path: root/drivers/net/ethernet/sun/sunbmac.h
2016-11-18sunbmac: Fix compiler warningTushar Dave
sunbmac uses '__u32' for dma handle while invoking kernel DMA APIs, instead of using dma_addr_t. This hasn't caused any 'incompatible pointer type' warning on SPARC because until now dma_addr_t is of type u32. However, recent changes in SPARC ATU (iommu) enables 64bit DMA and therefore dma_addr_t becomes of type u64. This makes 'incompatible pointer type' warnings inevitable. e.g. drivers/net/ethernet/sun/sunbmac.c: In function ‘bigmac_ether_init’: drivers/net/ethernet/sun/sunbmac.c:1166: warning: passing argument 3 of ‘dma_alloc_coherent’ from incompatible pointer type ./include/linux/dma-mapping.h:445: note: expected ‘dma_addr_t *’ but argument is of type ‘__u32 *’ This patch resolves above compiler warning. Signed-off-by: Tushar Dave <tushar.n.dave@oracle.com> Reviewed-by: chris hyser <chris.hyser@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-25sunbmac: use standard #defines from mii.h.Francois Romieu
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2011-08-11cassini/niu/sun*: Move the Sun driversJeff Kirsher
Moves the Sun drivers into drivers/net/ethernet/sun/ and make the necessary Kconfig and Makefile changes. Oliver Hartkopp <socketcan@hartkopp.net> suggested removing the sun* prefix on the driver names. This type of change I will leave up to the driver maintainers. CC: Sam Creasey <sammy@sammy.net> CC: Adrian Sun <asun@darksunrising.com> CC: Benjamin Herrenscmidt <benh@kernel.crashing.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
