: Sebastian Siewior <bigeasy@linutronix.de> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01m68knommu: remove unused interrupts in FEC driverGreg Ungerer
Remove the acquisition of unused interrupt types. We don't need to register all the TX and RX varients used on some ColdFire FEC hardware. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01m68knommu: fix ColdFire 5272 fec driver hash registersGreg Ungerer
Renamed the 5272 hash_table registers to match the "grp" hash_table registers of the other ColdFire parts. They are actually a group hash. The makes for consistent setup across all ColdFire parts. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04m68knommu: fix fec driver interrupt racesGreg Ungerer
The FEC driver has a common interrupt handler for all interrupt event types. It is raised on a number of distinct interrupt vectors. This handler can't be re-entered while processing an interrupt, so make sure all requested vectors are flagged as IRQF_DISABLED. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-23m68knommu: improve mii_do_cmd code in FEC driverPhilippe De Muyter
Improve the readability of mii_do_cmd(). Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-23m68knommu: improve code formating FEC driverPhilippe De Muyter
Indent all the `else' the same way. Remove some unecesary white space. Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET] drivers/net: statistics cleanup #1 -- save memory and shrink codeJeff Garzik
We now have struct net_device_stats embedded in struct net_device, and the default ->get_stats() hook does the obvious thing for us. Run through drivers/net/* and remove the driver-local storage of statistics, and driver-local ->get_stats() hook where applicable. This was just the low-hanging fruit in drivers/net; plenty more drivers remain to be updated. [ Resolved conflicts with napi_struct changes and fix sunqe build regression... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-30setup and detect 2nd phy on MCF5275 in FEC driverMike Cruse
Added code to recognize the second interface on M5275 boards. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-30clean up reading of ICR register in FEC driverGreg Ungerer
On the MCF5272, there is no need to read the ICR before writing it : the bit 4n+3 is a write-enable for the bits 4n,4n+1 and 4n+2. Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-30fix work queues in FEC driverGreg Ungerer
Fix the work queue code in the FEC driver. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-30remove unused config symbol from FEC driverGreg Ungerer
Removed unused CONFIG symbol and its conditional code from FEC driver. Pointed out by Robert P. J. Day <rpjday@mindspring.com>. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-30include cacheflush.h in FEC driverGreg Ungerer
Include cacheflush.h to get definitions for cache functions used in this code. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10[NET]: Kill eth_copy_and_sum().David S. Miller
It hasn't "summed" anything in over 7 years, and it's just a straight mempcy ala skb_copy_to_linear_data() so just get rid of it. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-09-12[PATCH] Remove more unnecessary driver printk'sAndy Gospodarek
As I promised last week, here is the first pass at removing all unnecessary printk's that exist in network device drivers currently in promiscuous mode. The duplicate messages are not needed so they have been removed. Some of these drivers are quite old and might not need an update, but I did them all anyway. I am currently auditing the remaining conditional printk's and will send out a patch for those soon. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
